Old 02-13-2004, 05:14 PM   #1
christianvwcars
Member#: 21644
1998 RS 2.5
Red
Impreza GC8 98 rs calipers w/ wrx rotors and brackets
Does this work.
1998 RS front calipers, convertion to WRX stock rotors.
I believe all I need is the bracket for the WRX calipers and the rotors, am I correct.
I am doing new pads and my friend has stock WRX rotors laying around. I need to buy the caliper mounting brackets if this works.
What is the differance in the rear brakes? Can the same thing be done with the rears?
Christian
christianvwcars is offline   Reply With Quote
Old 02-13-2004, 11:57 PM   #2
FletchMY98
Member#: 6395
2006 WRX STI
Steel Grey Metallic
Christian,
Yes it will defintely work. I just did the exact same mod to my car and am very happy with the results. There's a noticable improvement in brake power. All you need is the caliper brackets, all the hardware gets swapped from your 98 bracket onto the WRX bracket. www.northursalia.com has the whole mod documented.
I opted for a different mod with the rear brakes and went with the turbo legacy vented rear rotors, calipers and caliper brackets. Subaru sells a kit that includes the caliper and bracket all ready to mount up. This is another mod that I'm very pleased with. Its also documented at the web site listed above.
Let me know if you need a set of brackets, I have a pair laying around.
Best Regards,
Chris
FletchMY98 is offline   Reply With Quote
Old 02-14-2004, 10:23 AM   #3
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Your rear rotors and calipers are the same as the WRX. If you want to upgrade get the vented Legacy as above or the larger Legacy "H6" upgrade. You just need rotors and brackets to do the H6 upgrade so it is much cheaper.
oops! since you have a 98 you would need newer style rear calipers to do the H6 upgrade. So it will be quite a bit more $$.
linsavy is offline   Reply With Quote
Old 02-14-2004, 11:18 AM   #4
FletchMY98
Member#: 6395
2006 WRX STI
Steel Grey Metallic
Christian,
I actually have a set of the WRX rear calipers and brackets laying around if you'd like those too.
Regards,
Chris
WTB: RS or WRX brake calipers, rotors and brackets emsmap Private 'Wanted' Classifieds 2 09-29-2009 12:24 AM
Gold Brembos on WRX --- rotor and bracket question ted dibiase Brakes, Steering & Suspension 13 01-21-2009 04:40 PM
WRX Rotors and Caliper Bracket subachad Private 'Wanted' Classifieds 2 10-21-2005 12:36 PM
Does anyone hear want to get rid of their stock WRX rotors and caliper brackets? edkwon Mid West Subaru Owners Club Forum -- MWSOC 4 09-06-2002 11:39 PM
