Old 02-25-2004, 11:14 PM   #26
tdxflex
Member#: 13634
tdxflex is offline   Reply With Quote
Old 02-29-2004, 11:36 PM   #27
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
Originally posted by djerickd
thanks for that info I might try this Peak stuff.
I ended up getting it after doing a little research this stuff is like yellow/orange. Like dark pee.
djerickd is offline   Reply With Quote
Old 03-07-2004, 07:46 PM   #28
c_hunter
Member#: 32434
05 Outback XT 5EAT
Gold/Black
Originally posted by Unabomber
Coolant System FAQ
Is there a required coolant additive? Yes. Subaru Cooling System Conditioner (part number SOA635071) has recently been recommended to be added with every coolant replacement to prevent coolant system leaks.
You might want to clarify this info. The conditioner is only for certain 1999-2002 Phase II 2.5 engines that are susceptible to external coolant leaks from the head gasket. The conditioner should not be used under any other circumstances.
Craig
c_hunter is offline   Reply With Quote
Old 03-07-2004, 08:04 PM   #29
Jon [in CT]
Member#: 2992
02 WRX Sedan
Craig
You might want to re-read that first post again, where he includes an image from an updated 2004 Impreza Service Manual (MSA5T0410A) which recommends the cooling system conditioner be used whenever the coolant is replaced. That manual is applicable to all 2004 Impreza variants including the WRX and STi.
Jon [in CT] is offline   Reply With Quote
Old 03-09-2004, 08:52 PM   #30
Columbo
Member#: 17328
2002 WRX Wagon 4EAT
Appliance White
Default Drain plugs...
Okay specialists,
Are there coolant drain plugs on each bank of cylinders to drain coolant from the block? All water cooled engines I've worked on have had at least one (in-line engine) or two (v-engine). Good question?
Columbo is offline   Reply With Quote
Old 03-09-2004, 09:54 PM   #31
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
This link shows you where they are located. There are 2, one on each forward side of the motor for each bank.
Old 03-09-2004, 10:31 PM   #32
Columbo
Member#: 17328
2002 WRX Wagon 4EAT
Appliance White
Thanks so much for that information. I think that aspect of the coolant change if over-looked quite a bit. From the link, it seems not much more drains out of there though. I'll see what happens when I get there (now I know where).
Old 03-09-2004, 10:45 PM   #33
Jon [in CT]
Member#: 2992
02 WRX Sedan
Default Re: Drain plugs...
Originally posted by Columbo
Okay specialists,
Well, I'm not a specialist, but here's a diagram that shows the block plugs on a normally aspirated EJ engine.
This question also suggests some others that ought to be covered by any thread that presumes to call itself the "Cooling System FAQ" in the Service & Maintenance forum.
How do I drain my coolant?
How do I refill my coolant so I don't have any air pockets?
Here's a start on those answers, with a Subaru document (see p. 4):
http://www.endwrench.com/current/win...ngineMaint.pdf
Old 03-13-2004, 04:07 PM   #34
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
Just as an FYI:
My Honda S2000 uses Honda Type II Long Life coolant. It's an extended life, silicate free coolant made for use in aluminum engines such as the S2000's.
I plan to flush the WRX and use this as a replacement when I hit 30,000 miles.
Honda sells the Type II Long Life in 1 gallong jugs, and it comes pre-mixed (50/50).
heffergm is offline   Reply With Quote
Old 04-12-2004, 05:28 PM   #35
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
there is some good stuff here ron...
Old 04-12-2004, 05:45 PM   #36
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Default Re: Cooling System FAQ: Read if you want coolant information!
Great FAQ as always; thanks!
[quote]Originally posted by Unabomber
Should I use tap water, deionized water, or distilled water when mixing? Best waters to use are in this order:
1. Deionized water
2. Distilled water
3. Tap water
Why would deionized water be better than distilled?
What is the best coolant? As far as the best coolant for removing heat from your engine, it would be water. You might even see better heat removal capability if there is a coolant additive mixed with it. Obviously, plain water should only be used in racing only applications and only by advanced users. Its use in a normal passenger car is NOT recommended even for short use.
Just to explain a little more, water has a very high heat capacity. The reason it is mixed with ethylene or propylene glycol is to lower the freezing point below 32F and raise the boiling point above 212F. Both water and ethylene or propylene glycol are essential to the coolant's function.
