Old 02-16-2004, 06:04 PM   #1
ASpec818
Member#: 37059
03 WRX
World Rally Blue
Default for those with oem rubber floor mats, did u lay them over stock carpet mats?
other cars can just lay em over the stock carpet floor mats but for ours, the rubber mats don't cover the carpet mats fully.
ASpec818 is offline   Reply With Quote
Old 02-16-2004, 06:18 PM   #2
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
That's because they're not meant to. Pull out the carpet mats and put the rubber mats in. At the end of the winter, swap them back.
MB38 is offline   Reply With Quote
Old 02-16-2004, 07:02 PM   #3
mbeach
Member#: 39807
Vishnu Stage 2+ !SOLD!
YOu don't want to stack them up. The rubber mats tend to migrate toward the front of the car. If both mats get jammed under a brake pedal, you might have some troubles.
mbeach is offline   Reply With Quote
Old 02-16-2004, 07:24 PM   #4
philodox
Member#: 40522
2004 WRX Wagon
Actually, I've had more problems with movement of the rubber pads when it is JUST the rubber pad there... i've had clutch engagement issues because the rubber mat had slid so far forward. I put my rubber mats on top of my regular floor mats and they stay in place 100% of the time. It may have something to do with the regular floor mats have 2-3x as many little pin things to hold it in compared to the rubber ones, and the rubber pins being able to hold into the deeper carpet on the floor mats better than just the thinner carpet on the floor.
philodox is offline   Reply With Quote
Old 02-16-2004, 08:30 PM   #5
mbeach
Member#: 39807
Might have to try that. My rubber pads slide up behind the pedals all of the time. I figured that an extra pad might be enough to cause some trouble.
If that doesn't do it, I'm going to poke some holes in the pan and bolt them down.
Old 02-16-2004, 09:50 PM   #6
InfamousDX
Member#: 25413
I took out the carpets... rubber mats for winter and come spring, the regular carpets are goin' back in.
Old 02-16-2004, 11:32 PM   #7
03WRXMA
Member#: 35081
2012 WRX
Just use one rubber
Seriously, the rubber mats alone are fine, and the grips on the bottom keep them in place
03WRXMA is offline   Reply With Quote
Old 02-17-2004, 07:56 AM   #8
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
My rubber mat migrate forward too. I have to pull them back a couple times a week.
I want to do something to hook them to the peg that holds the carpet mats in.
dbrier is offline   Reply With Quote
Old 02-17-2004, 09:04 AM   #9
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
I have my rubber mats over the stock mats and they move maybe an inch or so during the course of every week or so. This setup has served me really well as my stock carpeted mats are in new condition still
Doesn't ever get in the way of the pedals either
Hank3 is offline   Reply With Quote
Old 02-17-2004, 09:23 AM   #10
Desolate One
Member#: 22797
2003 WRX Wagon
The dealer just threw my rubber mats on top of the carpet mats and I've never had a problem with movement. Initially I was going to take out the carpet ones but got too lazy and now it's been that way for over a year!
Desolate One is offline   Reply With Quote
Old 02-17-2004, 10:03 AM   #11
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
I don't have the Subaru rubber mats but the ones I bought from Target go over my stock carpet mats.
MAD REX is offline   Reply With Quote
Old 02-17-2004, 11:10 AM   #12
NeoteriX
Member#: 20999
2002 PSM WRX Stg 2
knee - Aw - teh - rix
I have the rubber mats over the stockers. They work absolutely fine, no movement.
NeoteriX is offline   Reply With Quote
Old 02-17-2004, 11:28 AM   #13
z wrx
Member#: 15443
2002 clownshoe
I took the regular ones out a long time ago. I just run the rubber ones all year round.
z wrx is offline   Reply With Quote
Old 02-17-2004, 11:39 AM   #14
Uncle Ben
Member#: 28628
2003 WRX Sedan
World Rally Blue Pearl
I have the rubber ones over the stock carpet, works fine that way... keeps the carpeted ones minty fresh too
Uncle Ben is offline   Reply With Quote
Old 02-17-2004, 12:51 PM   #15
FortyTwo
Member#: 39738
2003 Impreza WRX
Midnight Black Pearl
I have the rubber mats by themselves. For those of you with movement problems, try putting a small hole in the back left corner and looping a zip tie to the mat anchor.
FortyTwo is offline   Reply With Quote
Old 02-17-2004, 08:11 PM   #16
ASpec818
Member#: 37059
03 WRX
World Rally Blue
for those with the rubber mats over the stock carpet mats, do the rubber mats fully cover your stock carpet mats? i noticed that there are many uncovered areas. looks like the rubber floor mats are a lot smaller. hope i didn't get a wrong size or anything.
Old 02-17-2004, 10:27 PM   #17
snoballz
Member#: 52604
2004 WRX - sold :(
San Remo Red
The all-weather rubber mats are smaller. I have them over my stock carpet mats without movement.
snoballz is offline   Reply With Quote
tread for those who missed the wbm, what did you do? beavis820 New England Impreza Club Forum -- NESIC 49 05-21-2006 06:36 PM
For those with OEM rear lip snvin Interior & Exterior Modification 7 02-16-2005 11:03 PM
To those with MRT boot tank- how did you mount it? tifosi77 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-03-2002 01:17 AM
For those with 17" rims, what tires are you guys running in snows? malelee21 Brakes, Steering & Suspension 15 10-24-2001 06:33 PM
