Old 02-16-2004, 09:46 PM   #1
Facerake
Member#: 55137
Unhappy Fan Rationality code
I own a 99 Subaru Forester. I took it to the dealer for what I thought was a water pump going bad. It turned out that the code they pulled on the diagnostic was 483 Fan Rationality code. What happens is the radiator fan does not come on for some odd reason and it loses coolant. They told me that this code has occured only three times in the past five years and they do not know what it means. All I can do now is keep checking my coolant level once a week. Can anyone tell me what this code means and what to do about it?
Facerake is offline   Reply With Quote
Old 02-16-2004, 09:52 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
If your fans are not working, then logic seems to dictate the coolant temp sensor is not as well. I'm sorry to say that you are probably loosing coolant because your headgaskets are gone.
Brian
Old 02-17-2004, 12:59 AM   #3
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
Similar incident happened-water pump failed and away went the gasket.
joubtt is offline   Reply With Quote
Old 02-17-2004, 05:35 AM   #4
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
were you guys seeing overheating symptoms with the bad pump?
mine leaked a lil before i replaced it but didn't notice bad loss or overheating
overdose is offline   Reply With Quote
Old 02-18-2004, 10:54 PM   #5
Facerake
Member#: 55137
Default Coolant Fan
What is a 483 Fan Rationalitycode? The dealer said they have only had this diagnostic code three times in five years. I am losing coolant because something is not telling the fan to come on when needed at times. Sometimes it runs normally. The dealer had no recommendations.
Old 02-18-2004, 10:58 PM   #6
billzebub
Member#: 40248
2003 WRX
Midnight Pearl (black)
Wha? Switch dealerships. They don't know their own codes?
billzebub is offline   Reply With Quote
Old 02-18-2004, 11:06 PM   #7
Facerake
Member#: 55137
This same code has come up more than once on the same car with different diagnostics. The same problem keeps occuring. They said that the fan motor is probably fine.
Old 02-19-2004, 02:06 PM   #8
joubtt
Member#: 33901
04 04 STI
Old 02-19-2004, 10:46 PM   #9
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
P0483 Cooling fan function problem
Find a different dealer.
If they cant fix your car they shouldnt be in business.
Likely as brian said you probably have leaking head gaskets.
A fan not comming on is not going to make you lose coolant unless the car starts overheating and the coolant overflows.
the reason your getting the code is because the ECU is likely commanding the fans on and they are not turning on, its says hey I commanded you on, and your not working, hmm let me turn on the check engine light cause this is not normal.
Try this, turn the car on, then turn the A/C on, the cooling fans should come on.
If they come on, you know the fans are good, if they dont then you have to start checking wiring.
if you are not capable or dont have the means/knowledge to do this yourself, find another dealer.
Jay
Old 03-01-2004, 08:44 AM   #10
Brindor2.5
Member#: 40657
2008 Impreza WRX
Spark Silver
Default fuses blown
well i'm getting this "cooling fan raionality check" code right now. The check engine light had come on so i did a full look over and found that the fuses for my fans were blown. Put new ones in and fans are running but still pulling this code. Should the check engine clear if self or do i have to clear it? Might there be something i'm missing or should check?
Brindor2.5 is offline   Reply With Quote
CEL P0483 Cooling fan rationality check malfunction Loki Service & Maintenance 13 10-31-2012 03:46 PM
P0483 Cooling Fan Rationality Check Malfunction RS2001 Service & Maintenance 6 09-10-2009 09:29 PM
P0483 Control Fan Rationality Check Malfunction Sudaka Service & Maintenance 7 03-25-2009 01:40 AM
cooling/radiator fan rationality check? boshot427 Normally Aspirated Powertrain 0 03-22-2007 08:22 PM
p0483- cooling fan rational Rubasu Normally Aspirated Powertrain 2 11-12-2003 09:47 AM
