Old 02-14-2004, 01:22 PM   #1
filbert
Member#: 39661
2004 WRB WRX STi
07 OBP FXTS
Default can't get to grommit in firewall for amp power cable.
Alright, I've done a search and I've found some pictures but it looks like the hole in the firewall is right behind the intercooler and there so many lines and cables in there that I can't see anything, and even if i could I wouldn't be able to reach it.
I tried accessing it from the inside as well and found what looks like the entry point right above the gas pedal, except i can't punch a hole through the cover. Is that the right spot? Do I just need to stab it real hard to get through it?
Any tips? Are these the right access points???
Oh, i'm in an STi if that makes a difference...
filbert is offline   Reply With Quote
Old 02-14-2004, 01:25 PM   #2
filbert
Member#: 39661
2004 WRB WRX STi
07 OBP FXTS
Nevermind, i figured it out. there's two circles... one high above the gas pedal... and one right behind the brake pedal... the one behind the brake pedal is the correct one since the plastic cover comes off and there's rubber behind it... I ended up jacking the car up and crawling under and then you can find the hole pretty easily. I'll post better pics for everyone when i'm done.
Old 02-14-2004, 09:31 PM   #3
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
the higher-up one you have to remove the plastic trim around the wiper blades to access.
nhluhr is offline   Reply With Quote
Old 02-18-2004, 03:24 PM   #4
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Any tips?
Remove the intercooler. Half a dozen screws and it's out. Then you'll have plenty of room to work.
Jon Bogert is offline   Reply With Quote
Where to draw the line for amp power? RootUsr Car Audio, Video & Security 7 04-13-2010 02:15 PM
Amp power cable next to Sat radio antenna cable?? Jsunn Car Audio, Video & Security 2 12-12-2009 07:17 PM
Where to run amp power cable from engine to cabin? sgrassbaugh Car Audio, Video & Security 7 06-17-2006 11:44 AM
Where to run amp power cables through firewall ? Mops Legacy Forum 7 10-24-2002 08:18 PM
Where can I get a good guide for running an amp power cable? Schleppy Car Audio, Video & Security 3 03-27-2002 06:19 PM
