Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2015
Old 12-20-2004, 09:57 PM   #101
rogerd
Member#: 59934
2005 Legacy GT Wagon
Atlantic Blue
Ya know, a coolant conditioner is going to do NOTHING to prevent blown head gaskets.
Head gaskets blow due to the combustion pressures effectively exceeding the "sealing strength" of the studs/bolts that hold the head to the block. Whether the coolant is water, glycol, or whatever is pretty much irrelevant.
Head gasket problems are not uncommon where engines have been "pushed" by the manufacturer or aftermarket to larger bores (and hence smaller sealing areas) than the original design (as in pushing a 2.2 to a 2.5). It's also in my experience, much more common with alloy heads than iron heads. In fact, the only head gaskets I have ever had "spontaneously" blow have been with alloy heads. The only times I have had to deal with iron heads blowing gaskets were due to the engines being run very low on coolant and severely overheating.
What to do? About the only pro-active step you can take to head off (bad pun) the problem is to re-torque the head(s) after the break in period following initial (factory) build, or a rebuild. That way, at least you know that it is properly screwed down. And of course, make sure you never, never, ever over heat.
Oh, and once an alloy head has blown a gasket, 90% of the time it is no longer 100% flat - either warpage, or erosion due to combustion gas blowby. So, get it skimmed before you re-install, or it will blow again. And if, like Subarus, the block is alloy, check the mating surface for flatness very carefully also.
rogerd is offline   Reply With Quote
Old 12-20-2004, 10:34 PM   #102
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Silly boy, let me educate you....
SOA: Did you use the Subaru Cooling System Conditioner with each coolant service?
Customer: No
SOA: Your head gasket install will run you $XXX
You didn't see the math did you rogerd?
BTW, you are right, but I think you can see the logic in my illogical argument though can't you?
Old 12-20-2004, 10:55 PM   #103
rogerd
Member#: 59934
Atlantic Blue
...like I said originally, selling this snake oil stuff is a "for profit" activity, not a solution to a problem. Equally, all SOA claims in the documentation is that it stops leaks - no mention of head gaskets at all. My message was meant for the many out there who are not under warranty - like most in that 97-00 window; in warranty, you play by the rules of the game. Outside, you can apply logic. And "beware of overheating your aluminum engine" is probably the most important message.
Old 12-21-2004, 07:08 PM   #104
Rosco ReX Rox
Member#: 31294
2002 Impreza WRX
Default Behave ladies!!!
Unabomber and rogerd,
Can we please get along? Let's see if cooler heads prevail.
1. SOA's snake oil is for profit, but will protect all of us subie owners from big, bad SOA profit makers. Given the whole grand total of +- $15.00 for a gal. of SOA coolant snake oil, the SOA coolant additive snake oil and the distilled water, I'll bet y'all we've already spent WAY TOO MUCH effort over ... nothing!!!
2. Given the potential costs of damaged water pumps, clogged radiators, blown head gaskets, poor performing cooling, etc. $15.00 WINS.
3. Give big, bad SOA profit their $15.00 = keep your ride running fine with the snake oil.
NO BRAINER!!! Come on girls, much a do over... nothing!!! If we were discussing $150.00 or more, I'd say; let's get into it, but for the cost...
There you have it.
Rosco
Rosco ReX Rox is offline   Reply With Quote
Old 12-21-2004, 07:18 PM   #105
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
We actually see eye to eye, we're just messing around. The Subaru coolant isn't snake oil though. It is the 100% correct coolant for your car, but since it's a private label of Subaru, it's pricier. The same rules apply for Honda or Toyota branded coolant. The coolant conditioner though....that's up to interpretation and I tend to agree with rogerd that the main cause of the problem is something else. I personally doubt a $1.50 bottle of a rebranded Holt's (English version of Bar's Stop Leak) is going to save my head gasket.
Old 12-21-2004, 08:39 PM   #106
Jon [in CT]
Member#: 2992
02 WRX Sedan
I see you've got a know-it-all newb on your hands, Unabomber.
The idea that SOA chose to introduce the coolant conditioner requirement as a "for profit" activity is ludicrous. The coolant conditioner was introduced as part of a "service campaign" (a recall, though not a mandated safety or emissions recall - strictly voluntary) which involved hundreds of thousands of Subarus and the only action was to add the coolant conditioner. For those owners who responded to the campaign, SOA extended the warranty for cylinder head gasket external coolant leaks to a period of 8 years or 100,000 miles, whichever occurs first, from date of delivery. That campaign probably cost a mint.
