Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 02-20-2004, 12:50 PM   #1
branshew
Member#: 55492
Default Best way to 4 cyl HP increase?
What's the best way to get an extra 15-20 HP (& some more torque) out of the 2001 Outback w/ a 2.5 4 cyl engine. Cost is a factor, but I am open to all suggestions short of a turbo.
Does anyone make a chip that is less than $600?
I've been comparing this wagon to a VW Passat of the same year (2001.5) Althouth the VW has 170 HP compared to the Subaru's 165 HP, the VW has much more torque available at lower RPM (1800) than the Subaru does and therefore has much better accelleration. Plus, I can chip the VW for under $500 to @ 200 HP.
Overall, I like the Subaru better for its design, reliability, and AWD, but the VW is more peppy and has much better acceleration which is important to me.
branshew is offline   Reply With Quote
Old 02-20-2004, 05:18 PM   #2
bheinz57
Member#: 37870
2012 ISM WRX
'16 Forester XT
Chips are a waste of money. Exhaust, header, lightened crank pulley, CAI..All together will show you what the 2.5 is all about. Brian
bheinz57 is offline   Reply With Quote
Old 02-24-2004, 12:50 PM   #3
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
35 PSI -- in my tires
CAI?
Honkey3k is offline   Reply With Quote
Old 02-24-2004, 03:06 PM   #4
cadillacjake
Member#: 49969
2004 Baja Turbo
Black Granite Pearl
Cold Air Induction
cadillacjake is offline   Reply With Quote
Old 02-24-2004, 03:10 PM   #5
RidinLow
Member#: 329
1995 325i
Arctic Gray
Like most naturally aspirated motors, there is no significant bang for the buck upgrade here aside from forced induction. The WRX and the VW 1.8t's give you huge returns for little money, but no such luck with an EJ25 powered car.
RidinLow is offline   Reply With Quote
Old 02-24-2004, 03:46 PM   #6
anders8
Member#: 26658
1 Love Grassroots
NASA Rally Sport FTW!
All suggestions?
Easy: new rear end gearing.
Anders
(with "rear end" or "final" naturally being somewhat of a misnomer given the drivetrain layout and the two ring/pinions you need to replace.)
anders8 is offline   Reply With Quote
Old 02-24-2004, 03:56 PM   #7
RidinLow
Member#: 329
1995 325i
Arctic Gray
Shorter tires would be a cheaper alternative to regearing. Putting Impreza or regular Legacy height tires would increase the gear ratio by 6% (and increase the speedometer and odometer readings by 6%).
Old 02-25-2004, 12:09 AM   #8
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Lightened pulley set and, if MT, lighter flywheel.
Also, any weight you can pull off - I've read that losing 11 pounds is like gaining one HP. Do you NEED A/C? Does EVERY window need to be able to be lowered? Do you actually USE the rear and passenger seats? Call a tow truck instead of carrying a spare.
1 Lucky Texan is offline   Reply With Quote
Old 02-25-2004, 01:05 PM   #9
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
lol...texans are crazy
Old 02-25-2004, 01:10 PM   #10
anders8
Member#: 26658
1 Love Grassroots
Yeah, maybe it's really "1 Crazy Texan"
Anders
I love Texas! I got a roof scope for my rally car when I was in Amirillo!
Old 02-26-2004, 06:49 PM   #11
bheinz57
Member#: 37870
2012 ISM WRX
'16 Forester XT
No love for Carl? He He.
CAI
Header
Lightened crank pulley
High flow cat section
Cat-back exhaust
Cobb cam(s)
High flow heads
Many ways($$$$$$$) to beef up HP and torque.
It's the AWD sucking it all up driving more than just one or two wheels. Brian
Old 02-27-2004, 10:15 AM   #12
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
No, AWD kicks ass... end of discussion . Getting absolutely no scratch in first or second gear means you have a better chance of winning
Spin a tire, LOSE A RACE!
ej207: best way to increase CR? WReXd Built Motor Discussion 10 03-05-2010 01:34 PM
Best way to increase ride height? jpfurtak Brakes, Steering & Suspension 12 03-06-2008 07:12 AM
Best way to increase torque? warpath Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-17-2005 06:34 PM
Best way to increase low-end grunt? Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 03-01-2005 12:06 PM
best way to add hp knightsnke Newbies & FAQs 31 02-01-2002 01:46 PM
