Old 12-01-2012, 12:06 PM   #426
ryanb4614
Member#: 335145
I have a 2012 Subaru Impreza 2.0 base 5k miles. I don't even have the car for a year and the coolant level is at low. I stopped at my subaru dealership and he said they have the super blue for $28.00 a gallon. He told me I have to use the subaru brand. So I have to top it off since it is low. Is there anywhere online I can get the super blue cheaper? Is it odd that its already low within less than a year?
ryanb4614 is offline   Reply With Quote
Old 12-02-2012, 01:24 AM   #427
CalvinT
Member#: 329025
2002 WRX Wagon
It shouldn't be low after a year. Sounds like a leak or something else going on. Need to find out what's happening. It could be simple like a pressure cap problem or a problem with your overflow. Top off both the expansion take and over flow. Check your expansion tank first thing in the morning before driving and see if it's full or not. It should be full with no air bubble. I had an air bubble in the morning, a new pressure cap fixed it.
You should use either the Super Blue or Beck Arnley 252-1501U Blue Premium Extended Life. It's compatible with Super Blue and meets Subaru specifications. I suspect it might be the same thing. I paid $17 for the Beck Arnley at BAP. Go to the Beck Arnley website to find out who sells it.
Also call around to different dealers if possible. Another one might have a lower price. Also Acura, Honda, Infiniti, Mitsubishi, Nissan and Suzuki use the same coolant. Just make sure it's a factory coolant and is blue blue and not the green one that has to be diluted.
CalvinT is offline   Reply With Quote
Old 12-02-2012, 01:31 AM   #428
CalvinT
Member#: 329025
2002 WRX Wagon
You need to fill out your profile. Would make it easier for someone to help you. I just checked, I can special order the Beck Arnley into my local Oreilley's for $24.
Old 12-15-2012, 12:54 PM   #429
ryanb4614
Member#: 335145
I checked the coolant while the car sat overnight, it is below the low level mark. I've checked around there is no visable signs of a leak. I'm going to fill it and monitor the levels to see if goes down anymore. If it does I will call the dealership.
I contacted the subaru dealer and he told me $28 for a gallon so I may just go with that for now.
I think it's odd hat I've had the car for a year and it's already empty.
Old 12-16-2012, 02:19 AM   #430
CalvinT
Member#: 329025
2002 WRX Wagon
The car is still under power train warranty. The dealer should find and fix the problem at no cost to you. A car shouldn't use any coolant at all.
If the dealer isn't cooperative, either go to another dealer or call Subaru of America.
Their number is 1-800-782-2783
Old 12-16-2012, 08:29 AM   #431
CalvinT
Member#: 329025
2002 WRX Wagon
If your coolant level drops again I'd suggest asking the dealer to pressure test your cooling system and pressure cap. Also check the hose to your overflow tank. Make sure it's not leaking. Also check that your overflow tank hasn't developed a leak.
Old 12-27-2012, 02:11 AM   #432
subySerb
Member#: 155411
Tonight I noticed a few drops of coolant on the garage floor, and after some "detective " work found out that that the radiator cap is missing from my dad's 2010 Forester. We probably drove it like that for a few days. How bad is this gor the engine? Am I safe to drive the car to the dealership without the cap?
Thanks
subySerb is offline   Reply With Quote
Old 12-27-2012, 10:59 AM   #433
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
No problemo as long as the car doesn't overheat. No need for the dealership, just go to any auto parts store and get a cap.
Old 12-27-2012, 11:05 AM   #434
subySerb
Member#: 155411
I drove it last night (before I discovered the missing cap) and it didn't seem to overheat. Would that "blue light" just become red if the car overheats because the new Foresters don't have the normal gauge?
Old 01-28-2013, 04:47 PM   #435
Dinzdale40
Member#: 254306
2004 WRX STi
Thanks for all your help. I got my radiator installed and got all the air out without a hitch.
Dinzdale40 is offline   Reply With Quote
Old 02-07-2013, 09:44 AM   #436
STIinthefe
Member#: 314642
2004 STI
I recently had to replace my timing cover due to my AC idler pulley shaft stripping off the nut and sending the pulley into my timing cover like a Chinese throwing star. Any way I disconnected my upper radiator hose and plugged it and the radiator with a clean shop rag so I wouldn't lose so much coolant. I did lose around a 1/2 quart. When I finished I realized I left the coolant at my friends garage so I just let the car idle and drove it with no over heating or problems. Do I need to replace the lost coolant and bleed/burp the system. The core still looks full FYI. This is an 04 Sti.
STIinthefe is offline   Reply With Quote
Old 02-07-2013, 11:12 AM   #437
StiLmtd
Member#: 319354
2007 Sti Limited
UGM
I would bleed/burp the system just to make sure there are no air pockets in it. I've also bled/burped the system just because I've heard gargling on startup though, so it might just be my compulsiveness kicking in lol
StiLmtd is offline   Reply With Quote
Old 02-27-2013, 04:03 AM   #438
steven765
Member#: 105920
2006 Baja 5 Speed
After a complete rebuild on a 2.5 with multi layer head gaskets, I refilled with the new blue subaru super coolant. Should I be adding the subaru conditioner?
steven765 is offline   Reply With Quote
Old 02-28-2013, 01:38 AM   #439
CalvinT
Member#: 329025
2002 WRX Wagon
The Subaru conditioner is a good product. It does an excellent job of sealing small leaks. My original radiator cracked (5 inch crack) and the conditioner really slowed the leakage. There was a stream of coolant that it stopped. And it didn't clog the radiator. I know because I took the radiator apart later.
