Old 02-20-2004, 08:39 PM   #1
stentorian
Member#: 12959
2008 Scion xB
Default GF6/8 Alignment...?
I know I can search for alignment on here but most of what is found is for GC8's etc etc...So how about people with wagons, diffferent or same number? I just finished installing my suspension and will go get alignment tomorrow.
Suspension:
KYB AGX's
Eibach Pro Kit
Cusco Camber plates front and rear
-Joe
stentorian is offline   Reply With Quote
Old 02-21-2004, 09:38 AM   #2
linsavy
Member#: 11620
1997 GF4-STiV3 clone
I run -1.5 front/-0.5 rear camber, zero toe and it works for me. I have an ALK that got me to about 3.3 degrees caster. I will be adding front camber plates this springs and will likely kick the camber and caster up 1.0 each for autox and go back to the above for street use.
I may also put the rear camber closer to -1.0 once the more front camber is available.
The wagon does not need to have 0 rear camber as the added weight and no rear lsd allows it to rotate better. I would rather have a little camber there to help with grip and wear on the rcompounds.
Let me know how noisey the plates are.
linsavy is offline   Reply With Quote
Old 02-21-2004, 02:31 PM   #3
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
Arrow
IIRC, ravensblade-impreza has alignment specs on the site.
EDIT: Found the tech doc. Clicky click here...
Hope this helps...
-mykr.
mykrrrr is offline   Reply With Quote
WTB: 5spd GF6, GF8 Derek.C VIC Private Classifieds 7 06-05-2008 05:22 PM
gf6 bumper from japan on a impreza 1.8l L sedan? acetrouble8 Interior & Exterior Modification 0 11-15-2005 10:05 PM
WTB: MY01 GC8,GM6,GF6 Passenger Crystal Headlight Keo Private 'Wanted' Classifieds 1 01-06-2005 04:09 PM
GF6 HL upgrade nomadtw Electrical & Lighting 0 01-31-2003 11:06 AM
Dec 8 auto-x (Chlt) and wheel alignment Division By Zero South East Region Forum 37 12-03-2001 08:42 AM
