Old 02-14-2004, 11:58 PM   #1
smacksube
Member#: 4067
01 2.5 rs
Default tec-3, anyone running it?
i need to get another tec style ecu, with it's own coil packs, so i was looking at the tec-3. it says something about autocalibrated baseline maps to get the car initially running. is it really that easy? any info would be great, for some reason i can't find writeups or reviews on the tec-3. thanks
smacksube is offline   Reply With Quote
Old 02-15-2004, 09:04 PM   #2
Boxologist
Member#: 21118
pretty rare still. iirc, rs22b has one and Nino from Nino's autoaccessories sold me his(in car at the end of the summer).
Boxologist is offline   Reply With Quote
Old 02-16-2004, 01:47 PM   #3
jdk
Member#: 26114
06 rs
Did you have a tec2? If so use a calibration file as a reference(mainly for advance and basic fuel enrichments) then let the wizard pick your UAP(TOG) by giving the wizard calibrater the appropriate info. Then double check the style of map sensor you have (new/old) by going into advanced settings and looking at the real time kpa reading. My sensor was about 5 kpa lower then my tec2 was. Should be good to fire up and auto tune the VE table. (this is what I did anyway) I also always have a timing light to double check its referenced off the correct trigger wheel tooth...Hope this helps
jdk is offline   Reply With Quote
Old 02-16-2004, 08:14 PM   #4
batmanalan
Member#: 37583
haha i like the title,"tec-3, anyone running it?"
samuel L jackson voice- "english, do you speak it?"
batmanalan is offline   Reply With Quote
Old 02-16-2004, 11:15 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i am running a tec 2 on a motor identical to what you are installing ..
only issue is that the tec 2 won't control the subaru idle air control motor.. which is an issue when you live in a climate where there is radical tempature changes -15 to +115
although the tec 3 might
Old 02-17-2004, 01:45 AM   #6
luvmyrs
Member#: 1048
2000 Nothing, thanks
to POS thieves.
Yes the tec 3 controls the IAC motor. I Have TEC2, and as Jaxx said the IAC control would be a good thing. I currently have the stock ECU running the Idle and it seems to be doing pretty well.
luvmyrs is offline   Reply With Quote
Old 02-17-2004, 12:15 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i have considered buying a tec IAC and plumbing it in ..ugh ...
Old 02-17-2004, 07:08 PM   #8
luvmyrs
Member#: 1048
to POS thieves.
cuase if you do that, your gonna have to change everything else.
Old 02-18-2004, 05:42 AM   #9
ChAi
Member#: 1277
1999 Minnam Stage 2
Cobb Stage3 engine, TEC3
what MAP are you useing?
ChAi is offline   Reply With Quote
Old 02-18-2004, 03:56 PM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
jared's map .. i couldn't find anything close so it is 100 tuned by me..
mmm no .. the ej20G has the devorced IAC (w/ a one way valve) its not in the throttle body. so i could simply connect it down stream of the throttel plate and and give it its own air filter.. proublem is finding the correct one..
Old 02-18-2004, 08:12 PM   #11
smacksube
Member#: 4067
01 2.5 rs
sorry it wasn't coherent enough for you? everyone else understood what i was asking? dumbass....
anyhow...thanks everyone for responding. I wasn't planning on running this with the ej20g, but with my ej25. I still have most of the sensors from my tec-ii, so i can use those for the tec-3. But my main question/problem is...do the ends justify the means? lol
is the $1900-2200 i'll be spending make it THAT much better than a tec-ii. I'm looking at getting another tec-ii unit for 950 including plug wires and sensors. f
Old 02-19-2004, 11:08 AM   #12
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
is short words
is the tec 3 a $1000 better than a tec 2
yes
espically with wintec 3.1
Old 02-19-2004, 12:23 PM   #13
bullseye17
Member#: 16661
1997 Outback
Green
Ron at axis power just built a car with one...
bullseye17 is offline   Reply With Quote
Old 02-20-2004, 08:20 PM   #14
smacksube
Member#: 4067
01 2.5 rs
Originally posted by Jaxx
is short words
yes
ahh,don't be sad....lol..thinking more and more about it and looking at all the wintec 3.1 differences it looks like it's way more than $1000 better when you consider all the options. extra GPO's, reliability, and tuning.
Old 02-21-2004, 08:35 PM   #15
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
im sad as some one sold a tec 3 kit on nasioc for the same price i paid for my tec 2 kit
Old 02-21-2004, 08:49 PM   #16
smacksube
Member#: 4067
01 2.5 rs
ah damn....was it the full kit or just the tec-3 ecm. There all over ebay for 1500, but that doesn't include sensors, power harness, wiring harness, plug wires or the DFU. So by the time you add all that together it comes out to around the 2300 it retails for.
Old 02-22-2004, 10:22 PM   #17
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
was 1000 for the kit
Old 02-25-2004, 09:31 AM   #18
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Eric, I have an Idea, call me at the number I PM you with!
It's to your advantage.
latinskllz is offline   Reply With Quote
Old 02-26-2004, 06:08 AM   #19
Delicious Tuning
Member#: 1990
My question is why are you running a Tec in the first place? Do you have major modifications to the RS? As there are solutions coming out soon for the RS, that will take care of all these issues everyone is having.
Though if you know it well, and are planning major modifications it might be worth keeping.
Cheers,
Bill Knose
I-Speed USA
Delicious Tuning is offline   Reply With Quote
Old 02-27-2004, 11:30 AM   #20
Section 8
Member#: 821
Mine is closet mounted right now. I posted a while back to see if anyone was running it full stand alone. I am trying to decide weather or not to do it all at once, or leave the stock ECU in there for a while for ease of things (instead of having to "tune" EVERYTHING right off the bat).
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 02-28-2004, 11:18 AM   #21
Z1 Performance
Member#: 9327
The III is light years ahead of the II in every possible regard, and still our personal favorites in terms of bang for the buck and ease of use.
Z1 Performance is offline   Reply With Quote
Old 02-28-2004, 01:22 PM   #22
luvmyrs
Member#: 1048
to POS thieves.
I agree with Adam on this one. Ive seen RS22B's tec3 and the features are great. ALOT more on-fly features. and the 16x16 maps are great. Not to mention the ability to do individual cylinder fuel trims. drooooool...
Forza 3, anyone "beaten" it yet? bulgarianfreak55 Off-Topic 1 12-28-2009 03:25 PM
B&M Trick Shift transmission fluid...anyone running it? kaisersouse Transmission (AT/MT) & Driveline 3 07-29-2005 08:59 AM
42 offset 17x7 rims. Anyone running it? Have any issues? SinhCredible Tire & Wheel 5 04-03-2004 11:05 PM
anyone running a tec? subiekid Normally Aspirated with bolt-on Forced Induction Powertrain 6 10-18-2003 10:23 PM
Has anyone heard to much about the TEC 3? E'scubi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-16-2001 10:24 AM
