Old 02-21-2004, 10:21 PM   #1
joehack98
Member#: 53243
Default Coolent Temp Sensor Location and Part Number.
Hey All,
As the title states, can you help me located the coolent temp sensor and part number so I can replace mine on a ej20g.
Thanks.
Also, Has anyone ever had the issue of their gas needle dropping almost half a tank under "spirited driving" only to raise up to normal soon after.
joehack98 is offline   Reply With Quote
Old 02-22-2004, 02:41 AM   #2
joehack98
Member#: 53243
if not the part number, what other us engine is it compatible with?
Thanks
Old 02-23-2004, 03:42 PM   #3
Puckaveli
Member#: 1518
00 2.5RS
Go post this up on scoobynet.co.uk there you will find your answer.
Puckaveli is offline   Reply With Quote
Old 02-23-2004, 05:21 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
for the gas tank...how far is the rear end squating?....the gas will slosh which will cause the reading to be lower than there actually is...same thing happens on the interstate...
EJ20G O2 sensor problems and part number rob Subaru Conversions 4 04-23-2012 05:39 PM
coolent temp sensor lYNEl Normally Aspirated Powertrain 1 12-12-2006 10:56 PM
Coolent Temp Sensor & Idle? Token-Negro Engine Management & Tuning 0 10-22-2006 04:20 PM
oil temp sensor location cpu77 Normally Aspirated with bolt-on Forced Induction Powertrain 0 11-26-2002 05:55 PM
Where is the water temp. sensor located? spshultz Normally Aspirated Powertrain 2 09-06-2001 12:20 PM
