Old 02-16-2004, 03:24 PM   #1
O1LegacyGT
Member#: 52331
10 LGT Legacy
Silver on black
Question 01 legacy gt le adding turbo and top mount what hood?
Ok guys and girls i am ordering my turbo kit this friday, how ever i need to get a hood that will work with the top mount- I heard that a 04 subaru baja's hood will fit? I am trying to find a carbon fiberhood if possiable. But i am trying to do this fairly cheap, if i use a baja hood what other modifications do i have to do? Are there any other turbo hoods that will fit this car? or any older legacy hoods that will work
thanks
O1LegacyGT is offline   Reply With Quote
Old 02-16-2004, 03:55 PM   #2
tora
Member#: 5851
09 Forester XT
+ NA Miata
Erebuni has a CF and a fiberglass hood available that should work....something to check anyways. You can get a look for how it will look and how much you might pay. Ideally a JDM hood would be great.
Or why not cut a hole in your hood, add whichever hood scoop you like, mold it in. (I'd take the CF hood myself, but it is an option...especially if you have a friend who is a fabricator.
tora is offline   Reply With Quote
Old 02-16-2004, 04:59 PM   #3
O1LegacyGT
Member#: 52331
10 LGT Legacy
Silver on black
yeah i always wanted a cf hood,but as a passed mustang guy with a fox body stang i dont think a cf hood would look all that great. lol But how much do you think that would run? Then i can just use the hood and say it is a show car just like my stang.. around here it is kind of competive when it comes to street racing if i get back into that ;-) Ill defiently look into it thanks
can we use the stock grill with the cf hood?
Old 02-16-2004, 05:10 PM   #4
jackacc
Member#: 53188
2013 WRX 5 door
I just ordered a Baja hood the other day, and it will fit right on. I have been talking with 2000LegacySti and he just put his on last week with no problems.
I have heard that the erebuni hoods do not fit correctly. The holes for the windshield washer jets are not correct and I did hear something about the front fitment being off.
Plus, the Baja hood is only $300! plus paint of course... But I think that will be the best way to go and look the cleanest.
The grill just swaps over as far as I know. Good luck! As soon as I have the hood on, I will get some pix up!
Jack
jackacc is offline   Reply With Quote
Old 02-16-2004, 05:19 PM   #5
O1LegacyGT
Member#: 52331
10 LGT Legacy
Silver on black
thanks.. wow i hope they fit nicely for 500 dollars plus shipping
i would be really upset if once i recieved it, it didnt fit right
Old 02-16-2004, 09:15 PM   #6
Tizzle
Member#: 44472
Ver2 Legacy StiRA
88 RX, 87 RX, 07 FXT
I need to do the same thing with my 96 legacy. And Outbacks are pretty common where I live, so I should be able to get a hood with scoop off one of those from a junkyard. This would work right? I have a wrx scoop sitting in my room, but I think I would actually like the stock look more
Tizzle is offline   Reply With Quote
Old 02-17-2004, 01:28 AM   #7
2000LegacySti
Member#: 47005
ok, here's the scoop...
I have a 2000 legacy GT Limited and put the '04 baja turbo hood on last week. It fits PERFECTLY, absolutely no mods. I would definately recommend it.
Secondly, I had the Erebuni CF hood for a couple days and it was horrible. I had to send it back. Although it was of sound build quality and was constructed well, the curvature of the hood was off, the curvature of the scoop was off - big time, the washer nozzle holes were predrilled but were too small and had to be enlarged, the cutouts for the washer assembly on the underside of the hood were not there, the hole for the hood support rod had to be cut, the holes to mount the grill needed to be drilled, and finally, the part of the hood that touches the sides of the grill were cut at the same angle if ya know what I mean. It looked like \ GRILLE \ instead of \ GRILLE / .
This may have been just my experience, but it sucked.
I hope this helps....
2000LegacySti is offline   Reply With Quote
Old 02-17-2004, 03:40 AM   #8
tora
Member#: 5851
09 Forester XT
+ NA Miata
Good to hear, hadn't heard anything about the erebuni hoods. I wonder if the fiberglass one is any better? I'm guessin gthe CF one was fiberglass with a CF overlay?
Sounds like the baja hood is the way to go.
Old 02-17-2004, 03:58 AM   #9
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
you will have no issues with the Baja hood because its the identical hood offered on the Legacy B4 BE/BH chassis, which is the same chassis as our car and the Baja.
Ben
Old 02-17-2004, 10:48 AM   #10
O1LegacyGT
Member#: 52331
10 LGT Legacy
Silver on black
what about the brackets? are they a direct fit aswell or do they need to be fabricated.. also does anyone know where i could get a used baja hood that is already painted..
hey ben you think i can i hide that intercooler under the hood for with no problems, I think i am going to cancel my extended warantee the dealer sold me on there is no need for it now.. Then ill refinance
thanks everyone
any other opinions
what is joet running?
Old 02-17-2004, 12:18 PM   #11
aross
Member#: 831
11 Blurple WRX
03 BH MBP
IIRC JoeT has the JDM B4 Hood.
aross is offline   Reply With Quote
Old 02-17-2004, 02:01 PM   #12
O1LegacyGT
Member#: 52331
10 LGT Legacy
Silver on black
That is what i though bought i wasnt sure..
