Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 02-19-2004, 09:24 AM   #1
drew21180
Member#: 49684
2004 Forester XT 5MT
Default Another ticking noise from engine
A month or so ago I posted a thread on a ticking noise coming from my XT when the engine is cruising around 2500 rpm. This morning I noticed a new ticking noise while driving to work. It only happens when I give it gas (doenst have to be a lot) and it doesnt matter what RPM its at. I didnt drive it far to work, and it was kind of cold this morning, but not Wisconsin cold
Any thoughts? (or new ideas on the previous ticking) Is it something I should be concerned about?
Thanks
drew21180 is offline   Reply With Quote
Old 02-19-2004, 09:30 AM   #2
Corkfish
Member#: 39503
Once again, this is probably the wastegate performing it's normal function. Wastegate flutter.
Corkfish is offline   Reply With Quote
Old 02-20-2004, 12:39 AM   #3
Caddy Daddy
Member#: 11070
2004 SG9, Audi S8
Ducati ST2, BMW R100/7
hey its not that cold here...a week or 2 ago it warmed up to positive temperatures!
its hard to describe sounds with words, but if youre hearing a 'chatter' type of tick, consistent eigth notes tick, then that could be within normal boxer motor sounds. it is not unusal to hear that tick during warmup. ive heard it called different names before, 'valve chatter' or 'valve clapping'. hope that helps. dont forget to check fluid levels periodically.
Caddy Daddy is offline   Reply With Quote
ANother ticking noise thread....please help e-diagnose this!! rendog24 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 33 09-07-2011 02:22 PM
New ticking noise from the engine.. Ashr Normally Aspirated Powertrain 1 07-21-2009 07:52 PM
ticking noise from my engine? vision.dynamix Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 05-12-2009 06:15 PM
help! rough/shaky idle and ticking noise from engine resideinva Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-15-2008 10:57 PM
Another question -- Whining noises from engine at low rpm = good/bad? cerelius Newbies & FAQs 31 06-09-2005 04:00 PM
