Old 02-18-2004, 11:54 PM   #1
shortfuseWRX
Member#: 38573
1997 toyota tacoma
Black death
Default misfiring problems
hey guys i jus thave a few questions that need answering.
i have an 03 wrx that has a fmic stage 4 on it and is having very bad misfiring problems. currently it is an unspecfic misfire and i cant seem to be rid of it. i took it to my dealershipa nd they said they wont even work on it. i hav ereplaced everything that it may have been like plugs and coils. fuel system has been checked twice. compression, timing, everything. the shop it took it too think it may be the utec i have, but when it is disconnected the car does the same thing, mifiring at idle and throughout the entire powerband that is. so now they're gonna try the valve stiffness and spacing. so as you can see im in a pickle of a situation. and thing that would help me diagnois this problem would be much appriciated. thanks
sam
shortfuseWRX is offline   Reply With Quote
Old 02-19-2004, 12:47 AM   #2
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
Does the car run fine, just like all of these guys?
http://forums.nasioc.com/forums/show...hreadid=401993
I've been getting misfires lately. But I think I know what caused mine. They're not just random.
Pete
eastcoastbumps is offline   Reply With Quote
Old 02-19-2004, 12:50 AM   #3
shortfuseWRX
Member#: 38573
1997 toyota tacoma
Black death
wow thanks for the info pete. yeah my car runs a lot liek that but we checked everything and still cant think of whta it could be, everything they talked about on the thread that is. and i aslo forgot to mention that i have burn out several coils. they're thinking it may be my plugs. i have the smae heat range plugs but with an iridium element.
Old 02-19-2004, 08:45 AM   #4
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
How does the car run with a burnt out coil? Im' guessing its really rough, misfiring on every revolution.
Old 02-19-2004, 12:42 PM   #5
j-speedracer
Member#: 48897
02 WRX
how do you recognize a misfire? is it anything like the pinging of detonation?
is throwing a code the only way to tell?
j-speedracer is offline   Reply With Quote
Old 02-19-2004, 06:34 PM   #6
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
Throwing a code is the only way to tell. I've been getting misfires all the time and the car seems to run fine. But my car actually has a problem, unlike the cars in that other thread.
The engine uses crank angle velocity to determine if a cylinder doesn't fire. It uses sensors and crazy calculations to figure it out.
Pete
Old 02-19-2004, 07:20 PM   #7
SubieRacer
Member#: 775
i know this may sound dumb...but...could it be a bad tank of gas??
might be worth trying different gas.
SubieRacer is offline   Reply With Quote
Old 02-19-2004, 08:11 PM   #8
shortfuseWRX
Member#: 38573
1997 toyota tacoma
Black death
yeah i tried that soulution i spent over 100$ on dumping out and filling up with gas. i even flushed the system twice. so it isnt gas.
runnign with a burnt out coil is like turely running on three cylinders. no hp, and no throttle response. you have to slip the clutch a lot to get it to go and keep the revs up long enough to go. very bad felling. i guess it would feel liek you car is about to stall all the time but it keeps going, that is the best expalnation i can give you.
Misfire problems fellfrosch7 Service & Maintenance 7 04-26-2005 05:03 PM
Misfire problems WRX98Outback Factory 2.0L Turbo Powertrain 0 12-26-2004 03:06 AM
Misfiring problem please help Pochebum Factory 2.0L Turbo Powertrain 13 05-12-2004 03:54 PM
misfiring problem weaversm Service & Maintenance 2 12-17-2001 10:06 PM
My misfire problem.... solved! 8Complex Mid West Subaru Owners Club Forum -- MWSOC 15 07-16-2001 04:07 AM
Message Board Statistics All times are GMT -4. The time now is 11:22 PM.
