Old 02-16-2004, 09:03 PM   #1
Mr. Mercado
Member#: 36559
2003 Impreza WRX
Default HELP! Both Low Beams out!
Hey guys,
BOTH low beams are out on my WRX, but my high beams work just fine.
Anybody have any idea what the problem is? My parking brake is fully down, and the switch is positioned on. What are the odds that BOTH bulbs are blown?
PLEASE HELP!
Thanks,
Ryan
Mr. Mercado is offline   Reply With Quote
Old 02-16-2004, 10:00 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It's very possible that both low beams are blown. If you haven't disabled your DRLs the low beams are on all the time and will burn out sooner than they would normally. Also if you happen to have aftermarket bulbs they tend to not last as long as OEM type ones.
Old 02-17-2004, 04:17 AM   #3
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
it's easy enough to remove the driver side bulb to take a look at it... check if either of the filaments is burned and just dangling there. The "lowbeam" filament is the one right in the center of the glass whereas the highbeam filament is the one that's off-center inside the glass...
(this is for a 9007 bulb which is what comes in the '02/'03 wrx)
nhluhr is offline   Reply With Quote
Old 02-17-2004, 02:10 PM   #4
BLOW
Member#: 33477
I had that happen once, the dealer replaced a fuse in the engine bay fuse box I think. But it was a fuse problem
BLOW is offline   Reply With Quote
Old 02-17-2004, 06:55 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
A blown fuse will take out both high and low beams as the headlights have common power. Also there are separate fuses for the left and right sides.
Old 02-17-2004, 10:34 PM   #6
Mr. Mercado
Member#: 36559
2003 Impreza WRX
hey guys,
took a peek at the bulbs, and yes they were blown. What are the odds that both went.
The sad thing was is that they were PIAA!
Thanks for your help!
Both low-beams went out at the same time..help! andron Electrical & Lighting 14 03-03-2011 10:10 PM
both low beams went out at the same time, huh? pumpkyn Electrical & Lighting 5 08-28-2007 08:12 PM
low beam out, but high beam still works? pogomonkey Electrical & Lighting 2 12-08-2004 02:13 AM
Both low beams are gone! OBSS General Forum Archive 7 02-01-2001 06:45 AM
