Old 02-13-2004, 04:11 PM   #1
CONBON101
Member#: 45592
2000 IMPREZA 2.5 RS
SILVER
Default 2000 2.5 Rs Idle Problem
My fiance's 00 2.5RS is not feeling so hot. When idling (doesnt matter whether engine is cold or hot) it wants to die and occasionally has stalled. We have replaced the coil pack, plugs, wires, and the o2 sensor (twice) and it hasnt seemed to help at all. It will idle normal sometimes, and then the tachometer will drop and then jump and then drop again and then jump again. It has only spit out on CEL code and it was for the O2 sensor (that is when we had it replaced for the second time). Is it possible the timing is off? They have also "reprogrammed" the computer but that didnt help. This has been going on for about 4 months now and it isnt getting better. It seems to me this is an easily fixable problem and i dont know what else to check other than the items we have already replaced. Back in the summer, his coil pack freaked out and emited sparks while running and it seems ever since then it was sort of idling unsmoothly, but not like it is now. Does anyone have any suggestions??
CONBON101 is offline   Reply With Quote
Old 02-18-2004, 11:23 AM   #2
kickin_81
Member#: 16679
2004 Forester XT
If you can, try to get the car running with the MAP sensor disconnected.
kickin_81 is offline   Reply With Quote
Old 02-18-2004, 11:29 AM   #3
CONBON101
Member#: 45592
2000 IMPREZA 2.5 RS
SILVER
I will try that this weekend. If you know off the top of your head, where is the MAP sensor located. Never had to mess with it before.
Old 02-18-2004, 03:23 PM   #4
kickin_81
Member#: 16679
2004 Forester XT
Hmmm, the sensor is at the throttlebody. There should be some wires that connects into it with a connector.
Old 02-18-2004, 03:37 PM   #5
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default vacuum leak
Check for vacuum leaks. Your CEL seems to point in that direction too.
vvk is offline   Reply With Quote
Old 02-20-2004, 05:39 PM   #6
kyledooley
Member#: 1055
2005 No legacy for u
It's a diesel
Another good possiblity is the idle air control (IAC) valve.
Sometimes they gum up and the solenoid isn't as smooth as it should be.
Does the stumble go away when you touch the gas?
Also, when it is idling wierd, pull the hose of the brake booster and see what happens.
The idle should climb a few hundred rpm. If it climbs and still stumbles, then it might be the MAP. If it climbs and stays smooth, the map is fine, because it is reacting to the change in pressure in the manifold and its probably the IAC valve.
Simple test. Tell us what happens and we'll take it from there.
Kyle
kyledooley is offline   Reply With Quote
Old 03-06-2004, 04:24 PM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
What plugs did you put in?
If Bosch Platinums, that could be it as well.
2000 2.5 rs $10.5 str8jaket Private Vehicle 'For Sale' Classifieds 3 09-23-2007 10:10 PM
FS: 2000 2.5 RS coupe BRP 5 speed 76K miles Phx, AZ LOTS OF PIX JapCarRealGood SWIC Private Classifieds 11 04-27-2007 10:00 PM
FS: 2000 2.5 RS coupe BRP 5 speed 76K miles Phx, AZ LOTS OF PIX JapCarRealGood Private Vehicle 'For Sale' Classifieds 9 04-27-2007 11:49 AM
2000 Impreza L harness same as 2000 2.5 RS? BenBortner Subaru Conversions 7 03-04-2005 01:56 AM
('93-'01) Nagging problems w/ 2000 2.5 RS Coupe michaelu Impreza Forum 10 06-15-2001 11:06 PM
