Old 02-16-2004, 01:09 PM   #1
makofoto
Member#: 25243
2006 Legacy Outback
Default "Check Engine" warning light question ...
On the way home from the San Diego Solo II ... my Check Engine light came on ... we did the obvious, checked water, oil, fuses ... made sure the gas cap was on three clicks ... light is still on ... although the manual says it might take a few trips for it to reset itself ... what should I do if it doesn't go out ... dealer (w/ my mods) or a private garage like Scooby Specialties?
I have a '03 WRX Wgn with EcuTek dual maps, Stromung downpipe back exhaust system ending with a Prodrive muffler, APS up pipe, APS aluminum IC intake, STI IC.
20K on the car ...
makofoto is offline   Reply With Quote
Old 02-16-2004, 01:42 PM   #2
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Well, since you live in California, you're out of luck when it comes to the free Autozone method. Might try posting in your regional forum to see if anyone near you has an OBDII scanner that you could borrow briefly.
I assume you have some sort of fix (e.g., PonyExpress MIL eliminator) for the P0420?
Joel
Zola is offline   Reply With Quote
Old 02-16-2004, 01:43 PM   #3
Jon [in CT]
Member#: 2992
02 WRX Sedan
Actually, the only obvious thing to check when the CEL comes on is the trouble code stored in the OBD computer. Find someone with an OBD scan tool.
Jon [in CT] is offline   Reply With Quote
Old 02-16-2004, 09:08 PM   #4
Evan
Member#: 11218
2005 Legacy GT Wagon
99 Miata, 91 Miata turbo
I've got a scan tool in Irvine, you're welcome to come down and use it.
But you can probably find someone closer by posting in SCIC.
Evan is offline   Reply With Quote
Defi Warning light question? SCOOBY2.5RS Electrical & Lighting 2 03-30-2007 10:12 PM
Air Intakes and that orange "Check Engine" light Norris Normally Aspirated Powertrain 5 06-02-2003 03:52 PM
Day 1, "Check Engine" Light also?! Stickaru STi Forum Archive 0 06-01-2003 12:53 AM
"Check engine" light on wi/ cold air intake Subbieddie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 11-14-2002 01:36 PM
Anyones "check engine" light came on after K& N air filter was installed? Rozos Newbies & FAQs 11 11-05-2001 02:44 PM
