Old 02-15-2004, 06:16 PM   #1
treebeard
Member#: 33637
Default JDM STI Defi genome boost gauge wires
I bought a JDM STI genome electronic boost gauge (defi) a while back, but have not installed it yet for several reasons, the major one being that I cannot figure out how to wire the boost gauge controller properly...so please help out if you can! The controller can run up to four gauges at once, but I am only going to use the boost for now.
The main issue is finding the right hook up for the controller power wire which has a 15 pin connector at the end of it. From this connector, four wires go into the boost gauge controller, I am assuming two for power (red and white?) and two for dimmer control (orange and black?). The instructions written in Japanese indicate that there should be a 15 pin connector under the dash, but I think that is specific to the JDM wiring harness. So, how do I run power and dimmer (?) wires to the boost gauge controller.
The rest is easy, since it is totally plug and play (hose from bypass valve to electronic pressure sensor, wires from pressure sensor to controller, mounting the gauge on the steering column, and running the wires from the gauge to the controller)
Thanks in advance!
treebeard is offline   Reply With Quote
Old 02-16-2004, 02:02 PM   #2
treebeard
Member#: 33637
C'mon, anyone out there? There must be someone who has installed this kit...
Old 02-17-2004, 09:47 AM   #3
no_rex_yet
Member#: 7351
04 330cic
Don't have this gauge, but you should note it's made by Defi, and the same as their Link gauges. Perhaps try a search there or change your thread title to Defi to attract more attention.
no_rex_yet is offline   Reply With Quote
Old 02-27-2004, 03:52 PM   #4
wrrrx
Member#: 23993
2004 STi, Surgeline
WR Blue
Treebeard- any news on your progress?
Did you get a good deal on the gauge- I like the look of 'em, but Japanparts' bid was more than I wanted to spend...
Russ R
wrrrx is offline   Reply With Quote
Old 03-11-2004, 07:56 AM   #5
treebeard
Member#: 33637
I paid $280 or so for the controller and gauge...
I still haven't hooked it up yet. I need to do some cutting and splicing to run power to the controller, and I haven't had the time or motivation. Once the weather warms up, I think I'll give it a go.
Does anyone know where the best place is to pick up positive and negative wires to supply the 12V to the controller?
Since I have the subaru boost gauge, I already have the dimmer wires set up...
Old 03-11-2004, 12:15 PM   #6
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
I used my clock for all of the necessary wires for my gauges (Defi Link System). It has the constant 12V, ingition 12V, accessory light power, and ground.
mbiker97 is offline   Reply With Quote
Old 03-11-2004, 02:55 PM   #7
Monsito
Member#: 40581
04 STi
Monsito is offline   Reply With Quote
Fs: Rare Jdm Sti Genome Boost Gauge! subimatt Private 'For Sale' Classifieds 14 02-18-2006 08:11 PM
FS: STi Genome Boost Gauge h2opoloSTI Canada Region Forum 1 11-18-2003 01:51 AM
FS: STi Genome Boost Gauge h2opoloSTI Vancouver Impreza Club Forum -- VIC 1 11-18-2003 01:49 AM
STi Genome boost gauge install help Specialist Electrical & Lighting 1 08-12-2003 10:25 PM
STI Genome Boost Gauge Installed ImprezaWRXDriver Bay Area Impreza Club Forum -- BAIC 5 10-21-2002 12:41 AM
