Old 02-14-2004, 10:40 AM   #1
CurlyPete
Member#: 38658
2000 RS-T
Impreza GC8 Link + Tuning Issues
So I've been running a Ludespeed Stage III kit in my 2000 RS for about two months now. It drives nicely and all, boost set at 7psi (I'm at 7000ft elevation so I can easily get away with this). But one problem is I know the car is running a little rich. About every three weeks or so, I have to change the spark plugs because they are fouled. The engine can often get flooded because it gets so damn cold here and I am too dumb to stop cranking the engine. I need some help on the cold start, cold enrich, or whatever you believe is the problem. I can't seem to load a datalog of mine cuz the formatting changes and it is illegible. If anyone has suggestions, let me know. Thanks!
CurlyPete is offline   Reply With Quote
Old 02-17-2004, 12:39 PM   #2
Greenracer6
Member#: 7962
08 335i TwinTurbo
PSM 02WRX, 97 Dipped CRV
Default ...
Which version do you use??
values or percentage changes?
What size injectors/ timing around idle? Idle rpm?
What values do you have as your ::
crank enrich?
coldstart?
hot-restart?
clamp?
overrun vac?
Bill -- fellow tuner
Greenracer6 is offline   Reply With Quote
Mechanical Issue or Tuning Issue? (Bucking/Hiccups) MConte05 Open Source Reflashes 6 06-30-2009 12:51 PM
Link TPS issue FJP Normally Aspirated with bolt-on Forced Induction Powertrain 3 11-09-2003 02:57 AM
WTB locally: laptop for Link tuning wcbjr Texas Impreza Club Forum -- TXIC 8 11-01-2002 02:41 PM
LINK tuned and running good finally- just need to break in the clutch redmeanie Normally Aspirated with bolt-on Forced Induction Powertrain 0 08-17-2002 10:47 PM
Link tuning thoughts/questions phast Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 46 03-19-2002 03:59 PM
