Old 02-20-2004, 01:03 PM   #1
charliek
Member#: 48973
2004 WRX Impreza
Rally Blue
Have a Nice Day? alignment with STI struts on '04 WRX
I just got STI struts from my friend's '04 STI. And I just installed them on my '04 WRX and was wondering what is a good alignment setting with these new struts on my '04 WRX. Should I stick with the factory specs? New to this alignment issue can anyone suggest a good alignment setting?
Thanks,
Charlie
charliek is offline   Reply With Quote
Old 02-20-2004, 02:30 PM   #2
The Ru
Member#: 4937
95 M3
Alpine White
If your on stock springs still then i dont think you need an alignment(as long as you lined up the front camber bolts the exact postion they came out). But if your unsure, get it done. Its important and could cost you tons of money in tires.
Ride hight mostly messes with suspension geometry.
ian
The Ru is offline   Reply With Quote
Old 02-20-2004, 02:40 PM   #3
loreley
Member#: 19905
depends on what your looking to do with the car.
if your on stock camber bolts and sti suspension, zero toe and max camber f/r are a good place to start for a fast street setup.
loreley is offline   Reply With Quote
Old 02-20-2004, 07:20 PM   #4
Davenow
Member#: 23676
there is almost no chance you got it straight just eyeballing the bolts. You need the alignment anything you loosen those lower bolts.
I personally LOVE
zero toe all around
-1.5 front
-1.1 rear
Old 02-20-2004, 08:43 PM   #5
AustinTexas
Member#: 15971
2000 Scooby
STi
I have :
-2.6 front
-1.4 rear
zero toe.
AustinTexas is offline   Reply With Quote
'06 Sti springs and struts on '04 wrx? Caleb Horst Newbies & FAQs 7 09-15-2009 11:06 PM
'04 STi struts on '02 WRX? fabwrx Brakes, Steering & Suspension 4 09-10-2005 03:14 PM
What Struts will work with STi Pinks on 04 WRX duc748s Brakes, Steering & Suspension 5 01-10-2005 09:44 AM
STI exhaust on '04 WRX Hayaboosted Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 05-07-2004 12:30 AM
Clunking sounds on long lefts with STI struts on GC6 (attention GTGUY) Suba_Roo Brakes, Steering & Suspension 1 08-06-2003 03:09 PM
