Welcome to the North American Subaru Impreza Owners Club Monday July 14, 2014
Old 02-22-2004, 05:52 PM   #1
Carnot
Member#: 34596
'05 WRX Wagon PSM
'03 WRX Sedan PSM (Hers)
Default Jackstand blocks for stock jack points
I have heard a lot of solutions to use jackstands on the stock jack points without bending the pinch weld. I have not however seen any good pictures, or heard of any solution that I felt comfortable with. So I built my own. I have Craftsman 3 ton jackstands, so I built by blocks to work with them.
The first thing that I did was slot the wood. I just used some 2X4 I had lying around. I used several passes with my cordless trim saw to cut a notch 1/2" wide and 3/4" deep. This is big enough for the pinch weld to fit snugly into without resting in the bottom.
For the next step, I found that the round part in the bottom of the stand cradle has roughly the same radius of curvature as 2" steel pipe. So I used a reciprocating saw to cut some pipe. I cut the length to be the same as the width of the 2X4. Then I cut it length wise so that it was about a 90 degree arc when viewed from the end.
The next step was to create the notches int he wood that were needed for the outer part of the jackstand cradle. To do this, I clamped my two pieces of wood back to back in a vice. I then used a 3/8" butterfly bit to very slowly drill directly where the two pieces met. The idea is to create a semicircular furrow for the cradle to fit into. Ideally, I would have a drill press for this, but I don't so patience and a keen eye did pretty well.
All that is left is to attach the pipe section to the block. I just drilled a couple of holes and screwed them in place.
I've only tried them once so far, but it was an outstanding success. It was very stable and with the pipe section underneath to support, the load is very evenly distributed to make sure the wood doesn't break.
Pictures:
-Bryce
Carnot is offline   Reply With Quote
Old 02-22-2004, 06:28 PM   #2
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
I was thinking of making some blocks like that with the slot for jacking up the car. Nice stuff you got there though.
Old 02-22-2004, 09:27 PM   #3
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Wow, very nicely done, Carnot!
Thanks for the detailed explanation and pictures.
vrg3 is offline   Reply With Quote
Old 02-23-2004, 06:46 PM   #4
outback_97
Member#: 30874
0897 OUTBACKS
and 2003 TS wagon
That's cool, good idea!
I'm assuming you've seen this, but maybe not:
http://www.scoobymods.com/forums/sho...hlight=jacking
Works for me with no crimping of the "pinch weld", FWIW.
Steve
outback_97 is offline   Reply With Quote
Old 02-23-2004, 07:43 PM   #5
Carnot
Member#: 34596
'05 WRX Wagon PSM
Thanks for the feedback.
outback_97, I hadn't actually seen that particular thread yet. That's interesting. I wouldn't have thought that you could support the car there without damaging anything. I guess that's why I made the blocks.
As for the jack pad, I've had a good experience using the pad made by
Protech. It costs more than a piece of wood, but I can't put a price on peace of mind. I've heard wood break while jacking up the car and my heart rate has only just now returned to a normal speed.
-Bryce
Old 03-11-2004, 02:12 PM   #6
HS WRB-rex
Member#: 7218
2002 Impreza WRX
WRB Pearl
What size pad do I need for a craftsman 3 1/2 ton jack with 3 1/2 ton stand?
Craftsman 3 1/2 ton jack with 3 1/2 ton stand
HS WRB-rex is offline   Reply With Quote
Old 03-11-2004, 05:59 PM   #7
leecea
Member#: 37359
2003 WRX
Another option, as has been said many times, is a $1 hockey puck that will fit nicely into the cup of most floor jacks and will not break like wood.
leecea is offline   Reply With Quote
Old 03-11-2004, 07:09 PM   #8
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
I know guys that have used hockey pucks 'carved' kinda like that...
Old 03-24-2004, 09:42 AM   #9
BlackEye
Member#: 36203
2003 WRX
Platinum Silver Met.
Default I just want a garage :(
Sad Bump...
BlackEye is offline   Reply With Quote
Old 04-01-2004, 07:53 PM   #10
BIGSKYWRX
Member#: 7958
09 GH B+
Good idea.
Prtech also makes a saddle for side lifting- most common for changing tires at autox/rallyx/track- it's designed for unibody lifting from the side:
What I'm going to ask them if the can make the same thing for stands- they already make covers for them:
Or possibly if they are thick enough you could just put a groove in them.
Big Sky
Old 04-04-2004, 10:20 AM   #11
Carnot
Member#: 34596
'05 WRX Wagon PSM
It would be nice if Protech would make a pad that would work for jackstands. Until then, here is an action shot of my blocks.
I am also longing for a garage. It doesn't help matters that I've spent the last couple of days helping my friend frame up his 24x32 foot detached garage. This is the toy garage, he already has a two-car on his house. I guess I'll just sit in my apartment and sulk for a while.
-Bryce
Jack point + Jackstands samleeiii Newbies & FAQs 2 08-13-2008 08:46 PM
wtt:wrx block for stock wrx wheels/tires xtian MWSOC Private Classifieds 3 10-13-2006 02:18 PM
Looking to borrow jack, jackstands, engine hoist, tranny jack, air tools? moss Mid Atlantic Impreza Club -- MAIC 2 06-27-2006 04:14 PM
WTB: EJ22T Block for stock Pistons nativo Private 'Wanted' Classifieds 0 06-16-2004 08:39 PM
suggestions needed for hydraulic jack & jackstands cj917 New England Impreza Club Forum -- NESIC 5 03-06-2001 02:19 PM
