Old 02-14-2004, 08:57 PM   #1
brokemypiston
Member#: 31209
2000 GC8
Default Anyone ever see this with gas filled bulbs?
I might be off on this, but has anyone noticed that gas filled bulbs that are non HID will begin to get dimmer over time. I've had these headlight bulbs for about 3 months now, and am beginning to think they're a bit dimmer than they used to be. Anyone ever see this problem?
brokemypiston is offline   Reply With Quote
Old 02-14-2004, 10:28 PM   #2
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
if by "gas filled bulbs" you mean every single bulb that's ever been manufactured, then yes, it happens.
But more likely what is happening in your case, the connectors between the bulb and socket are getting some corrosion on them and that's limiting current and causing a voltage droop. Clean the connectors and apply some of that grease to seal them and keep them clean.
-Nick
nhluhr is offline   Reply With Quote
Old 02-15-2004, 02:24 AM   #3
brokemypiston
Member#: 31209
2000 GC8
what type of grease?
Old 02-15-2004, 01:40 PM   #4
redcoupe
Member#: 27233
2003 wrx
Sedona red
White, die-electric grease.
redcoupe is offline   Reply With Quote
Old 02-15-2004, 05:52 PM   #5
brokemypiston
Member#: 31209
2000 GC8
and actually, on that note, I thought all halogen bulbs were vacumed and xenon were the ones that were gased. might be wrong on this
Old 03-06-2004, 10:40 AM   #6
topdaytrader
Member#: 26666
2002 Porsche 996TT
Black/Black
topdaytrader is offline   Reply With Quote
Old 03-06-2004, 11:09 AM   #7
redwagon
Member#: 2181
2008 SpecB
It's been a few years since I looked at the periodic table, but IIRC xenon is in the class of the halogen or inert gases. So are argon, neon, helium and a couple others I can't remember now. Xenon has been used in bulbs and strobe lights for a very long time. It's easier to fill a bulb with a gas that doesn't allow the filament to burn than it is to try to evacuate it, plus the envelope doesn't have to be as strong
redwagon is offline   Reply With Quote
Old 03-06-2004, 02:56 PM   #8
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Halogen and incandescent bulbs both get dimmer as they get older. The filament material burns off and condenses on the outside of the bulb. This is one of the reasons people think blue-coated bulbs are better than standard halogens -- they replace their old bulbs with these substandard new bulbs but still get more light in the end.
It happens much less with halogens if they're run clean and at the proper voltage, though; the halogen cycle allows the material to recondense on the filament.
3 months shouldn't make a big difference, though... If you are for some reason feeding them too low a voltage or if they're dirty you should rectify that by cleaning the contacts however you like and by cleaning the bulbs with isopropanol.
Oh, and all halogen bulbs have some xenon in them.
vrg3 is offline   Reply With Quote
Old 03-07-2004, 05:50 AM   #9
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Originally posted by topdaytrader
uh. . . doing a little bit of illegal advertising on the forums, are we? BAN!
http://forums.nasioc.com/forums/sear...earchid=696547
Old 03-07-2004, 11:08 AM   #10
redwagon
Member#: 2181
2008 SpecB
How does coating the glass envelope of the bulb a blue color make it brighter? I would have thought any kind of filter would make it dimmer rather than brighter...
Old 03-07-2004, 12:34 PM   #11
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
redwagon - You're right. Seems motionr's customers aren't as "bright" as you.
Sorry, couldn't resist.
Old 03-07-2004, 03:31 PM   #12
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
Bingo! This is something nobody seems to understand.
Samirr76 is offline   Reply With Quote
Old 03-07-2004, 11:33 PM   #13
redwagon
Member#: 2181
2008 SpecB
Just found D. Stern's site. Mystery solved
anyone ever see this video? chrisc75 General Community 54 01-20-2010 11:00 AM
Anyone ever see this? silverscooby02 Transmission (AT/MT) & Driveline 20 03-31-2007 01:48 AM
Push Nevada..anyone ever see this? Keith Off-Topic 2 08-29-2006 12:31 PM
Anyone in Denver ever see this car? glilly Rocky Mountains Impreza Club Forum -- RMIC 8 08-18-2004 12:21 PM
Anyone ever see this spoiler before? Tomnel Member's Car Gallery 35 05-03-2003 03:56 PM
