Old 09-29-2000, 10:07 PM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Thumbs down 1/4 mile times before and after S-AFC!
Well, I have to say that so far the S-AFC hasn't been any help. Not to mention that my check engine light is constantly on but that I can handle. Anyway Here are the pathetic times. The car is stock (MY00) except for Stromung Dual Tip and Mid pipe.
before w/S-AFC
R/T 1.002 .808
60' 2.160 2.171
330' 6.606 6.562
1/8th 10.303 10.273
mph 66.41 66.23
1000' 13.486 13.486
1/4 16.206 16.242
mph 82.87 81.92
Well, There it is. That is with the S-AFC set at -10% 1000-2000, -9% 2000-4000, -8% 4000-5000, -7% 5000-6500 for both high and low throttle.
As you can see the times are pretty much identicle. Without the S-AFC was actually a bit faster! This was in about 95 degree weather (Phoenix)
Eric
Eric SS is offline
Old 09-30-2000, 12:59 AM   #2
IMPBOY
Member#: 65
Post
Something is wrong. You shouldn't have the CE light. Check the wiring and make sure everything is connected to right pins. I also have AFC on my 00 and no CE and .6 off the 1/4 mile.
IMPBOY is offline
Old 09-30-2000, 06:40 AM   #3
john seput
Member#: 497
Post
How did you guys connect the AF wire? Are you reading after the cat?
Js
john seput is offline
Old 09-30-2000, 08:53 AM   #4
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Impboy, what settings are you running?
I'm finding that a 0% correction all across the board on my MY00 yields EGT's that are really close to optimal...
RidinLow is offline
Old 09-30-2000, 09:42 AM   #5
Akiata
Member#: 297
Smile
shouldn't you only use a AFC when you put on a intake? I have one on my legacy but I also have a weapon R intake.
And about the check engine light try disconecting the battery overnight (just to be sure) then reconect it and do the normal ECU reset. My CE light came on too. It also helps if you are friends with a subaru mechanic and can take it to him so he can plug in the OBDII and delete the light.
Akiata is offline
Old 09-30-2000, 10:37 AM   #6
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Post
I don't have the AF wire of the S-AFC hooked up. I'll try to reset the ECU. I'm pretty sure all of the wiring is fine. All of my monitors are working.
Eric
Eric SS is offline
Old 09-30-2000, 10:24 PM   #7
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Post
5 speed.
Eric
Eric SS is offline
Old 09-30-2000, 11:00 PM   #8
Red-Imp
Member#: 1742
2000 Imp 2.5 RS, SRP
& a fast red car ;)
Post
OT: Dude! You should have went rallycrossing with us in Prescott. We had a blast. I finally found something I can do.
Oh, and sorry to hear about the S-AFC. I don't think it will be much help w/o some sort of intake change (preferrably forced induction).
-Red
Red-Imp is offline
Old 09-30-2000, 11:35 PM   #9
Greg I
Member#: 384
2002 Acura RSX-S
Question
Well, your reaction time was slower on the second run.
If you take those numbers at face value, and assume all things being equal, it looks like you had significantly more power until you hit 60mph, where it trailed off (even with a slower R/T you caught up to where you were on the first run).
OR, you didn't shift as well towards the end of the run the second time.
OR, your 1-2 shift was better the second time.
Too many variables. You need to do more runs than that (which is my point). In any case, I wouldn't expect a huge difference in 1/4 mi times with relatively light mods...
Greg.
Greg I is offline
Old 10-01-2000, 12:17 AM   #10
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
Post
Is your car 5 speed or automatic?
WRC 555 is offline
Old 10-01-2000, 01:04 PM   #11
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Post
I think you need to work on your reaction time, the safc wont help you there.
munkis is offline
Old 10-01-2000, 01:11 PM   #12
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Question
What year is your car? MY99s seem to run lean with intake+exhaust, while MY00s seem to run rich.
bsquare is offline
Old 10-01-2000, 07:55 PM   #13
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
Question
Does reaction time matter? What I mean is does the time start when the light hits green or does time start once your car starts moving?
I thought reaction time only matters if you actually are racing against someone but doesnt affect time.
WRC 555 is offline
Old 10-01-2000, 09:15 PM   #14
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Post
WRC 555: You are correct. Reaction time has NOTHING to do with elapsed time. I could have a 10 second reaction time and still run a 16 second e.t. That's why in top fuel you will sometimes see someone with a slower e.t. beat someone with a faster e.t. if the person with the slower e.t. had a lot better reaction time.
