Old 02-20-2004, 11:36 AM   #1
jimbo1972
Member#: 54579
Default ECU removal?
I want to get my ECU reflashed by COBB but i tryed to open there file on there web site to show how to remove the ECU buy i could not open it with my computer.
Could someone just give me a brief desciption on where it is located, and best way to remove it.
Thanks for the help
Jim
jimbo1972 is offline   Reply With Quote
Old 02-20-2004, 12:40 PM   #2
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
First unplug the battery and step on the brake until all the juice is drained out (the odo will go blank).
In the passenger footwell...
Three plastic screws for the carpet, pull it back.
There are a couple bolts (10mm I believe) holding on the kickplate. Then two nuts holding the ECU to the floor. The wiring harness is clamped down with one plastic connector.
Then it's as simple as just unclipping the ECU connectors. Sometimes they are hard to get started, but a screwdriver gently used to start the process can help.
Good luck.
mexicanpizza is offline   Reply With Quote
WRX ECU removal instructions? wrbWRX Engine Management & Tuning 3 06-19-2005 01:06 PM
ECU removal instructions TopKatz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-20-2005 11:09 AM
ECU Removal and Price tsdamrow Engine Management & Tuning 1 02-13-2005 05:26 PM
ECU Removal stratdaddy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-15-2004 01:37 AM
ECU Removal...help Matty Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 03-16-2002 08:46 PM
