Old 02-25-2004, 05:30 PM   #1
Hit Man X
Member#: 27787
'02 WRX Sedan
Default UTEC compared to TXS Unichip...?
Aside from being able to self tune (I'd only need a cheapo laptop as I already have AutoTap) does the UTEC work better than the Unichip setup? Any reasons to swap them out?
Hit Man X is offline   Reply With Quote
Old 02-25-2004, 05:34 PM   #2
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Sure it works better. It has tons more options and features you can use, and i'm not just taking about silly stuff like launch control or wiring in a spare solenoid or shift light (which you can). I mean like coolent correction, or IAT correction for fuel or timing. Full adjustable knock control, and above 5,500rpms too. It's worth the money.
And being able to switch between differnet maps at the push of a button. Then there is datalogging etc. You just need a laptop able to run windows 95 i guess, although people have used worse lol.
PaulRex is offline   Reply With Quote
Old 02-26-2004, 10:30 PM   #3
GameOver
Member#: 23145
2004 WRX STi
BLUE
Mac compatibility ?!?!?!?!?
GameOver is offline   Reply With Quote
Old 02-26-2004, 10:31 PM   #4
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Unichips are bad, they will work in a pinch but I wouldnt... get something real. A utec with an ecu reflash works realy good!
totoherbs is offline   Reply With Quote
Old 02-26-2004, 11:44 PM   #5
Hit Man X
Member#: 27787
'02 WRX Sedan
I guess they are just limited now-a-days.
How easy is it to setup injector offsets for oversized fuel injectors?
Looks like a UTEC may be the next mod for me.
Old 02-27-2004, 12:01 AM   #6
totoherbs
Member#: 7321
.... 122 IggPoints
Dont try and tune the utec with out a delta dash.
Check out this thread
http://forums.nasioc.com/forums/show...s&pagenumber=2
Old 02-27-2004, 12:58 AM   #7
Hit Man X
Member#: 27787
'02 WRX Sedan
Hrm...I've never cared for the full boost onset at low throttle with the Unichip setup either.
Reading that post led me to consider ECUtek. That seems a LOT like LS1 Edit I used on my Z71...basically controls and can change EVERYTHING on the stock computer (no piggyback crap) for the most linear solution.
LS1 Edit is about a $600 program that is available to the public. Is that ECUtek available like that? It didn't appear so on their site.
If my local tuning place doesn't have ECUtek, can I have them tune a UTEC where it runs smooth like stock?
Old 02-27-2004, 01:07 AM   #8
totoherbs
Member#: 7321
.... 122 IggPoints
A basic ecu reflash and a utec for tweeks is a realy good set-up.
A good utec tuner can have it running good...
Whats your set up?
Old 02-27-2004, 05:05 PM   #9
Hit Man X
Member#: 27787
'02 WRX Sedan
Whats your set up?
Full catless exhaust, IC hoses, and that Unichip currently.
Next mod will be a large TMIC then injectors and fuel pump once I decide on what turbo (prolly P&P'd VF35 for the 4EAT I have).
How would the ECU get reflashed and the UTEC for tweaking?
Also I don't want this hard to get back to stock in more than a day. I don't know how much longer I will keep this car (at least 6 months) if that makes a difference or not upon tuning.
Thanks!
Old 02-27-2004, 07:50 PM   #10
totoherbs
Member#: 7321
.... 122 IggPoints
Dont put all that work into the car if your not going to keep it...
You can pick up a cobb stage 2.5.... and the use the utec for tweeks. Or get an ecutek from a local tuner. Its not a cheep way to go but it works good. Again if you not going to keep the car dont put all this money into it, you wont get it back out.
http://forums.nasioc.com/forums/show...hreadid=507285
Old 02-27-2004, 09:28 PM   #11
Hit Man X
Member#: 27787
'02 WRX Sedan
Well I do all my own labor and almost always buy used parts so losing a few $100 doesn't bother me at all to have fun for now. This car is a good beater for me so hell, I may just run it to 100K mi then off it, it's tough to say.
How much is an ECUtek flash typically? What about dyno tuning a UTEC?
WTB: VF39, TXS Unichip/or Utec Bungers Evo5 Private 'Wanted' Classifieds 1 08-18-2006 12:20 AM
Hooking up an EBC to TXS Unichip MyRuRex Engine Management & Tuning 1 07-07-2003 09:31 PM
Do people use the UTEC to increase timing or decrease compared to stock? kenshiro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-02-2003 09:47 AM
UTEC vs Stage 1 TXS unichip comparisons/experiences? SCRAPPYDO Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-02-2003 08:32 AM
WTB: TXS UTEC, or TXS Unichip Mitsuby Mid Atlantic Impreza Club -- MAIC 1 02-14-2003 08:33 PM