Old 02-17-2004, 02:08 PM   #13
PHATsuby
Member#: 13617
2001 Legacy GT back
no fabrication needed, bolts right up, and yes the intercooler will fit under it, how do you think my hood closes
good luck!
Ben
Old 02-17-2004, 02:38 PM   #14
O1LegacyGT
Member#: 52331
10 LGT Legacy
Silver on black
cant wait, i am to impatient for this turbo project... I dont know where i am going to scoop up the 2k for the ecu but i am working on it
Old 02-18-2004, 08:48 AM   #15
KeithvH
Member#: 37273
2003 Legacy SE Wagon
minty-fresh green
What turbo setup are you going with? Links?
KeithvH is offline   Reply With Quote
Old 02-19-2004, 12:29 AM   #16
whitt
Member#: 8928
0216 02 WRX & 16 WRX
White & Lapis Blue
hey I was just wondering did they just use the aluminum b4 hood or did they do something stupid like making a steel version for the turbo baja?
DW
whitt is offline   Reply With Quote
Old 02-19-2004, 05:36 AM   #17
PHATsuby
Member#: 13617
2001 Legacy GT back
B4 hood is not aluminum, and neither is the Baja hood(they are the same )
Ben
Old 02-19-2004, 03:42 PM   #18
White2.5GT
Member#: 25142
1998 Legacy 2.5GT
can we have some pics of your car with the baja turbo hood?
White2.5GT is offline   Reply With Quote
Old 02-19-2004, 04:15 PM   #19
O1LegacyGT
Member#: 52331
10 LGT Legacy
Silver on black
I am going to make an atempt to go with a simular set up as joet and phatsuby running the autronic... I still cant believe about the cf hood being that bad of quality as far as molding i mean i believe you that it was bad but i cant believe they let that left there warehouse i guess some companys can just care less about their customer service
Old 02-19-2004, 04:38 PM   #20
2000LegacySti
Member#: 47005
yeah, its in the shop right now but I will try to have pics in the next week or so. it really looks nice.
01LegacyGT- like i said, the hood was of sound build quality, but the molding was definately off, and I have heard positive things about erebuni. this was just my experience, someone else's may be different. regardless, the baja turbo hood is excellent, 4 bolts and you're done. sadly, it isn't aluminum. that kinda sucks, but its not too bad...it weighs the same as your factory hood
Old 02-19-2004, 08:10 PM   #21
O1LegacyGT
Member#: 52331
10 LGT Legacy
Silver on black
with my luck i would hate to take the gamble and pay all that money for the hood and be stuck with shipping charges ouch!!
Old 02-20-2004, 07:33 PM   #22
zzzzzzzz
Member#: 9843
Sweet you guys! Just read this thread yesterday and I happened to have my car in the shop! Had a little accident and needed to change the hood and front bumper! I called them to arrange for the turbo Baja hood/scoop and 04 bumper as the replacement parts. Turns out, I only have to pay an additional $200 and some change!!
I'll have some pics once I get it.
Oh yeah, I'm driving a Mazda 6 as my rental...
zzzzzzzz is offline   Reply With Quote
Old 02-29-2004, 04:48 PM   #23
MekoNY
Member#: 8000
2005 Accord
Graphite
So does anyone have pics of their baja hood on a BE Legacy yet? If everything you guys have said is true, I'll be ordering mine tomorrow. I have lots of paint chips and one huge gash on my hood, so instead of re-painting it, I'm going to go with the Baja hood. But I just want to make sure I don't have to cut, drill, or fabricate any parts.
Sam, I got my GR-2's and your Whiteline springs installed yesterday by AZP Installs (Tri-State forum) and it was a job and half! You never told me that I would need WRX tophats with those springs.
Luckily for me, they happend to have a WRX salvage that was laying around. Otherwise I would have been screwed.
In the end, my car looks nice and the next mod is the hood...just want to be sure this time.
MekoNY is offline   Reply With Quote
Old 02-29-2004, 07:03 PM   #24
SSR
Member#: 14760
2002 Legacy GT LTD
Black Granite Pearl
So anyone have the part number for the Baja hood?
And did you order the hood painted your factory color? or did you bring it to your local paint shop to have them paint it?
Thanks!
SSR is offline   Reply With Quote
Old 02-29-2004, 07:14 PM   #25
jackacc
Member#: 53188
2013 WRX 5 door
I should have my car back from the shop early this week with the new baja hood on. I just dropped it off last week to get painted at my local body shop. (it comes in a dull black color) I'll post pics as soon as I have it back. part #: 57220AE01A
Hood cost me around $300 but you also have to order the hood scoop insert for it as well ($100). There are also a couple other parts that redirect air onto the intercooler that are required (unless your turbo setup comes with something)
I do not have a turbo so I did not need them. I am just changing the hood for aesthetic purposes
Socal turbo and top mount for sale Tomster Engine/Power/Exhaust 2 05-22-2007 01:15 AM
sti turbo and top mount into 2001 forester chrs427 Subaru Conversions 1 09-08-2006 02:39 PM
Stock WRX turbo and top mount Fltblkgsx Private 'For Sale' Classifieds 13 01-22-2005 02:25 PM
Stock WRX Turbo and Top Mount Fltblkgsx Private 'For Sale' Classifieds 0 01-15-2005 11:50 AM
Stock WRX Turbo and Top Mount Fltblkgsx Private 'For Sale' Classifieds 0 01-14-2005 09:38 PM
