Old 02-01-2004, 03:32 PM   #1
Rally1
Member#: 20633
Question Dirty air filter, photo, please advise.
Changed my filter today (finally), and it looks pretty nasty:
That's at 20,000 miles. I have the "snorkle" removed.
The new (stock) filter is more yellow than red.
I presume I should have changed it a lot earlier? Maybe evey 10k from now on?
Rally1 is offline   Reply With Quote
Old 02-01-2004, 03:39 PM   #2
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
At least you can tell what color it started out as..... I have seen worse.
Old 02-01-2004, 03:54 PM   #3
Rally1
Member#: 20633
Well the car goes into the dealer tomorrow to try to get the clutch shudder fixed, and warranty my front brakes. So i figured i'd take care of everything else, lest they are tempted to do it and charge me for it!
Old 02-01-2004, 04:02 PM   #4
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Keep in mind that a dirty air filter will filter out more dirt than a clean air filter.
Subaru (IIRC) recommends 30k between air filter changes.
You can't hurt anything by not changing the air filter soon enough or too often, although performance and gas mileage may slightly degrade if it really gets clogged.
Someone out there sells a gauge which you can install into the airbox which measures the pressure drop after the filter vs atmo pressure and lets you know when the filter really gets clogged. This is the best way to know when it's time to change the filter. Filter Minder I've been thinking about trying one myself, but not sure where to buy one.
drees is offline   Reply With Quote
Old 02-01-2004, 04:56 PM   #5
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
Ah, yeah, that may be, but nor will it let in as much air as a clean filter. I don't' think that's necessarily a good trade off.
heffergm is offline   Reply With Quote
Old 02-01-2004, 07:28 PM   #6
InfamousDX
Member#: 25413
I thought Subaru recommended every 30K to change the air filter but my dealership sent me a reminder for 15K mile service and on the list of things to be done it said air filter... so beats me.
InfamousDX is offline   Reply With Quote
Old 02-02-2004, 12:31 AM   #7
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Well, at least they're relatively cheap. $5 or so from the autostore, a little more if you get the genuine subaru filter.
Psydotek is offline   Reply With Quote
Old 02-02-2004, 10:19 AM   #8
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
When I used paper filters, I changed them every 15k. With the K and N, I clean it every 10k or so.
Brian
North Ursalia is offline   Reply With Quote
Old 02-02-2004, 12:06 PM   #9
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
Mine looked worse. Remember that we had a couple little fires in November that have thrown soot in the air for the last few months.
Coati is offline   Reply With Quote
Old 02-03-2004, 05:11 AM   #10
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
As noted, they're cheap and easy to change, and perform an important function, so why not change them every year/15k? My local independent Subaru mechanic also suggests changing the air filter every year, and they definitely don't push extra work.
armand1 is offline   Reply With Quote
Old 02-04-2004, 01:39 AM   #11
esteve
Member#: 28716
2006 STI
That applies to K&N type filters, but I don't think paper ones since they don't rely on oil for filtration and have smaller passageways.
I changed mine at 10K miles because of the fires too (otherwise I would've done it later), and some sections had a black, sooty residue.
I just use the Purolater ones from Pep Boys, pretty cheap and high-quality.
esteve is offline   Reply With Quote
Old 02-05-2004, 09:41 AM   #12
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Impreza GC8 looks fine
It really looks fine. You could go longer, perhaps 30k miles. The current Subaru change interval is 60k miles. Of course, it depends were you live, as some areas are much more dusty than others. But yours looks fine.
The new yellow OEM filters are excellent! They are oiled paper filters and are of much higher quality than any aftermarket filter I have seen.
vvk is offline   Reply With Quote
Old 02-13-2004, 01:12 PM   #13
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
The manual says 30k, unless you have lot of dust etc.
They are not easy to change either, at least on the 02/03 WRX.
Mike Wevrick is offline   Reply With Quote
Old 02-13-2004, 01:43 PM   #14
Rally1
Member#: 20633
Are you saying the air filter is hard to change on the WRX? It' s very easy, and a lot easier than the one on the Talon.
Old 02-13-2004, 02:39 PM   #15
Mike Wevrick
Member#: 24654
1957 Taggart Comet
Yes; on my 03 there is a ton of stuff attached to the top of the housing that gets in the way and makes it tough to open and especially to close.
Don't know about Talons but its certainly a lot harder than my previous Subies.
Old 02-13-2004, 02:49 PM   #16
Rally1
Member#: 20633
Be thankful you dont have a DSM then! You have to dissconnect IC pipes and hoses, and pullout the whole airbox to get at the filters on the those Mitsu 2.0's.
Old 02-14-2004, 07:24 PM   #17
hys420
Member#: 18315
2008 STI ON ORDER
DGM - STILL WAITING!!
Lightbulb
Put in a K&N filter... never needs changing, and clean once every 50k miles, and you also get about 2% improved airflow.
(edit: heh K&R.. too much programming for me!)
hys420 is offline   Reply With Quote
Old 02-15-2004, 09:20 AM   #18
kenchan
Member#: 15106
oh, thought the K&N's need to be cleaned once every 30k miles.
I pulled mine out the other day and it looked pretty clean.
(at 25k miles).
kenchan is offline   Reply With Quote
Dirty Air filter? Tony_Montana87 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 11-06-2008 06:42 PM
Need local help/advise re. air filter & stalling problem Impreza911 Vancouver Impreza Club Forum -- VIC 3 05-26-2005 09:49 PM
Air filter being dirty? antny Texas Impreza Club Forum -- TXIC 22 08-03-2004 03:16 PM
Photo Printers- Please advise HekWRX Off-Topic 18 11-14-2002 01:00 PM
Yeah, my air filter got dirty (part one) Bankheist Texas Impreza Club Forum -- TXIC 11 10-31-2001 05:06 PM
