Old 02-13-2004, 02:00 PM   #1
JonnySubaru
Member#: 17901
Default Anyone ever test for electrolysis? (grounding mod)
Just wondering if anyone has done this?
A couple volts tested between the coolant and the negative terminal would actually prove that our cars need the grounding mod.
Anyone?
JonnySubaru is offline   Reply With Quote
Old 02-13-2004, 08:27 PM   #2
Nivek-CA
Member#: 41415
Do a search you will find it.
Nivek-CA is offline   Reply With Quote
Old 02-15-2004, 12:52 AM   #3
JonnySubaru
Member#: 17901
I didn't find anything regarding the grounding mod solving potential electrolysis. Could you give me a pointer?
Old 02-15-2004, 02:35 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
This is NOT the purpose of the 'grounding mod'...it has nothing to do with electrolysis...it has to do with equalizing the electrical potential between chassis and engine components and reducing electrical 'noise'.
Old 02-15-2004, 10:57 PM   #5
Silverwheels
Member#: 51076
2004 WRX Sti
Baby-Rattle Blue
Problem is, it's hard to measure the potential between a liquid and a metal contacting the liquid without using specialized equipment.
The metal in the tip of your voltmeter probe will create an electrochemical reaction with with the coolant and form what is known as a half cell. The coolant, in turn, will react with the metal in the wall of the radiator to form another half cell. If you connect these two half cells through the voltmeter you will create a single-cell battery. The meter will read the voltage of this "battery" you have just made, but without more knowledge of the two electrodes and the intervening electrolyte, the reading will be just about meaningless.
There are ways of getting meaningful results using reference electrodes such as those found in pH meters, and there is a HUGE amount of information on the subject of electrolytic corrosion as Nivek-Ca has pointed out, but Uncle Scotty is correct that the presence or absence of a grounding mod would not affect electrolysis in a properly wired vehicle.
Sorry for running on, electrochemical instrumentation is part of what I do...
Silverwheels is offline   Reply With Quote
Old 02-16-2004, 06:13 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
For the electrolysis, see: http://www.neosyntheticoil.com/keepcool.htm
The second 'advantage' listed is 'prevents electrolysis'.
Old 02-17-2004, 11:24 AM   #7
JonnySubaru
Member#: 17901
"Ehhhum.... properly wired vehicle."
Ok... well I think you all missed my point. Electrolysis in automobiles often results from poor grounds in electrical automotive parts, i.e. sensors, starter motors, etc. If the Subaru suffers from such a condition (poor grounds), electrolysis would be a likely symptom.
Would the "electrochemical reaction" from a voltmeter show amount to even a volt on the voltmeter? The problem of electrolysis would show from several volts between the coolant and a good ground.
I would like to see some "evidence" rather than butt dyno results from adding additional grounds.
Since I love messing with my car, I want to do it... but would like a reason to waste a few hours on my car making a kit.
Old 02-17-2004, 11:25 AM   #8
JonnySubaru
Member#: 17901
Ok... I'll shut up and just try it myself. Thanks guys!
Old 02-17-2004, 11:39 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
The grounding mod isn't necessarily an HP mod, but a driveability mod
Hou: anyone ever get an in ground pool installed at their house? TKRbeast Texas Impreza Club Forum -- TXIC 26 07-26-2007 08:45 PM
Anyone ever work for enterprise car rental? nitrohuffer Off-Topic 17 02-17-2005 07:11 PM
Anyone ever test both a GC8 A/T and a GDA A/T SpeedRacerWRX02 Transmission (AT/MT) & Driveline 0 09-28-2004 09:24 PM
Anyone ever work for a coffee shop? GooseMan Off-Topic 16 03-10-2003 04:49 PM
Has anyone ever tested their IQ? FOoM_RiCE Off-Topic 21 08-25-2002 06:55 AM
