Old 02-15-2004, 04:56 PM   #1
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default anyone modify a EJ25 DOHC intake manifold?
hey, ive got a spare mani to play with, anyone modded one to flow better high end?
h
supermoose is offline   Reply With Quote
Old 02-15-2004, 09:05 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
are you gonna use this on your supercharged H6?
It has been done, but the problem is that the area at the top of the runners where the plenum connects is inaccessabel, and that is where the bends and a good part of the restriction lies. I have toalked to a couple of tuners about this and their only suggestion to do this right is to cut the manifold, port it and then weld it back together...
Old 02-16-2004, 02:50 AM   #3
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
extrude hone? thats when the run a gritty puddy through the manifold. just an idea.
RS_to_WRX_swap is offline   Reply With Quote
Old 02-16-2004, 03:59 AM   #4
supermoose
Member#: 9093
swap starr
i was thinking about actualy just keeping the flanges and making a sheet metal plenum and runners or modifying the runers to be shorter then welding them onto the plenum. hmm. however i cant weld. narf
Old 02-16-2004, 05:49 AM   #5
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
wouldn't sheet metal be too thin anyway?
Old 02-16-2004, 09:52 AM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
talk to Dcoty. He and his brother have been doing some custom manifold work in Dan's quest to break 13's. They may or may not be willing to share their designs at this point...
Old 02-16-2004, 05:17 PM   #7
supermoose
Member#: 9093
swap starr
depends on guage etc. id use somthing thick enough to be durable. sure i could grab random dubing that would fit at my buddys shop. i think
FS: EJ25 single cam heads / SOHC,DOHC intake manifolds sneaky Engine/Power/Exhaust 2 03-27-2009 10:41 AM
WTB: 2.5 dohc intake manifold 94legacy2.2 Private 'Wanted' Classifieds 6 02-21-2009 02:45 PM
Feeler: 99 DOHC Intake Manifold with accessories 25rsti NESIC Private Classifieds 6 07-19-2008 10:20 AM
wtb 2.5l dohc intake manifold stibf Private 'Wanted' Classifieds 3 02-23-2008 09:58 AM
Anyone have EJ25 DOHC Intake Manifold and Valve Cover Gaskets laying around? MY99 2.5GT Built Motor Discussion 0 04-11-2007 09:19 AM
