Welcome to the North American Subaru Impreza Owners Club Tuesday December 23, 2014
Old 02-13-2004, 10:55 PM   #1
jpbpro
Member#: 36155
03 WRX
Platinum on Gold
Default Best way to ~300hp
I rolled about $8000 of negative equity into my rex for reasons I won't go into. Anyways, I would like to get to around 300hp with reliability being priority #1. I understand the increased hp vs reliability equation, so please no preachers. I just want to avoid a blown motor, not worried about losing some life on the clutch. My original plan was the Cobb Stg 2 reflash, tbe, and uppipe. My local dealer says he's not had a good experience with Cobb and has had several destroyed motors. Reliabilty is why I've chosen Cobb, but I tend to give my dealer the benefit of the doubt. He knows a lot more about the car than I do. At the end of the day though, he's a car salesman and every word from his mouth is suspect.
Anyways, looking for some opinions. 275-300 hp at the crank
Have
Greddy Cat Back
Thinking of getting
Cobb Accessport
Stromung dp and 3rd cat eliminator
Perrin or APC Uppipe
Then I want to be done with the engine. I want it to be simple. Reliable, installed, never want to fuss with it. Let me know your thoughts. Let me know if there is a better way.
thx
jpbpro is offline   Reply With Quote
Old 02-13-2004, 11:25 PM   #2
jbtsurf
Member#: 14189
2002 WRX Wagon
vishnu or TXS stage 2. im currently running TXS stage 2.5 and dusted a STi last night. i think the driver was pretty inexperienced cause i launched all over him off the line. anyway ive never dinoed my car but have always assumed it to be running 300hp at the crank.
so you pretty much need:
downpipe/midpipe
engine management
uppipe
boost control(electric preferably)
jbtsurf is offline   Reply With Quote
Old 02-13-2004, 11:50 PM   #3
jpbpro
Member#: 36155
03 WRX
Platinum on Gold
I don't understand the combo of a boost controller and engine management.
The Cobb reflash raises boost to almost the limit of the stock turbo. I assume TXS and Vishnu do as well. Why both? Not saying your wrong. I've seen others doing it. I just don't understand it.
Old 02-14-2004, 12:14 AM   #4
jikhead
Member#: 32535
2009 Nissan 370Z
Monterey Blue
I'm currently running a Cobb Stage 2 with the following: Vishnu uppipe, Bosal downpipe, Stromung midpipe, Bosal catback, Injen CAI, Samco IC hoses, GFB BOV, ground kit, sti shifter, 17" OZ Superleggeras, Pirelli P Zero Neros. Their dyno map says 225whp. There's no AWD dyno in ARK, but I've used a GTech Pro and the high was 221WHP...so pretty much right on. The transmission and flywheel really took a toll last year at drag strip. But these things are going to happy. I'll eventually work on this. I have a new VF34 combo kit coming in next week and plan to put a new Cobb map on that's 320CHP. I'll do another Cobb map in the summer...Stage 3 that's supposed to be 350CHP.
I don't think you can go wrong with any of the WRX tuners that specialize in WRXs...ESX, Vishnu, TurboXS, Cobb. I like Cobb because they are known in SCCA racing and are not just about all out HP mongers. Bigger isn't always better is becoming a common motto of mine when researching my next mod.
jikhead is offline   Reply With Quote
Old 02-14-2004, 02:56 AM   #5
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Cobb stage 2 with a vf3x will be the best bet. They have been around the longest, and are the cheepest. And with the A.port you can do reflashes if you what to change maps and such for free.
And you can go wrong... some of them are just very expencive, I didnt even see any tuning options on esx's website untill you get to thier $999 stage 4.
Old 02-14-2004, 10:50 AM   #6
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
i would suggest something with knock control or monitoring, which a reflash alone will not do. Also if you want 300hp reliably, start with a 257 block + ihi turbo.
el~sharko is offline   Reply With Quote
Old 02-14-2004, 11:04 AM   #7
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
You don't think the 2.0 can make 300 crank reliably?
Zackbo is offline   Reply With Quote
Old 02-14-2004, 11:32 AM   #8
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
i do, but he was asking for the best way, and I was just giving him my opinion. I dont think a usdm wrx in the long run will make 300hp reliably compared to a stock wrx. I mean it also depends on your definition of reliable.
Old 02-14-2004, 01:02 PM   #9
totoherbs
Member#: 7321
.... 122 IggPoints
Ya, I agree that you should have gages, and something to watch the knock.... As for the ej257 yes it would be easyer, but its also going to cost 5 times more just for a short block swap.
Old 02-14-2004, 03:33 PM   #10
z&cobb
Member#: 12344
2002 2JC
blue
I really appreciated the UTEC blinking the CEL at me after getting a bad tank of gas last week (probably 87 octane). Between that and the boost gauge and the ABC, and MMT additive plus 93 BP/Amoco for dilution, it was easy to get back up to 16.5 to 17 psi max after the TXS TMIC.
I believe somewhat over 300 at the crank is OK. It has been OK for 53,000 miles so far. I don't go full bore at full output for too long in the kind of driving I do. I monitor the IC tanks soak temps gauges and use water/alcohol spray in anticipation of a strong pull, if necessary. For example, if the temp at the intake of the snorkle is 50 F, I like the cold tank to be 53 F (with spray) or about 57F without spray. Hot tank temps can be about 87 F under those conditions.
You can't have too many gauges. Oil temp, and volts are nice too.
Real time info is very valuable for keeping the engine happy.
