Old 02-22-2004, 04:41 AM   #1
SubyWRXer
Member#: 43137
2005 Legacy GT LTD
Default need help
when i step on the gas, the rpm goes up fast to about 4500 then drops back to about 2500 then climbs back up slowly... it happens in all gear except 1st gear.. any ideas? will utec cause this?
SubyWRXer is offline   Reply With Quote
Old 02-22-2004, 05:40 AM   #2
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Worn out clutch perhaps? Or you're slipping the clutch way too much when up-shifting...
Old 02-22-2004, 01:20 PM   #3
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
If you have the clutch all the way out and your engine revs up without the car accelerating, than almost certainly your clutch is worn out.
Mike Wevrick is offline   Reply With Quote
A/C Pressure switch 94 Leggy? Need Help DjKlown Legacy Forum 2 06-02-2010 05:42 PM
EJ25 build, need help! rcarlson87 Built Motor Discussion 0 06-02-2010 10:36 AM
Hard Drive Recover Help much needed... ATA RAID 0 knowledge needed HELP PLEASE!!! 2k2 Off-Topic 63 12-24-2003 10:35 PM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-18-2003 12:11 PM
Need help!Need flywheel bulletin from SOA.Please help. RallyeX General Forum Archive 3 06-01-2000 07:57 AM