Thanks
Eric
Eric SS is offline
Old 10-01-2000, 09:54 PM   #15
Greg I
Member#: 384
2002 Acura RSX-S
Post
RE: reaction time
Huh, didn't know that. Obviously I don't run the 1/4mi . The rest of what I said still stands though. I think you need to do more runs.
Greg.
Greg I is offline
Old 03-03-2001, 10:57 PM   #16
trojan9x
Member#: 3169
2001 2.5 RS: Holbert
Memorial Winner 2003
Post
how much are they and how hard are they to install?
trojan9x is offline
Old 03-03-2001, 11:05 PM   #17
cj917
Member#: 627
MY96 outback wagon
Question
like impboy said, something else might be wrong if your CE light is on a lot (maybe o2 sensor? are you part of the recall?)
also, with stock intake you are not gonna see much difference at all... and i thought some of us found that MY00 runs rich below 3500-4000rpm while lean above that?
what are you tuning your settings with?
cj917 is offline
Old 03-03-2001, 11:10 PM   #18
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Post
It's more like Eric's car is just that slow. He's got a runt until the Ludespeed kit goes into it.
kastle is offline
Old 03-03-2001, 11:16 PM   #19
XT6Wagon
Member#: 524
04 STi
Post
Something to think about:
If the track conditions are not exactly the same they will not produce the same results.
Also HOW you drive matters alot. You can for instance trade RT for ET if you know a little trick.
XT6Wagon is offline
Old 03-04-2001, 03:58 AM   #20
RS-LOVER
Member#: 4463
2000 Impreza RS
Blue Ridge Pearl
Post
I'm sorry to say but that isn't very good at all. I ran a 16.097 at Speedway in Orlando. That is completely stock! The only thing i did was remove the hood-scoop plate,and took of the front plastic air intake,silencer box,hood vent(stuck intake tube out hole)and side-stepped the clutch at 5200rpm.
RS-LOVER is offline
Old 03-04-2001, 08:06 AM   #21
trojan9x
Member#: 3169
Post
i got a 14.8 1/4 and 6.8 0-60 according to my G-tech with just the Ganz flow as being my only performance upgrade to date.
trojan9x is offline
Old 03-04-2001, 11:25 PM   #22
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
Trojan9x - the best "Ganzflow as only mod" qtr mile time I know of was Spunky at 15.08 with 200 lbs removed from the car, and 15.4 without him stripping the car. These times were real, from the drag strip. Wow!
ImprezaRS dot com is offline
Old 03-05-2001, 07:31 AM   #23
sanders
Member#: 187
2008 Impreza 2.5i
NBP
Post
i have the AFC in MY99... took off 0.2 off my 1/4. my best before then was [email protected] (3 times in a row) then i installed the AFC, and i have hit [email protected] and [email protected] all of my runs were also done at Orlando Speedworld. my mods were just Brospeed Muffler and the AFC - no I/H/ or mid-pipe... (oh yeah, full interior and a trunk full of my school books and spare tire )
sanders is offline
Old 03-05-2001, 08:36 AM   #24
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Well, if the track allows a variety of staging locations then shallow staging will give you a faster ET at the expense of RT because you're moving before you break the beam.
Anyway Eric, an intake would help but a turbo will help more. Unfortunately I would agree with the runt theory, 82MPH isn't good for a stock RS.
ColinL is offline
Old 03-05-2001, 09:09 AM   #25
Gambit
Member#: 102
Post
I thinku don't need an AFC for map based Imprezas. They don't run lean. But if you want shiny lights....
Gambit is offline
HTML code is On
1/8th mile results - before & after TXS Stage 2! 2QUICK4U Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 04-02-2002 03:05 PM
0-60 and 1/4 mile times joefocker20 Normally Aspirated Powertrain 1 03-01-2002 08:51 AM
('93-'01) if you have an intake and exhaust only on AT subie post you 1/4 mile time here SuBaRu-ImPrEzA_RS Impreza Forum 19 05-07-2001 08:46 PM
1/4 Mile time slips from last night...and a sighting. munkis General Forum Archive 0 10-12-2000 04:53 PM
My 1/4 mile times and question Keiho Technical Forum Archive 23 08-08-2000 01:52 AM