There was an End Wrench article about the conditioner. Subaru started recommending it for the 2.5 liter engines back around 2004 or so because of a head gasket problem. They were leaking coolant to the outside of the engine. Subaru also extended the cooling system warranty on the affected cars to 100,000 miles or 10 years if the conditioner was used when coolant was changed according to the maintenance schedule.
When I replaced my radiator I flushed my engine seven times with distilled water and put the blue Subaru super coolant in, and a bottle of conditioner. I figured it couldn't hurt.
Old 06-28-2013, 11:18 PM   #440
MG rex
Member#: 341359
2013 WRX Hatch
When is the best time to check for coolant level? When my engine is cold, it is exactly at the MIN level and when hot it is right between MIN and MAX.
Quite concerned if this is normal for a brand new car.
Unrelated to coolant but I noticed the air condition condensate drips after driving. Is there a way to stop this? Can't imagine it'd be good for XX years in the future.
MG rex is offline   Reply With Quote
Old 06-29-2013, 07:30 AM   #441
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Don't worry about either.
Old 07-01-2013, 12:55 PM   #442
tcat
Member#: 218325
2005 Baja Sport
Dark Blue
Need to replace coolant on my '05 Baja (90K), probably buy a gallon of that Beck Blue and do it myself. I do need to replace my hoses, any brand preference there? Gates... Goodyear... all about the same price. Gates says "requires sleeve" what does that mean?
tcat is offline   Reply With Quote
Old 07-01-2013, 03:11 PM   #443
Fatnslow
Member#: 314685
2002 WRX Sedan
Default coolant system question
Hello,
I recently swapped out all of my hoses and replaced my thermostat. For the most part, I followed the FAQ for the proper burping procedures when filling the system. I did make one small change and I wanted to know if the system would correct itself.
Basically, when I was refilling my coolant system (2002 wrx) I didn't have a spare bucket to pre-mix the concentrated coolant with 1 gallon of distilled water. Instead, I poured 1/2 of the concentrated coolant in the reservoir tank and the rest into the filler tank by the intercooler. I then put in the subaru coolant conditioner and almost 1 gallon of distilled water. So starting out, my water to coolant ratio is like 75/25 instead of 50/50. My engine heats up quickly, but it has not gone a tick mark above nominal temp.
I thought that as I drove, the coolant in the reservoir tank would mix in with the rest of the system. Given time, would the system naturally "correct itself" by mixing in the coolant from the reservoir as the 75/25 coolant evaporates? If not, I suppose I would have to dump everything in a bucket, mix it, and then repour it back in the system? :s
Fatnslow is offline   Reply With Quote
Old 07-01-2013, 04:04 PM   #444
shello007
Member#: 195405
2003 Wrex Wagon, LGT
Blue Black, Black
You wanna only put fluid to the low mark in the reservoir. When the engine is cold. That's the level
shello007 is offline   Reply With Quote
Old 07-01-2013, 05:26 PM   #445
tcat
Member#: 218325
2005 Baja Sport
Dark Blue
Decided to buy Peak Global Lifetime since it's on sale at Pepboys for $5.50! Ordered the Subaru conditioner at Amazon $8.32 free shipping.
How difficult is replacing upper and lower hoses? Last dealer oil change told me they were cracked and needed replacing. I ordered Gates from Amazon, planning on a radiator weekend.
Old 07-02-2013, 02:32 AM   #446
Fatnslow
Member#: 314685
2002 WRX Sedan
That I understand, but I think my question got lost in translation. I am wondering if the 25/75 (coolant/water) mixture I have will eventually even out to 50/50 with the 100% coolant from the reservoir tank. Mainly, will my current 25/75 mixture evaporate out of the overflow hose and will be replaced with the 100% mixture from the reservoir tank?
Old 07-02-2013, 02:36 AM   #447
Fatnslow
Member#: 314685
2002 WRX Sedan
It takes like 15 minutes. 10 or so of that is waiting for the coolant to drain out. Once the system is drained, the hoses are an easy swap.
Old 07-03-2013, 04:18 PM   #448
DerrickRH
Member#: 75078
2000 Legacy GT
Black Granite Pearl
FWIW, I have used this O'Reilly brand pre mixed coolant in my 00 Legacy w/ subaru coolant conditioner for some time and have had zero issues with it. Should save a few bucks since it meets all of the same specs as Subaru brand and Peak.
http://www.oreillyauto.com/site/c/de...0496&ppt=C0059
DerrickRH is offline   Reply With Quote
Old 07-04-2013, 07:27 PM   #449
cosseywrx
Member#: 276443
2005 2.1 stroker WRX
So i have deleted my upper coolant tank because i run a oil cooled turbo.
My problem is this.
My system has been bled of all air. What happens is when the car is cold the upper rad hose will collapse.
This is with using the stock 137kpa cap on the radiator.
What i tried now is using the upper tanks 108kpa and letting it cool to see what happens.
Remember i have deletes the upper tank and the hose collapses when the moto cools down and is cold.
cosseywrx is offline   Reply With Quote
Old 07-14-2013, 09:31 AM   #450
Kraj81
Member#: 361484
2006 Impreza WRX
seeing that i don't know which coolant is currently in the system, should I have it flushed or can i just top off with any?
Kraj81 is offline   Reply With Quote
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 702 Yesterday 12:08 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 08:49 AM
Oil FAQ: Read if you want more information on oil, oil filters, and oil changes! Unabomber Service & Maintenance 1061 10-22-2015 11:38 PM
Tool FAQ: Read if you want information on Subaru specific tools and sundries Unabomber Service & Maintenance 41 08-16-2014 05:59 PM
