Old 02-17-2004, 08:37 AM   #1
BrianH
Bing user
Member#: 44383
Default Greddy 60MM Electronic EGT Gauge
I've got the 60mm electronic greddy EGT gauge , and it works fine the only problem is that it doesn't light up when I turn my lights on. I know that the wiring in it works as I can plug it into either my boost or my oil pressure gauge and it works fine. Has anyone ever torn into one of these and dissasembled it? Is there any chance of it just being something burned out? The gauge itself does its job just fine, illumination is the problem.
Thanks
BrianH is offline   Reply With Quote
Old 02-17-2004, 11:15 AM   #2
tdxflex
Member#: 13634
Get a multimeter or test light and check the illumination wire from the gauge. If the bulb is burnt, it should just be an open circuit and the illum wire should still read 12v. If it doesn't read 12v, I would guess either the connection or the wrong wire was used, but probably not the wrong wire since you said it's the same one for your other gauges. Are you use crimp, solder, or vampire clips?
tdxflex is offline   Reply With Quote
Greddy 60mm electrical EGT gauge gomikeyp Electrical & Lighting 3 06-19-2006 08:49 AM
FS: GReddy 60mm electronic temp gauge Peak/warning Twerthi Private 'For Sale' Classifieds 6 08-27-2005 11:34 PM
FS : NJ / Greddy 60mm Electronic Boost Gauge TRICMAN2004 Private 'For Sale' Classifieds 6 04-30-2005 06:43 PM
FS: Greddy 60mm Electronic Boost Gauge Tb311 Private 'For Sale' Classifieds 6 09-21-2004 05:17 PM
Ca: Greddy 60mm electronic boost gauge, kartboy shifter bushings, pictures inside STEALTH-WRX Private 'For Sale' Classifieds 4 02-13-2004 12:08 PM
