Old 02-15-2004, 03:33 PM   #1
Odin
Member#: 25428
2005 STi
Default Tire pressure guage, is this right?
I bought a roadmedic tire pressure guage from autozone awhile ago. I can't find the package it came in. Does this need to be calibrated?
I just filled my tires (Yokohama 420's) up with my home air compressor (a $15 job from wherever) and they seem to be alright by the looks of it. No bulge in the back and little bulge in the front. I filled the front tires up to just shy of 35 psi (hard to tell w/ this compressor's gauge), but my new gauge is reading 8-10 psi lower. I don't want to blow my tires up. Anyone had this issue before?
Thanks.
Odin is offline   Reply With Quote
Old 02-15-2004, 03:41 PM   #2
Karl
Member#: 13110
You can't tell by the "look" of tires whether they are properly inflated or not.
And the gauge on your compressor is probably not very accurate.
How about a cheap pen type slide gauge? Try comparing the reading of that with your new gauge.
Karl is offline   Reply With Quote
Old 02-15-2004, 03:52 PM   #3
Odin
Member#: 25428
2005 STi
I'll give it a shot. Thanks.
Old 02-15-2004, 06:50 PM   #4
Odin
Member#: 25428
2005 STi
Well, the crappy compressor really was about 10psi off. Went to a gas station with a compressor w/gauge and it was much closer to my new gauge. So I've been driving around on some seriously deflated tires. I guess I like to learn the hard way.
Old 02-15-2004, 08:06 PM   #5
BryanH
Member#: 993
Go to target and buy a digital gauge by accutire. They are awesome and cheap. The pen slide type gauges get out of spec very easy.
BryanH is offline   Reply With Quote
Old 02-17-2004, 11:47 AM   #6
Orson
Member#: 25254
2003 WRX wagon
Those pencil gauges are unfairly trashed. Consumer Reports did an extensive test of gauges a long time ago. Their finding is that the pencil gauges are just as accurate as the round dial gauges. More importantly, dropping a round dial gauge from 3 feet put every single one out of calibration. The pencil gauges had no changes in calibration due to dropping.
Orson is offline   Reply With Quote
Old 02-17-2004, 12:38 PM   #7
grindMARC
Member#: 23547
02 WRX Wagon
Mersoydes 300SDL
Yeah, I paid $11 for mine and it reads in half pound increments. Great for autoxing...
grindMARC is offline   Reply With Quote
Old 02-17-2004, 09:00 PM   #8
leecea
Member#: 37359
2003 WRX
Yea, I was fooled by this too. I even went out of my way to get a compressor with a digital gauge and it was still reading way too high!
leecea is offline   Reply With Quote
Old 02-18-2004, 11:27 AM   #9
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
I got a digital gauge from Radiosuck. Works great...1/2 pound increments.
Old 03-06-2004, 04:22 PM   #10
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
I ngeneral, I hate the pencil type gauges.
If you use 6 different ones, you tend to get 6 different readings.
Round gauges are usually better.
BTW, I think a drop test will show that a pencil gauge "works better", why?, there are no moving parts.
Based on the above comment, I guess a $50 OBD code scanner is better than a $2000 Subaru scanner because it works better after it is dropped.
Any good tool needs to be taken care of.
I have always used dial type or digital type tire pressure gauges. I usually cross check them against each other to verify readings.
The biggest thing is to ALWAYS use the same gauge and write down the pressures you measure. Then try different pressures and see if you like the handling.
where to find ( what brand is..) the most accurate tire pressure gauge Toodma Texas Impreza Club Forum -- TXIC 39 03-26-2009 06:25 PM
Is this a good tire pressure gauge? essogas Service & Maintenance 15 09-13-2003 01:58 PM
17x8.5 tire size, is this right? wReXeRw Tire & Wheel 7 04-21-2003 07:57 PM
Is this right???? (EGT gauge question) Ken Levin Factory 2.0L Turbo Powertrain 3 01-08-2002 11:56 AM
Which is more accurate, digital or normal tire pressure gauge ? nor1212 Newbies & FAQs 3 07-25-2001 01:34 PM
Message Board Statistics All times are GMT -4. The time now is 06:24 AM.
