Old 02-22-2004, 10:28 AM   #1
kuks
Member#: 39753
07 OBP WRX
03 Sonic Yellow WRX
Question cobb stage 2 questions.
Hey all,
I just got my bonus check from work and want to put it towards my wrx. I just ordered an access port(for stg2 93 oct) and already have a Txs rfl muffler and Bosal downpipe. My question is would my money be better spent buying a catback(bosal) or Hotchkis sways(front and back). I understand they are completely different mods, but I need to know if I need the catback to see gains. Would the catback make a big difference in power I FEEL? If not, I was concidering the sways. Any suggestions? Thanks for your help.
P.S.
Is there a pipe TXS I can buy that will make my RFL muffer a full catback(mate from my stock 3rdcat to my axle back)?
kuks is offline   Reply With Quote
Old 02-22-2004, 11:05 AM   #2
kedrin
Member#: 48380
theres a mad daddy or something mid pipe you can buy that replaces that. i think its 180 or something. hes posted in the vendors section
kedrin is offline   Reply With Quote
Old 02-22-2004, 01:56 PM   #3
abqkid
Member#: 52295
2003 WRX Wagon
I would go with the sway bro. When i got my catback (greddy evo) i did not notice much of a gain. Just noise. I am going to get some hotchkis sways also. I think that would more fun and a better overall up grade. You have to get new endlinks though and those are like 200 for a set of 4
abqkid is offline   Reply With Quote
Old 02-22-2004, 02:28 PM   #4
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
I agree. The muffler is the major restriction in the catback.
mexicanpizza is offline   Reply With Quote
Old 02-22-2004, 04:03 PM   #5
kuks
Member#: 39753
07 OBP WRX
03 Sonic Yellow WRX
Do I need the endlinks just to make the new sways fit, or do they help increase the handling? Also, I've never upgraded sways on any of my previous cars. What do they do. I know they will make my car feel more neutral through the corners, but what does that mean--will they eliminate the body roll? Thanks again, BK
Old 02-22-2004, 04:27 PM   #6
GeoffM
Member#: 30252
2005 996GT3,'15 3500
04 Ducati 749R #249
Have you already replaced your up-pipe, if you're going to be running cobb stg 2, I know i'd think about it before you clog up your cat and have bits and pieces of it flying into your turbo.....
GeoffM is offline   Reply With Quote
Old 02-22-2004, 06:04 PM   #7
kuks
Member#: 39753
07 OBP WRX
03 Sonic Yellow WRX
Has this actually happened to someone who is simply running a stage 2 setup?
Old 02-22-2004, 10:39 PM   #8
abqkid
Member#: 52295
2003 WRX Wagon
i haven't heard of anyone that this has happened to but i am sure that it might happen. I would not worry about not having an up pipe installed for your cobb stage 2 as it is not required by cobb. The cat is fixed to the up pipe so well that it took me 6 hours to get the whole thing cleaned out. Mind you i was also using high powered drills and chizzles to do this.
Old 02-22-2004, 10:52 PM   #9
pjdwrx
Member#: 52217
I thought turbo back was required for stage 2?
On this page look at part number AE-WRX-0202-91
http://cobbtuning.com/wrx/accessecu.html (3rd row down).
Just want to be sure, because stage 2 was going to be the first thing I did after installing my turbo back.
pjdwrx is offline   Reply With Quote
Old 02-22-2004, 10:58 PM   #10
allanak
Member#: 39856
2011 BMW 135i
Alpine White
For the best gains, you need a turboback. The only REQUIREMENT is a downpipe.
allanak is offline   Reply With Quote
Old 02-22-2004, 11:03 PM   #11
abqkid
Member#: 52295
2003 WRX Wagon
exaclty waht allanak said...only need a downpipe that eliminates all of the cats.
Old 02-22-2004, 11:34 PM   #12
pjdwrx
Member#: 52217
Thanks for the clarification. I'll be doing the turbo back first anyway, so no worries for me.
Old 02-23-2004, 02:44 AM   #13
JWerty1
Member#: 49215
2004 WRX Sedan
get the turbo back it yields a considerable gain and reduces spool, i'd go for an uppipe too just cuz no cats is great
plus if you already bought the accessport you can take full advantage of stage 2 with a catless setup
go for sways down the road
JWerty1 is offline   Reply With Quote
Old 02-23-2004, 03:16 AM   #14
Woody643
Member#: 34739
03 WRX
Silver Metallic
Default don't scare me like that
Hey,
Cobb states that you still are stage II even if YOU STILL HAVE the third stock cat. You only need to remove the second downpipe cat. You probably should remove or gut the stock uppipe cat for peace of mind.