SOA explicitly claims both in the service campaign bulletin sent to dealers (see http://forums.nasioc.com/forums/show...readid=4881570) and in emails sent to affected owners (see http://www.scoobymods.com/forums/sho...04&postcount=5) that the coolant conditioner prevents coolant leaks from developing and corrects existing coolant leaks at the head gaskets. SOA also explained to its dealers' service technicians, via its monthly Subaru Tech T.I.P.S. newsletter, exactly how the new coolant conditioner works to seal off head gasket coolant leaks (see http://www.scoobymods.com/forums/att...achmentid=2666).
But, feel free to ignore SOA's recommendations.
Jon [in CT] is offline   Reply With Quote
Old 12-22-2004, 11:12 AM   #107
Rosco ReX Rox
Member#: 31294
2002 Impreza WRX
Default What he said!!
Yeah... go ahead, don't add the $1.50 coolant conditioner.
Una and rogerd, nothing to it. I just think its silly to avoid spending an inisgnificant amount of $ to get a lot of peace of mind. I don't know about you guys, but facing the possibilty of big dollar repairs and the down time without our rides isn't the way to go. The downside to all this nonsense is less than $20.00 for us shade tree types. Go shade tree types.
Happy holidays all
Rosco
Old 12-23-2004, 10:09 PM   #108
esteve
Member#: 28716
2006 STI
Are there any possible downsides to using stop leak on a regular basis, like with every coolant change, especially if you car has no leaks or head gasket issues? I read it might plug up heater cores or even radiators but there's not much info about it.
I think it's interesting that using regular EG coolant is a big no-no because it can damage seals even though you can't even see the silicates in there they're so tiny, but it's ok to pour that thick brown gravy in there every coolant change. Those particles floating around can't be good for the water pump seal...I guess that's my main concern.
How does stop leak "lube" the water pump? Bar's claims it does that, and I'm guessing Holts is the same thing.
Maybe I'm being paranoid, but I'm really curious about this. I did add the conditioner when I did the 30K mile coolant change.
esteve is offline   Reply With Quote
Old 12-24-2004, 10:35 AM   #109
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
I wouldn't use Bar's as it's not recommended by Subaru. I can feel your pain about the additive, but we can only place our trust in Subaru that Holt's thick brown gravy is doing good by our cars. I have no idea how Bar's or Holt's does what they say they do, so I push that big imaginary "I Believe" button.
Old 12-26-2004, 04:40 PM   #110
rogerd
Member#: 59934
Atlantic Blue
As the "know-it-all newb", who happens to have a Master's in mechanical engineering, and years of automobile design and development experience behind him, I stick by my point. Additives do NOT fix head gasket problems in any way shape or form. Manufacturers do "own brand" products to make money - be it oil, coolant, parts, whatever. They could easily specify what we should buy - but that way, they and their dealers don't make money.
Don't get me wrong, if I have to pour some SOA magic gunk into the car to maintain warranty coverage, I will do it - I'm just more realistic than most as to its efficacy.
As to Holts and Barrs - that's the stuff I used to pour into clunkers when I had no money to fix them.
Old 12-27-2004, 08:57 PM   #111
banman
Member#: 12408
2006 Legacy GT
Here's a question to bring the thread back on track from the additives and coolant types discussion: where the heck is the "air bleeder/breather screw" for the radiator? It refers to it in the service manual, but I'll be damned if I can find it! I changed my coolant without ever figuring out where this thing was . . .
banman is offline   Reply With Quote
Old 12-27-2004, 09:40 PM   #112
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
What service manual are you referring to? I don't see that in the 02 factory manual that I have. There is no bleeder for the radiator, just the drain plug at the bottom.
Old 12-27-2004, 09:54 PM   #113
rogerd
Member#: 59934
Atlantic Blue
I just hope that Subaru is not using Holts Radweld or similar as a fix, as was implied by one of the posts. Used to excess it may clog heater radiator cores, which have narrow pathways - in fact Rover specifically disapproves of its use for this reason (see the Holts web site). Btw, Holts also makes "piston seal" a substance to "seal" up sloppy pistons in their bores to stop oil consumption, plus additives to fix gearboxes and Redex, an oil you pour into your gas tank, etc., etc.
