Old 02-14-2004, 10:45 AM   #1
Kobiyashi
Member#: 53318
Default Quick Question
Do normal knock a little when tuning???
What AFR should I run on 93 octane?
Should I lower boost and raise timing above 19-22 5k-7k, @ 17psi, or should I Raise boost and lower timing even more?
I don't feel like I have the HP gains for this setup that I should but knock is rather limiting me to anything, back of 2 degrees when I hit it.
Vs. an STi we are only talking about 2-3 car lengths from 20mph rollon to 80. I feel as if it should be better than this; should it?
---- TIMING MAP ----
[-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100]
[-100] [-100] [-100] [-100] [-100] [30] [30] [19] [16] [15] [12]
[-100] [-100] [-100] [-100] [-100] [27] [27] [19] [16] [15] [12]
[-100] [-100] [-100] [-100] [-100] [24] [24] [19] [16] [15] [12]
[-100] [-100] [-100] [-100] [-100] [22] [22] [18] [16] [15] [12]
[-100] [-100] [-100] [-100] [-100] [19] [19] [17] [16] [15] [12]
[-100] [-100] [-100] [-100] [-100] [17] [17] [16] [16] [15] [12]
[-100] [-100] [-100] [-100] [-100] [17] [17] [17] [16] [15] [13]
[-100] [-100] [-100] [-100] [-100] [18] [18] [17] [17] [16] [14]
[-100] [-100] [-100] [-100] [-100] [18] [18] [18] [17] [16] [15]
[-100] [-100] [-100] [-100] [-100] [20] [20] [19] [18] [17] [16]
[-100] [-100] [-100] [-100] [-100] [22] [21] [20] [19] [18] [17]
[-100] [-100] [-100] [-100] [-100] [22] [22] [20] [19] [18] [18]
[-100] [-100] [-100] [-100] [-100] [22] [22] [20] [20] [19] [18]
[-100] [-100] [-100] [-100] [-100] [22] [22] [21] [21] [20] [19]
[-100] [-100] [-100] [-100] [-100] [23] [23] [22] [22] [21] [19]
[-100] [-100] [-100] [-100] [-100] [23] [23] [22] [22] [21] [20]
[-100] [-100] [-100] [-100] [-100] [24] [24] [22] [22] [21] [20]
[-100] [-100] [-100] [-100] [-100] [25] [25] [23] [23] [21] [20]
---- Current AFR is 10.8-11.1:1, should I richen more for timing and boost?
Thanks
TXS UP
TXS TBE (Catless)
STi Injectors
Perrin Rails
Walboro Pump
FPR Mod
VF 22
Perrin FMIC
Perrin Short Ram
-kobi
Kobiyashi is offline   Reply With Quote
Old 02-14-2004, 02:36 PM   #2
kenchan
Member#: 15106
besides your map that 20mph roll is one of your primary problem.
the wrx just does not do well from a rolling start especially
from 20-30mph which is between top of 1st and bottom of
2nd gears.
kenchan is offline   Reply With Quote
Old 02-15-2004, 02:44 AM   #3
Kobiyashi
Member#: 53318
Not just that, I was using that as an example...
Any other input would be much appretiated.
-kobi
Old 02-15-2004, 02:28 PM   #4
mandrOid
Member#: 18681
JDM VER8 STi Wagon
*** TEAM BLEW RACING ***
You can only squeeze so much power from making timing changes.
You map looks pretty but there is room for improvement early on (10-50% @ 2000-3500 RPM). Without a log that map doesn't say much.
A way to tackle knock is to look at the value the stock ECU was attempting to make and go from there. I run anywher between 7-12 degrees of advance from that value. Start with +3 and adjust as you can.
I've read a few of your posts and can only suggest using MS Excel to plot where in your map the car is hitting when you test; and knock. That will show you how little of the map you use normally and where you need to make changes. I suggest using one spreadsheet for multiple pulls.
Example (one of my first conservative maps):
mandrOid is offline   Reply With Quote
Quick Quick Question! J-Chow Normally Aspirated Powertrain 3 06-11-2006 07:31 AM
quick quick question for .. yub2da Brakes, Steering & Suspension 3 08-15-2005 12:58 PM
Quick question and I need a quick reply imprezive General Community 6 12-04-2001 08:44 AM
Help, need quick answer to quick question about ezpass munkis General Forum Archive 2 09-29-2000 03:45 PM
Message Board Statistics All times are GMT -4. The time now is 12:37 PM.
