02-22-2004, 02:11 AM | #1 |
Member#: 33846
ignition timing???
what is the highest recommended advance typically run, I have a problem with the afc, everytime i lean it out the timing advance gets further and further. is there something wrong with my equiptment, i was logging +43 degrees with an otc flight recorder.
I dont know what to do, apparently it is very hard to compensate for 650s with an afc. I will be getting a utec soon but for the meantime I need some suggestions. thanks
02-22-2004, 10:02 PM | #2 |
Member#: 18709
i think since you're running richer conditions, the ECU is trying to compensate ignition timing for your richer/leaner a/f conditions. i think when you get your UTEC you should be fine in terms of optimal performance, as you will be able to adjust your timing map. are you running rich?
02-23-2004, 12:03 PM | #3 |
Member#: 36528
Vehicle:2002 Impreza Wrx Silver |
I think it's more cause you have really big injectors and/or a larger then stock piping holding your maf sensor. The result is the ecu seeing less air at any given point, thinking there is less load and advancing the timing....... If ya start out with higher numbers in your partial throttle fueling it would help a little, but I dunno what it would do to your fuel trim. Getting control of your timing(like with a reflash) would be key.
peace |
Idle timing/ low load ignition timing adjustment after cam install? | NITROS | Engine Management & Tuning | 2 | 03-18-2009 02:32 PM |
Valve timing & Ignition Timing | volleykid | General Community | 0 | 09-12-2005 11:25 AM |
('93-'01) Valve Timing & Ignition Timing | volleykid | Impreza Forum | 0 | 09-12-2005 11:23 AM |
Ignition Timing Vs Boost. | DJIMPREZA | Technical Forum Archive | 1 | 08-08-2000 05:45 PM |
MSD DIS 2 ignition timing control anyone out there tried it yet? | MPREZYA | Technical Forum Archive | 1 | 06-07-2000 09:38 AM |