The plain fact is that a modern well designed, properly screwed together engine does not leak - until the water pump goes home at what should be around the 100k marker at least. It also does not blow head gaskets unless it is severly overheated.
Like I said, if it's needed for warranty, so be it. But no way would I pour any of this stuff into a vehicle of mine by choice.
Old 12-27-2004, 10:20 PM   #114
banman
Member#: 12408
2006 Legacy GT
Step 8 in the page pictured on the first page of this thread, and it's also mentioned in this PDF on page 10:
http://www.endwrench.com/current/win...ngineMaint.pdf
(It says "to refill the cooling system, remove air breather plug from radiator")
Old 12-27-2004, 10:34 PM   #115
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
That link and the accompanying pics are not WRX-specific, just general Subaru maintenance. The WRX radiator has no bleeder.
Old 12-27-2004, 10:58 PM   #116
banman
Member#: 12408
2006 Legacy GT
OK, but it does say (turbo model) after step 8.
Old 12-27-2004, 11:02 PM   #117
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I was referring to the endwrench link. The manual excerpt in this thread does not actually refer to a breather plug, just a bleed hole in the filler neck of the radiator under the cap. If you have an 02 WRX you don't have this either as your radiator doesn't have the cap.
Old 12-27-2004, 11:05 PM   #118
Jejunum
Member#: 15773
2011 Impreza WRX
Customer: No
does the coolant conditioner apply to all subarus? when i called my dealership about it they were like uhhh huh?
Jejunum is offline   Reply With Quote
Old 12-28-2004, 06:19 AM   #119
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
Your dealer = ignorant. It applies to ALL Subarus.
You have an 05 so that Holt's stuff is already swimming in your coolant.
Old 02-12-2005, 09:07 AM   #120
Amazake
Member#: 9889
What about a coolant flush? There are generally three ways to perform this:
a. After the system is drained, many fill up the radiator with regular or distilled water alone. Then heat cycle, cool, and drain.
b. After the system is drained, fill up the radiator with a "radiator flush" product and water. Then heat cycle, cool, and drain, and then run clear water through to wash out any traces of the product.
I have an odd case here: My garage uses well water that is NOT suitable for drinking. The garage is in an industrial area and I would assume the groundwater is quite toxic. Who knows what is in it.
Should I use the well water for the flush?
Amazake is offline   Reply With Quote
Old 02-13-2005, 10:43 AM   #121
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
I'd definately skip a well water flush. Non-potable water such as well water is loaded with sulfer, iron, and all sorts of not aluminum friendly stuff. I'd also bring in water in jugs to triple ensure they don't use well water for the regular fill.
Old 03-27-2005, 07:17 PM   #122
rexsquared
Member#: 71748
2002 WRX Sedan
World Rally Blue
I'm curious as to why you rank deionized above distilled. Deionized is just that...no ions but it can be chock full of nonionizable stuff (organics.) Distilled water is generally considered to be of higher purity than deionized.
rexsquared is offline   Reply With Quote
Old 03-27-2005, 08:46 PM   #123
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
I can't recall right now as I found that somewhere on some website or other in my research for this article. The whole "which is better" topic can be argued though and as long as you use either, you are fine.
Old 07-04-2005, 10:53 AM   #124
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Forester
Peaty is offline   Reply With Quote
Old 07-28-2005, 12:13 AM   #125
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
^^interesting ... so phosphates are OK as long as they are "non-amine" whatever that means
Also, I have an old partial jug of cheapo Supertech coolant that lists the ingredients as ethylene glycol, diethylene glycol, and water. Does that mean it has no silicates or phosphates?
Mike Wevrick is offline   Reply With Quote
Oil FAQ: Read if you want more information on oil, oil filters, and oil changes! Unabomber Service & Maintenance 1040 03-19-2015 10:26 AM
Spark Plug FAQ: Read if you want spark plug information! Unabomber Service & Maintenance 692 12-21-2014 02:42 AM
Uppipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 370 11-11-2014 04:51 PM
Tool FAQ: Read if you want information on Subaru specific tools and sundries Unabomber Service & Maintenance 41 08-16-2014 04:59 PM
