Old 02-16-2004, 05:43 PM   #1
GTR STI
Member#: 45209
2004 STI
Default MAF or MAP signal for Emanage??
I'm trying to wire my E-manage, and am not sure whether to use the MAP signal, or MAF signal. I would assume map signal, but who knows. Also, is it just me or is there a mistake in the wiring diagram for the STI. For the ignition the diagram goes
#1 = 18
#2 = 17
#3 = 16
#4 = 16 (I would assume they meant 15)
Also, this question is kinda dumb but when it comes to electronics you never know. Is the Accelerator Position Sensor the same as the TPS sensor? I know the STI has electronic throttle, just not sure if those sensors function the same.
Final question, would it be alright to use the Power supply and ground for the main unit power supply?
Thanks for the input
Chris
GTR STI is offline   Reply With Quote
Old 02-17-2004, 02:08 AM   #2
redrexx
Member#: 36568
02 sedona WRX gone
04' Silver STi in affect
Seems that you are the only one brave enough or stupid enough to tackle this install unguided. We'll just say "brave" for the time being. E-manage is great, but the problem is that everyone will do it differently. Greddy has about 4 or more different harnesses and a sensor or two that are all bought seperately to customized your setup. That's great, but only if you know what you are doing. I would suggest you take your car and the unit to someone who knows both the E-manage and the STi well. That may be a tough combo to order. I know Dan can serve you up, but pretty much only if you bought if from him, which I assume you didn't.
redrexx is offline   Reply With Quote
Old 02-17-2004, 08:24 AM   #3
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
I believe you want to use the MAF signal, at least that's what's used on the WRX. You'll have to find a pinout of the STi ECU to confirm which wires for the ignition. I'm not sure what you mean by "use the power supply for the main power supply".
The e-manage is a great tool and there is a growing user base, stick with it and I'm sure you can get it to do what you need it to.
lotusTT is offline   Reply With Quote
Old 02-17-2004, 09:49 AM   #4
GTR STI
Member#: 45209
2004 STI
have the pinout, and found out it is the MAF. I need to use a FCD on the MAP.
I would never take my car to anyone to work on except to dyno tune. I have had way to many problems in the past sending my car to people. I'm sure there are plenty of qualified guys out there, but I've been through too much BS!
Thanks guys
Chris
Old 02-18-2004, 01:31 AM   #5
Scrubb_hair
Member#: 55262
1998 Toyota (sorry)
Metalic green
I have just finished work on an STI using the SMT6 piggyback unit; the concept is the same as the E-manage unit. I am not sure what signal I taped into, unfortunately at the time I didnít have a wiring diagram and I was working on the ecu side not the engine bay, but the way I decided which one to use was to cut the wire while the car was running, one wire stalled the engine the other did not.
I modified the wire that stalled the engine, was able to handle fuelling and lock the boost limit on the car so that the user could raise boost.
I have been looking for a reason why they have two sensors on this car and would appreciate it if anyone could explain this to me.
By the way is you are looking for Subaru wiring diagram I found a great link at http://www.northursalia.com/modifica...ng/wiring.html
Scrubb_hair is offline   Reply With Quote
Best Tuning Setup MAF, Blowthru MAF, or MAP? Sko Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 11-11-2007 03:31 PM
Possible bad MAF or MAP on WRX? sponaugle Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 10-16-2001 09:31 AM
WRX....MAF or MAP? Gambit Normally Aspirated Powertrain 12 01-16-2001 04:17 PM
MAF or MAP? Intake help for newbie Jason52 Newbies & FAQs 8 11-30-2000 11:49 PM
MAF or MAP wop Newbies & FAQs 2 10-19-2000 09:38 AM
