Welcome to the North American Subaru Impreza Owners Club Saturday January 24, 2015
Old 02-16-2004, 02:44 PM   #1
whitewrxwagon
Member#: 27960
2003 WRX Sport Wagon
Default Trans / Diff Fluid question
Found this comment on red line gear oils
DIFFERENTIAL FLUIDS
75W90 GEAR OIL - recommended for most street driven and racing differentials. Excellent performance in conventional and limited-slip units. Also for limited-slip manual transaxles which require a 90 WT oil. Contains limited-slip friction modifiers.
75W90NS - recommended for manual transmissions and non-limited-slip transaxles that recommend 140 WT oils. Can be used in racing limited-slip units to increase lockup and reduce wheel spin. Street-driven rear-wheel drive cars should use regular Red Line 75W90 or 80W140.
Looking for feedback on either version and any problems encountered like syncro issues.
Thanks
whitewrxwagon is offline   Reply With Quote
Old 02-16-2004, 04:59 PM   #2
LyveWRX
Member#: 19057
& Red Ford & '72 CB350
First thing first-> SEARCH the TRANNY fourum.
All others aside....
I like a cocktail of fluids for my tranny. Here's the whole story.
0-13,000mi --> stock fluid no troubles, one TSD rally (brisk)
13,000 -- 46,000 mi -->DIFF - 3/4qt of super-heavywt shockproof; 75w-90 rest
TRANS - 3.4qts 75w-90ns, super-heavy wt shockproof to fill
At approximately 46kmi I changed the fluids again. atleast 2500mi of Brisk TSD rally and lots of "spirited" driving, no troubles at all whatsoever with the shift. (have to double cluch down into first, always had to even on stock fluids)
New Recipe:
After subiegal's testimony on the heavywt shockproof I decided I could use more protection.
DIFF- 100% heavywt Shockproof
TRANS - 2qts 75w-90ns rest w/ heavywt shockproof.
Now It still shifts great when hot, when cold however (as cold as -15F) you have to be really patient w/ the shift.
nick
LyveWRX is offline   Reply With Quote
trans and rear diff fluids questions (Amsoil) stixtasy12 Newbies & FAQs 6 05-30-2009 12:11 PM
rear diff fluid question TurboSteve Service & Maintenance 3 01-17-2005 09:37 PM
Tranny/Diff Fluid Question mykrrrr Mid West Subaru Owners Club Forum -- MWSOC 19 01-08-2003 10:12 AM
changing out rear diff fluid question newbie sewbie Transmission (AT/MT) & Driveline 4 12-12-2002 05:16 PM
Tranny/Diff. Fluid Question Dolphin Overton Transmission (AT/MT) & Driveline 7 02-10-2002 04:38 AM