Woody
Woody643 is offline   Reply With Quote
Old 02-23-2004, 03:48 AM   #15
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Originally posted by Woody643
Hey,
Woody
I would leave the 3rd cat in place... its not like that extra little bit is goint to make much of a difference. If you were that into you would go with a bigger turbo....
Old 02-23-2004, 05:38 AM   #16
links_courses
Member#: 42207
2004 WRX Sedan
PartyPoker Fiend
I upgraded my 2004 with the Cusco 22mm sway bar and GT-Spec solid endlinks. The handling is MUCH improved. Stock setup has built-in understeer (front end plows through turns instead of gripping) and adding a larger rear sway bar and solid endlinks has made my car pretty much neutral (front and rear drift equally.) Oversteer would mean the rear end swings out around a corner before the front.
I still use the stock RE92s which are not very good in dry/wet but have been decent in the snow this year. I imagine better tires might improve the handling as much as the sway bar.
links_courses is offline   Reply With Quote
Old 02-23-2004, 07:40 AM   #17
kuks
Member#: 39753
07 OBP WRX
03 Sonic Yellow WRX
Is it recommended to replace both the front and the back sways, or just the rear? How much of an improvement are the endlinks good for--just the rear or both? Thanks much, BK
Old 02-23-2004, 11:50 AM   #18
abqkid
Member#: 52295
2003 WRX Wagon
i have read that the endlinks don't make a huge diff. but they won't break like the stock ones might.
Old 02-23-2004, 12:15 PM   #19
kuks
Member#: 39753
07 OBP WRX
03 Sonic Yellow WRX
COOL! Thanks for everyone's input. I guess I'll be ordering some sways as soon as it warms up a bit. The catback and highflow cat will have to wait... for now. Thanks again, BK
Old 02-23-2004, 12:48 PM   #20
Jeff_DML
Member#: 32018
2008 M3 Sedan
Interlagos Blue
depends how stiff your rear sway bar is? I have the perrin adjustable rear sway and I initially set it the middle setting which is equivalent to 24mm. I thought it was a bit too much oversteer and abrupt when it happened, I am now running the weakest settting == 22mm and it seems very balanced so far. So if you want to run stiffer rear, 24mm or greater then you might want to replace the front. Otherwise I think 22mm in the back is a good match for the stock front 20mm.
I have stock endlinks
Jeff_DML is offline   Reply With Quote
Old 02-23-2004, 12:55 PM   #21
REXchampman
Member#: 39365
You dont need to get front and rear sway bars. I got a rear sway bar, set it to 22m, i noticed a difference the first turn i made. It does not reduce body roll, it just makes the car turn-in so much crisper. A catback, you will notice some gains, but not that much power. I say save your money and dont buy a front swaybar, the point is to reduce understeer not encouarge it. Plus, the wrx has plenty of power as it is, add better handing and youll have lots more fun!
REXchampman is offline   Reply With Quote
Old 02-23-2004, 01:26 PM   #22
OvRclockR
Member#: 20671
2002 Wrx sedan
I say get a maddad 3rd cat eliminator to improve your exhaust flow for the cobb stage 2. Keep your midpipe. It is good for sound damping purposes.
OvRclockR is offline   Reply With Quote
Old 02-23-2004, 06:14 PM   #23
oxtox
Member#: 33740
2012 sti hatch
wrb
i think stromung makes a 3rd cat eliminator and high flow cat/mid pipes. as for end links vs. sway bars, my impression is that whatever people change first is what they think made the most difference. i did rear links and sway bar with the whiteline heavy duty mounts and have been quite happy. for the money you'ld spend on a front bar you can change the alignment settings and tire pressures, will be pretty damn happy, and have money left over towards a short shiffter, morrettes, brake pads, yadda, yadda, yadda. just my long winded 2 cent which most likely belongs in the brakes and suspension section.
oxtox is offline   Reply With Quote
Bushur racing stage 1/cobb stage 2 questions boostdog Newbies & FAQs 9 06-07-2007 03:45 PM
Cobb Stage 2 questions thedude Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 01-29-2004 10:31 AM
cobb stage 2 question thewhitewrx Engine Management & Tuning 4 12-31-2003 03:30 PM
COBB stage 2 question thewhitewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-27-2003 02:19 PM
cobb stage 2 questions wrxracer55 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-02-2003 05:35 PM