PS: The car has a much better "drivability" factor than when it was stock. I tried to make it as close as possible to my na 300ZX at lower rpms.
z&cobb is offline   Reply With Quote
Old 02-16-2004, 07:45 PM   #11
allanak
Member#: 39856
2011 BMW 135i
Alpine White
jikhead: I don't want to hijack, but are you running a generic stage 2 map or was it tweaked by anyone? Maybe you should get rid of the CAI. I know I'm going back to stock + panel filter once my accessport comes.
Also, totoherbs is probably right. Cheapest and easiest way to ~300hp would be a vf34 and the remap (free with accessport!) to stage 2.5, and then 3.0 whenever thats around.
allanak is offline   Reply With Quote
Old 02-16-2004, 10:51 PM   #12
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
the cheapest way, can be done without a bigger turbo. Remember he said reliability is his number one priority, not bang for the bang value.
Old 02-16-2004, 11:52 PM   #13
totoherbs
Member#: 7321
.... 122 IggPoints
Cobb is the most reliable shop out there... they have been around this long for some dam good reasons.
Old 02-17-2004, 12:08 AM   #14
jikhead
Member#: 32535
2009 Nissan 370Z
Monterey Blue
No I haven't it's the base Stage 2 map. According to Josh, the CAI must come off. I think once I've got the new turbo on w/factory intake...I'm gonna buy a GTech Pro and do some runs with the factory and CAI...see what I get. This is no real dyno but there's not a single AWD dyno in the state.
Old 02-17-2004, 12:30 AM   #15
totoherbs
Member#: 7321
.... 122 IggPoints
Its not so much that they might be worth a few hp but that it will do funny things to the MAF.
Old 02-17-2004, 12:36 AM   #16
03WRXMA
Member#: 35081
2012 WRX
Exactly. The diameter of the pipe is diff. and throws things off. Use the OEM intake and trust Cobb if you go with their reflash
03WRXMA is offline   Reply With Quote
Old 02-17-2004, 12:40 AM   #17
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
also i was trying to make the point, that if your gonna make 300hp on a stock ej205, you can easily do it on the stock turbo.
jpbpro: your best bet is just get an exhaust + EM, that should put you right where you wanna be.
Old 02-17-2004, 01:11 AM   #18
totoherbs
Member#: 7321
.... 122 IggPoints
Ya but at 105% the stocker isnt going to last long.... and with the added heat its putting out its going to take other things with it.
Old 02-17-2004, 07:40 AM   #19
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
hmmm, I guess the cobb stg2 that will get you there doesn't use the stocker for that reason.
Old 02-17-2004, 02:30 PM   #20
totoherbs
Member#: 7321
.... 122 IggPoints
Yup, vf30/35...
Old 02-17-2004, 06:26 PM   #21
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
Yup, vf30/35...
so I'm assuming they just haven't updated their webpage with the new change to their stage2 package that you speak of?
Old 02-17-2004, 06:33 PM   #22
totoherbs
Member#: 7321
.... 122 IggPoints
AE-WRX-VF34-91
VF34 Map
Requires VF34, STI Injectors
Turboback Exhaust, Uppipe
STOCK Intake and Intercooler 315HP / 295 ft-lbs 91 octane 1.04
http://cobbtuning.com/wrx/accessecu.html
and its 34/30 my bad...
Old 02-17-2004, 06:33 PM   #23
allanak
Member#: 39856
2011 BMW 135i
Alpine White
From http://cobbtuning.com/wrx/accessecu.html
Description: VF34 Map - Requires VF34, STI Injectors, Turboback Exhaust, Uppipe, STOCK Intake and Intercooler = 315HP / 295 ft-lbs @ 91 Octane (320/300@93 Octane)
Same numbers given for the VF30....No dyno graphs to speak of for this specific map on Cobb's site, however.
Old 02-17-2004, 06:40 PM   #24
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
Yup, vf30/35...
When you said this, you made it look like you were saying the vf30 came with their stage2. I was a little confused.
Old 02-17-2004, 06:45 PM   #25
02WRX_BLUE
Member#: 13704
2006 EVO MR
Apex Silver
[quote]Have
Greddy Cat Back
Thinking of getting
Cobb Accessport
[quote]
May I suggest "Helix Downpipe and PERRIN uppipe with out EGT bung to complete the TBE... The bell mouth of Helix is nicely casted that it should last longer than the SS only downpipes...
Then, You should get "VF34 or VF30" turbo along with "STI PINK Injector", "Walbro Fuel Bump", & "UTEC (Biased since I had UTEC and loved every option it had)" ..
Tune it and you should be happy..
I don't think STOCK injector could provide reliability even if you could get up to 300 crank HP..
When I had 02 WRX, my stock injector's IDC was 85 to 95 running 16.5 PSI using 93 OCT with stock turbos...
Just my 2 cents..
02WRX_BLUE is offline   Reply With Quote
Best Way to Splice To Add Length to 8 gauge Amp Power Wire This Is Not Mike Car Audio, Video & Security 20 07-13-2008 10:52 AM
Whats the best way to make my 2002 have 300hp? 2002bugeye Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 11-04-2005 08:46 PM
Best way to get around 300hp vica153 Subaru Conversions 4 03-29-2005 01:08 PM
Rally mudflaps. Best way to attach them to the body?? Rallyspec Motorsports 10 06-27-2002 04:32 PM
Best way to get to Myrtle Beach SC IMPREZIV Tri-State Area Forum 13 06-17-2002 09:14 PM