Mike Wevrick is offline   Reply With Quote
Old 04-12-2004, 09:18 PM   #37
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Thanks for the praise folks! I added some more input to the FAQ based on your post Mike, thanks.
Old 04-12-2004, 09:51 PM   #38
Mike Wevrick
Member#: 24654
1957 Taggart Comet
oops, lost my question in bad coding:
Old 04-12-2004, 10:11 PM   #39
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Depending on which of the 9000 websites you believe, deionized water is purer than distilled. More pure = better. As with many of my "facts", there is controversy on this issue with an associated high geek factor that I don't even want to go into. Even though it's "better" I have no clue in the world where anyone would go to get deionized water though. I did find it online @ $30/gallon, so I would assume that 99% of readers will just "settle" for distilled.
Old 04-12-2004, 11:27 PM   #40
Homemade WRX
Member#: 33782
96 bastard child
deinonized water takes out all the elements/ions (hints the name) from the water leaving only pure water. I guess all of the ions collect heat or just don't leave contaminates.
*factoid* you can't be electricuted in deionized water
Old 04-13-2004, 01:19 AM   #41
voam
Member#: 33460
2003 WRX Wagon
What about the 2002-3 WRX? Does Subaru recommend using this conditioner for these years as well? Anybody done this? Do you pour it in first, last? How much is in the bottle?
voam is offline   Reply With Quote
Old 04-13-2004, 02:21 AM   #42
WrXsTeel
Member#: 19092
I just got finished doing a flush.. and refill of OEM Subaru Coolant. I have an 03 and decided to put in the conditioner that subaru is now recommending. The bottle is pretty tiny and I put it in after the coolant was full.
WrXsTeel is offline   Reply With Quote
Old 04-13-2004, 10:00 AM   #43
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
This thread talks about it in depth, but basically, if your car is 1999+, you need the conditioner. Add it first, last, or in the middle as it doesn't matter. It is $1.39. This thread talks more about the conditioner specifically.
Old 04-13-2004, 07:32 PM   #44
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
This thread ought to be a sticky.
Coati is offline   Reply With Quote
Old 04-14-2004, 03:42 PM   #45
Johnzim63
Member#: 33330
2002 WRX 5spd sedan
Did they change the oem part number for the coolant? I just went and bought a gallon of undiluted antifreeze from my local dealer, and the invoice says:
"SOA635002 Floor Coolant"
Johnzim63 is offline   Reply With Quote
Old 04-14-2004, 04:35 PM   #46
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
There are two part numbers actually, one for the qt. size and one for the gallon size. I will add them to the main post and thanks for reminding me about this....I forgot to add it a week or so ago when I found out about the two part numbers.
Old 04-15-2004, 08:53 AM   #47
Johnzim63
Member#: 33330
2002 WRX 5spd sedan
Aha. So then it looks like the stealer billed me for (4) quarts rather than (1) gallon for the sole purpose of jacking up the price. Sounds about right for Subaru.
Old 04-18-2004, 01:36 PM   #48
Maicca
Member#: 29143
2000 IMPreza
Camo
This is a great thread!!
Just in time for me to change the fluids
Any special precautions to take when changing out the radiator, also? I plan on going with one of Speed Monkee's.
Maicca is offline   Reply With Quote
Old 04-19-2004, 11:23 PM   #49
Bimmer
Member#: 4116
2002 Impreza TS
I'm such a dunce...
I've got the EndWrench article, complete with illustration, but I still can't figure out where the air bleed screw is.
Please help me out...
Ben
Bimmer is offline   Reply With Quote
Old 04-20-2004, 09:44 AM   #50
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Originally posted by Bimmer
... I still can't figure out where the air bleed screw is.
There is no air bleed screw. This link will help you get any trapped air out.
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 705 05-17-2016 10:30 PM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 378 12-27-2015 07:49 AM
Oil FAQ: Read if you want more information on oil, oil filters, and oil changes! Unabomber Service & Maintenance 1061 10-22-2015 10:38 PM
Tool FAQ: Read if you want information on Subaru specific tools and sundries Unabomber Service & Maintenance 41 08-16-2014 04:59 PM
