Welcome to the North American Subaru Impreza Owners Club Sunday October 4, 2015
Old 02-13-2004, 10:32 PM   #1
Member#: 49550
2000 Impreza 2.5 RS
Blue Ridge Pearl
Default Foglight keeps shorting out, please help!
my drivers side foglight went out 2 weeks ago, i replaced the bulb on sunday, feb 8, was working all week, then, it shorted out again, on feb 13, is there anyway i can fix this myself? i want to avoid a mechanic at all costs if possible please help
Steroid500 is offline   Reply With Quote
Old 02-14-2004, 04:46 PM   #2
Member#: 13282
2007 FXT
WRB SPB Edition
Silly question... By any chance did you touch the bulb when replacing it?
Normally a short in the system will blow the fuse before it blows the bulb. On the other hand you might wanna check and make sure you don't have an intermittent connection. Use a volt meter to make sure you have power and ground at the bulb, if you don't wiggle the wires(might be easier with a friend) and see if voltage appears. If you have voltage then maybe you got a faulty bulb from the store or accidentally touched it when replacing it, that'll shorten the bulbs life quite a bit. When the bulb heats up the oils from your fingers damage the bulb.
EvasionOfTruth is offline   Reply With Quote
Foglight Fuse shorting out drigo Electrical & Lighting 10 11-28-2009 03:05 PM
Car keeps cutting out/stalling help? STizzIE Pre-2002 Factory Turbo Powertrain 16 04-28-2009 06:40 PM
04 wrx Left foglight keeps burning out?!?!? NITROS Electrical & Lighting 8 12-13-2005 10:12 AM
Header Studs keep backing out, please help STiShawn Normally Aspirated Powertrain 4 09-21-2001 09:24 PM
