Old 02-15-2004, 05:02 PM   #1
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
Default Oil changes and such...
Ive been doing my own oil changes now, and im wondering if there is anything else i should be doing/checking while doing the oil changes. I dont have to grease anything do i?
03WRX83 is offline   Reply With Quote
Old 02-15-2004, 05:05 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Nothing to grease as all the pivot points are enclosed and "lubed for life". I personally rotate my tires with every change. In fact, I JUST got done doing this an hour ago. While I had the hood open, I check the other fluids to make sure the levels were correct. That is about all I can think of, but maybe someone else has advice?
Old 02-15-2004, 07:10 PM   #3
BillJC
Member#: 31002
I would get used to checking everything. Well, everything you can see. Get used to what looks correct. If you notice something that doesn't seem right, then you can fix it. I usually go through and make sure all of the nuts and bolts are tight. You know, sit under the car for about 15 minutes nut'n bolt'n the chassis. We do it be for every run on the race car so once every few months on the street car sounds good enough for me.
Bill
BillJC is offline   Reply With Quote
Old 02-15-2004, 08:32 PM   #4
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
i dont even jack my car when i do oil changes, i am fortunate enought to be able just shimmy under to undo the drain plug and filter.
Old 02-15-2004, 10:32 PM   #5
InfamousDX
Member#: 25413
Get some ramps or something... that's what I have now and it makes everything a breeze.
Old 02-15-2004, 11:23 PM   #6
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
got ramps, to lazy to use them just for an oil change.
thanks for all the input
Oil change and Transmission oil change help in Ann Arbor Scuter83 Mid West Subaru Owners Club Forum -- MWSOC 12 09-11-2006 10:53 PM
DFW where can I quality oil filters and such captaind Texas Impreza Club Forum -- TXIC 13 08-15-2005 01:28 AM
2nd oil change and which oils to change? makofoto Service & Maintenance 4 12-28-2002 08:07 PM
Oil Changes and Oil Filter for My Rex winterhammer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 05-17-2001 05:44 AM
