Old 02-14-2004, 03:30 PM   #1
Twerthi
Member#: 30207
2005 Lotus Elise
Magnetic Blue
Default Free 740cc injectors flow test report from RC Engineering
I think you'll find the report interesting
Twerthi is offline   Reply With Quote
Old 02-14-2004, 03:40 PM   #2
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
So they are actually 850's and not 720's??????
jigga is offline   Reply With Quote
Old 02-14-2004, 04:02 PM   #3
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Need4Boost is offline   Reply With Quote
Old 02-14-2004, 04:45 PM   #4
eightballrj
Member#: 18520
2005 L GT Limited
Ok, there is no way that everyone is having good luck with these having one set that flow around 740cc's and another that flows 850cc's. So, either someone did one of the tests wrong or these injectors are not as consistent as everyone might have thought. Whats the deal??
RJ
eightballrj is offline   Reply With Quote
Old 02-14-2004, 05:06 PM   #5
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
Awesome post, Twerthi!
From my own personal tuning efforts, I'm not surprised at the results.
Says it was performed @ 43psi test pressure.
They listed the spray pattern as excellent
Zackbo is offline   Reply With Quote
Old 02-14-2004, 05:12 PM   #6
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
lets just hope that there is nobody that has 2 that flow 850cc and 2 that flow 740cc!! YIKES! that would suck, i hope mine are all even....oh well, F*** it, too late now!
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 02-14-2004, 05:18 PM   #7
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
Jeff
yep...too late now, i aint reinsatlling and retuning again...
Kwyjibo is offline   Reply With Quote
Old 02-14-2004, 06:18 PM   #8
02R6
Member#: 22157
'02 WRX '04 350Z
Cause We Are The Aquateen
Wow, good to know. Thanks a lot. (I'm still going to send mine in to make sure they're flowing evenly and the pattern is good.)
02R6 is offline   Reply With Quote
Old 02-14-2004, 06:31 PM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Perhaps you guys should start posting the numbers off of the injectors to compare with others' results. Might just be a simple design change between years that causes this difference.
Old 02-14-2004, 07:28 PM   #10
Twerthi
Member#: 30207
2005 Lotus Elise
Magnetic Blue
I was rather shocked when I looked at the report. These came from a 2002 WRX and the modifcations were performed by nhluhr (which he did an awesome freakin job, they look very very clean, almost as if there weren't any modifications done)
Old 02-14-2004, 07:56 PM   #11
gpatmac
Member#: 18446
2002 WRX wagon
psm
Hmmm, I wonder why I'm seeing between 11.1:1 to 10.6:1 at WOT but up to and over 100% IDC's. I'm going to have to take another look at what I'm doing.
gpatmac is offline   Reply With Quote
Old 02-14-2004, 08:07 PM   #12
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
were the original ones that got flowtested the STI pinks?
nhluhr is offline   Reply With Quote
Old 02-14-2004, 08:11 PM   #13
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
I doubt someone would end up with half and half, as im sure the injectors are made in batches and all come from the same bin along the assembly line
GMTarkin is offline   Reply With Quote
Old 02-14-2004, 08:28 PM   #14
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
Wow. Good work. Very interesting results. We have not seen a set flow test that high. Nice to see that the pattern is excellent and that they are all in the same range. Would like to see some more tested. Thanks.
Kingpin is offline   Reply With Quote
Old 02-14-2004, 11:05 PM   #15
Leonardo
Consigliere
Super Moderator
Member#: 185
2009 Civic EX
Holly isht!
Leonardo is offline   Reply With Quote
Old 02-15-2004, 07:31 AM   #16
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
Did you mod the stock injectors or the pinks?
I had my stock modded by DarthChicken and his guy also flow tests them before sending them back. Ours check in at roughly 740~CC (stock blues).
Old 02-15-2004, 08:29 AM   #17
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
Were'nt the others flow tested at like 30psi?
That would explain the difference, down to like 10cc's.
If an injector flows 740cc's @ 30 psi, then it should flow approx. 850cc's @ 43psi.
Old 02-15-2004, 01:25 PM   #18
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Yup, gotta be different test methods. The difference between the injector flows is SO low (less than .06%) that nothing else really explains it.
gpatmac - 100% at 11:1? My god man, what turbo/engine your running? I see no more than 72% at 23psi at 8000rpm!
DarthChicken is offline   Reply With Quote
Old 02-15-2004, 02:27 PM   #19
Twerthi
Member#: 30207
2005 Lotus Elise
Magnetic Blue
The ones I had tested were stock blues, not the STi pinks.
Old 02-16-2004, 03:09 AM   #20
gpatmac
Member#: 18446
2002 WRX wagon
psm
I apologize. I'm in the 10:1 area. I still don't think I should be seeing 90-100% IDCs, though.
2.5L block, 02 WRX heads, 740's, Green turbo, FMIC.
my log (.xls)
Old 02-16-2004, 04:30 AM   #21
eightballrj
Member#: 18520
2005 L GT Limited
no way.... thats damn near 3500cc/min of fuel total if the above report is correct.... no way you are maxing 800cc+ of injector with that setup.
Richard
Old 02-16-2004, 04:44 AM   #22
Wzcb08
Member#: 28062
Wzcb08 is offline   Reply With Quote
Old 02-16-2004, 05:08 AM   #23
gpatmac
Member#: 18446
2002 WRX wagon
psm
I don't know what to think. I'm convinced that I'm doing something wrong or am overlooking something. Some other areas that I am or will be troubleshooting are in this thread
I need to make myself a fuel pressure checker.
While I'm updating everyone on my experiences with the 740 stockers, don't assess my experience to be universal. There's something wrong with my setup that is causing my injectors to behave funny (also note how they're behaving for me in 1st gear).
Old 02-16-2004, 05:12 AM   #24
gpatmac
Member#: 18446
2002 WRX wagon
psm
Hey eightballrj,
Your setup is similar to mine. Have you had any similar experiences to mine like what I'm posting in the other thread? Hopefully not.
Old 02-16-2004, 11:21 AM   #25
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
AF meters get inaccurate down around the 10-10.5 AFR range and even though you're dumping fuel, they still can say 10.8:1 or so. I had this problem with a car I was tuning that was running into a fuel wall at 10.8:1... I pulled 15% of fuel out and it still read the same AFR. Took another 5-10% before the fuel wall was gone and it actually came up to about 11:1, IIRC.
06 WRX injectors flow tested at RC at 560cc blinguskahn Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 38 03-09-2006 08:53 PM
injectors cleaned flow tested other then rc engineering... AaronWRX Engine Management & Tuning 7 07-10-2005 12:22 PM
Another Flow Test Report from RC Engineering for The "Free Injector Mod" 02R6 Engine Management & Tuning 52 08-20-2004 10:41 PM
Free 740cc injectors flow test report from RC Engineering -- The re-test Twerthi Engine Management & Tuning 24 03-21-2004 03:27 AM
Free 740cc injector flow test report from RC Engineering Twerthi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-14-2004 03:31 PM
