Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 02-15-2004, 03:36 PM   #1
Defiantguy
Member#: 41268
2015 WRX
Default ProEcm problems
I installed a proecm I got off fat tits and I'm having CEL issues. I'm pretty sure my wires are correct and I'm grounding to a bolt by the ecu. After about 1.1 miles it throws a CEL and I get stuck in limp mode(can't rev past 4500rpms). Anyone have any suggestions for me?
Also, I accidentally cut a wire for the turbo application but I reconnected, soldered, and taped up the connection so its good. Could that be throwing the cel? Any help would be greatly appreciate, thx.
Defiantguy is offline   Reply With Quote
Old 02-15-2004, 03:52 PM   #2
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Might help if you got the code pulled and could tell us which one it is.
Joel
Zola is offline   Reply With Quote
Old 02-15-2004, 04:46 PM   #3
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
I was getting a code for speed sensor that was similar. One of the wires was loose.
Drac9 is offline   Reply With Quote
Old 02-15-2004, 05:28 PM   #4
Defiantguy
Member#: 41268
2015 WRX
question, I used a ground wire to ground the proecm now. Cept when I turn the car off, the power light on the ecm stays on. Is this normal?
99 Subaru Outback Shifting problem gifters Transmission (AT/MT) & Driveline 5 07-03-2010 04:05 AM
Is the proECM or TCII legal for STS trojan9x Motorsports 29 03-17-2004 11:15 AM
Who wants to figure out how the ProECM/TCII chips work? fellfrosch7 Normally Aspirated Powertrain 183 07-13-2003 05:41 AM
proecm- high idle problem awdwagon Normally Aspirated Powertrain 5 10-14-2002 11:30 PM
Help! ProECM install problems. monovich Normally Aspirated Powertrain 18 02-27-2002 02:36 AM
