Old 02-16-2004, 01:57 PM   #1
R.C.Y.K.
Member#: 10389
Default Question about Omori Oil Pressure Gauge Install
I am about to install the omori oil pressure gauge, I am going tap it to the oil gallery plug under the alternator. So the question, do i need to lose all the engine oil to do the install?
scoobymod
R.C.Y.K. is offline   Reply With Quote
Old 02-16-2004, 02:34 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
Why not use the one under the IC? You can just get an adapter plug from Subaru and it becomes as simple as plug-and-play.
cnk is offline   Reply With Quote
Old 02-16-2004, 02:46 PM   #3
awdman
Member#: 27962
2003 WRX Sedan
Blue, with more dings!
Default I doubt it.
Oil drains down to the bottom when the engine is off. I just put my sending unit in (14th) near the intercooler and I didn't see any oil at all.
The problem with my chosen location is the crankcase vent tee. It caused some interference. I had to use hose clamps to keep one one the lines on....
Just something to consider...
awdman is offline   Reply With Quote
Old 02-16-2004, 02:48 PM   #4
awdman
Member#: 27962
2003 WRX Sedan
Default I doubt it.
The problem with my chosen location is the crankcase vent tee. It caused some interference. I had to use hose clamps to keep one of the lines on....
Old 02-16-2004, 02:53 PM   #5
R.C.Y.K.
Member#: 10389
I dun use the one under the ic, becoz i am going to install oil temp there.
one more question, since i have omori gauges, so there is 1 red power, 1 white power, and 2 black ground wires that i need to hook up. and i am going to hook them up to the clock harness. so do i hook up the red power to switch 12v, and white power to illumination, and should i put all the ground to the same wire on the clock harness?
Old 02-17-2004, 12:39 PM   #6
awdman
Member#: 27962
2003 WRX Sedan
Default I wouldn't.
Whichever wires are for illumination, you should connect with the spare harness coming off of the clock. That way your dimmer switch works. Both power and ground!
Switched power or battery power can be connected at the clock and ground as well.
Basically you don't want to share illumination ground with anything else because the ground is how Subaru controls the dimmer.
Taking the radio out isn't hard compared to the clock!
oil pressure gauge install question bulldog2277 Newbies & FAQs 2 06-10-2008 12:08 PM
Autometer Oil Pressure Gauge Install Questions maxpower_454 Electrical & Lighting 4 11-28-2005 03:02 PM
Autometer oil pressure gauge install question sethb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-08-2005 07:59 PM
quick question about oil pressure...worried about my car Blindeye_03 South East Region Forum 6 09-03-2004 11:58 AM
Oil pressure gauge install questions PHATsuby Normally Aspirated with bolt-on Forced Induction Powertrain 12 06-23-2003 01:33 PM
