Welcome to the North American Subaru Impreza Owners Club Friday April 18, 2014
Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 02-18-2004, 07:23 AM   #1
SleeperXT
Member#: 47902
2004 Forester XT
Red
Default Cold Start Tip
My 04 XT has always cranked about 5 revolutions before turning over. Here is what I noticed. If you turn the key to the position just before the starter crank position for about 2 seconds, just until you here the whine from the fuel pump stop, then crank the starter, it fires right up! Check it out.
Chas
SleeperXT is offline   Reply With Quote
Old 02-18-2004, 09:41 AM   #2
Caddy Daddy
Member#: 11070
2004 SG9, '77 R100/7
'00 Ducati ST2
good call
Caddy Daddy is offline   Reply With Quote
Old 02-18-2004, 11:49 AM   #3
Ghostrider600
Member#: 37992
06STI 09STI 09LegSE 99RS
Mine always starts first crank, third if it's -10F, but thanks.
Ghostrider600 is offline   Reply With Quote
Old 02-18-2004, 12:35 PM   #4
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Could be an indication your battery is going south for what ever reason. A trick to getting a cold battery going is to put the key in the on position for a few min and turn on the lights (in this case low beam DRL's) this sends juice through the battery and makes it warmer helping it start quicker. Just a thought.
Peaty is offline   Reply With Quote
Old 02-19-2004, 10:22 AM   #5
GuyLR
Member#: 21811
2003 WRX Wag/01 OBS
WRB and SM
Also sounds like the fuel rail is bleeding down and that the fuel pump takes a few seconds to bring the pressure up at the injectors. My '01 does that sometimes so I'll give it a try.Thanks.
GuyLR is offline   Reply With Quote
Old 02-19-2004, 10:24 AM   #6
Corkfish
Member#: 39503
Frankly, I don't think I want my engine to fire right up on a cold day. I'd rather crank it to get some oil flow first.
Corkfish is offline   Reply With Quote
Old 02-19-2004, 05:41 PM   #7
Tom Bombadill
Member#: 2386
2002 BMW 330i
Titanium Silver
I always wait for the six key-chimes and then crank.
I figure that will give some pressure to the system.
Tom Bombadill is offline   Reply With Quote
Old 02-19-2004, 09:22 PM   #8
bozman9
Member#: 48814
2006 Legacy GT SpecB
Platinum Silver
Excellent tip! I'll give that a try; it is frequently below zero here in the winter. Brrrrr!
-Bozman
bozman9 is offline   Reply With Quote
Scratching/Scraping sound when cold starting speedracer47 Normally Aspirated Powertrain 14 05-23-2010 04:52 PM
('93-'01) Cold starting up my Impreza RS 2001 AliasAngel Impreza Forum 17 06-01-2001 09:35 AM
Just how bad ARE those cold starts? 8Complex Normally Aspirated Powertrain 23 12-20-2000 06:08 AM
Cold start - revisited Steve00RS General Forum Archive 3 12-18-2000 07:07 PM
Cold starting mrbell General Forum Archive 5 12-16-2000 11:39 AM
