Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 02-19-2004, 01:26 AM   #1
DrivenByWhatsInside
Member#: 55250
2002 WRX sedan
wrb
Angry Problem with parking break light.
here's the problem. I start my car release the parking break lever, drive off and then get pissed off. Its because my parking break light on the dash remains lit. After good 10 minutes of driving, the light would sometimes shut off. But, sometimes it would turn on and off continuously for a long period of time. Its a really frustrating and confusing situation.
Any help in this matter would be GREATLY appreciated.
DrivenByWhatsInside is offline   Reply With Quote
Old 02-19-2004, 01:26 AM   #2
DrivenByWhatsInside
Member#: 55250
2002 WRX sedan
wrb
oh, by the way, I have an 02' WRX (bone stock)
Old 02-19-2004, 02:02 AM   #3
Hawk296
Member#: 14555
1995 Impreza L
Baja
on the older models the same light comes on when the brake fluid is below a certain point. Maybe check the fluid.
Do the daytime running lights turn on when you release the parking brake or do they stay off?
Hawk296 is offline   Reply With Quote
Old 02-19-2004, 06:12 AM   #4
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Yes, it's not just the parking brake light, but the brake system trouble light. I'd take it in to have things checked out.
Old 02-19-2004, 08:11 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If the fluid level is low check your pads first. As the pads wear and the pistons move outward in the calipers the fluid level in the reservoir will drop. If the level drops below a certain point it will trigger the warning light. This is the only reason for the fluid level to be low other than a leak.
If you just fill the reservoir to make the light go out and then change the pads later, the fluid may overflow when the new pads are installed.
Old 02-20-2004, 06:15 PM   #6
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Peaty is offline   Reply With Quote
Old 02-24-2004, 04:22 PM   #7
Imprexa
Member#: 55472
And the whole time i was tweaking with the parking brake system trying to find a solution.
The parking brake light stays off,
thanks hawk
Imprexa is offline   Reply With Quote
Old 02-24-2004, 04:25 PM   #8
Imprexa
Member#: 55472
By the way guys,
Thanks a lot, you saved me many hours and days of stress.
Old 02-24-2004, 04:30 PM   #9
Imprexa
Member#: 55472
One thing for you guys out there having the same problem as me is that you'll notice that when you accelerate, the parking brake light would turn off. Here is the reason(thanks to Peaty)
Brake fluid takes up the space behind the piston making the brake fluid level go down. If the light is flickering it probably happens on acceleration or a sharp turn because the brake fluid is sloshing around. Another thing that may make it come on is the float inside the reservoir is stuck. The float has a sensor on it to let you know when the level gets low. If the level looks good and the light is on check that the float isn't stuck. Barring any of those things the e-brake switch that tells you it's up may be broken, but not likely.
Problem with Park Sefu Legacy Forum 0 04-26-2006 05:48 PM
headlights only off with parking break? WRXminion Electrical & Lighting 5 12-26-2005 06:48 PM
Any problems with using fog light switch for WI? fragment Electrical & Lighting 0 07-28-2004 04:36 PM
Electrical Problem with Daytime running lights NEED HELP! smiles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-30-2002 11:14 AM
('93-'01) problem with a couple lights. Help please! gimpless Impreza Forum 2 04-10-2001 03:29 PM
