Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 02-15-2004, 09:03 PM   #1
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Default Cyl 4 misfire only with borla headers
I posted awhile back about getting a cyl 4 misfire under WOT in the 3rd gear with no driveability.
I can now say its defintly related to the headers, because I have had them off the car for about a month (due to crack) I just got them fixed and I put them back on, and bam back comes the flashing cel in 3rd gear.
It never came on in the past month without the headers.
I have to rack my brain now and figure out why/how the headers would do this..
nothing jumps out at me. That dam cel is annoying as hell!
boooo
Jay
Old 02-15-2004, 09:31 PM   #2
EvasionOfTruth
Member#: 13282
2007 FXT
WRB SPB Edition
Good luck figuring out what it is, it'll be interesting to see the cause. I've been running Borlas for 6 months or so with no issues (well except the cat effiency cel).
EvasionOfTruth is offline   Reply With Quote
Old 02-15-2004, 10:19 PM   #3
Olson
Member#: 51277
1991 Galant VR4
Blk
check the plugs wires and and the caps. is all i can say. (is that what there called if not forgive me im new to the boxers)
Olson is offline   Reply With Quote
Old 02-16-2004, 05:39 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Ive replaced everything, normal maintnence
I fix cars for a living
Jay
Old 02-16-2004, 06:32 PM   #5
Olson
Member#: 51277
1991 Galant VR4
Blk
it wouldnt have anythign to be doing with running lean. that all i can raelly think of. but that shouldnt be a prob.
i dont know somebody else might know thats weird
Old 02-16-2004, 08:52 PM   #6
CheezeWeezle
Member#: 17187
2009 Braun Entervan
Gimpy White
That is weird...why would something external and part of what the cylinder produces cause the cel...I'm still with no cel and I've had them on for about 6mths and approx 12k...maybe more....weird..
edit: What about your intake? Modified? I could see a result of the misfire because of the intake and the freer flowing exhaust...maybe...just throwing out an idea. I still don't see why something external directly relates to anything internal....especially when it's running at the end of the chain?
CheezeWeezle is offline   Reply With Quote
Old 02-16-2004, 11:43 PM   #7
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Abnormal scavenging of the exhaust is about it. Does the plug in that cylinder look normal compared to the others? Is there more heat in that area with the Borlas?
1 Lucky Texan is offline   Reply With Quote
Old 02-17-2004, 01:24 PM   #8
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
35 PSI -- in my tires
Ok now im scared... should i buy headers for my 2.5li outback
Honkey3k is offline   Reply With Quote
Old 02-17-2004, 09:12 PM   #9
clyde
Member#: 14305
1997 Impreza OBS
Is it RPM-dependant at all? Does it get worse in gears higher than 3rd?
clyde is offline   Reply With Quote
Old 02-17-2004, 11:10 PM   #10
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
from what ive checked so far.
its 100% Load/Open loop, 6k rpms usually in the 3rd gear, I havent checked the freeze frame data on the latest CEL yet, ill post them results when I do.
im lazy...
I havent pulled the plug at all.
At first I thought it was carboned up valves...but headers or no headers shouldnt make a difference.
I do have a jc sports intake
CheezeWeezle you hit the nail on the head.
the other thing that has me is there is NO driveability, just a flashing CEL. At 6k rpm WOT if the car misfires, you would certianly expect to feel it.
I dunno. Eventually ill look into it deeper, but by the time that comes around ill probably have done my WRX swap.
I also have a 112,000 miles, so im not worrying about it too much cause the car runs great.
Jay
stumped by cyl 4 misfire. KurtP Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 01-02-2010 08:55 PM
HELP!! Cyl. 4 Misfire...? SubieStylez Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-16-2007 03:38 PM
Cyl 4 misfire simpreza2 Normally Aspirated Powertrain 3 03-18-2005 12:48 AM
CEL P0304 - cyl 4 misfire, want people's thoughts edkwon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-19-2004 04:44 PM
Cyl 4 misfire, no drivability concerns... munkis Normally Aspirated Powertrain 11 03-28-2004 10:48 PM
