Old 02-22-2004, 06:11 PM   #1
voam
Member#: 33460
2003 WRX Wagon
Default rear diff oil change / impressions
Lately decided to get started on the 30K mile service a little early ( at 20K) and when I saw the syrupy grayish fluid coming out of the rear diff I am glad that I didn't wait another 10k miles! Also changed the trans fluid with valvoline dino 75w90 gl5 at the same time. That fluid still had a nice golden color coming out. I know color is not necessarily indicative of an oils effectiveness but is that common for the rear diff fluid to be grayish?
Initial impressions after the change of just those fluids is that the whole drivetrain seems a lot smoother.
voam is offline   Reply With Quote
Old 04-09-2004, 08:31 PM   #2
03WRXMA
Member#: 35081
2012 WRX
bump^ any info on this?
03WRXMA is offline   Reply With Quote
Old 04-09-2004, 11:24 PM   #3
esteve
Member#: 28716
2006 STI
I changed my rear diff fluid at 10K miles and it was nasty and gray too. I read about other people having the same thing so it's probably normal.
Does anybody know the reason why? Perhaps an additive from the factory or the rear diff just wears more as it breaks in?
esteve is offline   Reply With Quote
Old 04-10-2004, 01:20 AM   #4
pityr
Member#: 31719
Mine was gray and nasty at 30K miles. It could just be the fluid they use in the rear diff.
pityr is online now   Reply With Quote
Old 04-10-2004, 01:36 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
It could be a graphite additive....tha would account for the color....
Old 04-10-2004, 03:02 AM   #6
wrx112
Member#: 35048
i just did mines today it was a bitch but well worth it
wrx112 is offline   Reply With Quote
Old 04-10-2004, 03:16 AM   #7
Rev1
Member#: 51240
08 Lexus IS350
Pretty easy to do, the only thing is the smell ... like fried onions or something ... Changed rear diff to Mobil 1 75W90 ... and some Motul Gear 300 oil for the 6sp...
Smoother overall as well... no way I was going to wait 30k miles to change them...
Rev1 is offline   Reply With Quote
Old 04-10-2004, 12:59 PM   #8
z&cobb
Member#: 12344
2002 2JC
blue
I hope it wasn't mousse (water sheared with heavy oil).
I never noticed anything like that from 5mt and rear dif change I did. I put valvoline in the front and Redline in the rear.
z&cobb is offline   Reply With Quote
Old 04-10-2004, 04:50 PM   #9
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
mine was nasty @ 9k miles. refiled with redline, car feels the same, which was never bad.
RS_to_WRX_swap is offline   Reply With Quote
Old 04-11-2004, 04:23 AM   #10
wrx112
Member#: 35048
its .8 quart right what ahppen if you put a little short on the diff?
Old 04-11-2004, 05:12 AM   #11
Rev1
Member#: 51240
08 Lexus IS350
.8 quart for the WRX and 1.1 qt for the STi
Old 04-11-2004, 07:42 PM   #12
WRXVII
Member#: 15854
VF34'd...
just got it done today... replaced with Mobil1 sylthetic @ 54k miles.
WRXVII is offline   Reply With Quote
Old 04-12-2004, 10:00 AM   #13
Ging
Member#: 3258
2000 Impreza TS
Filling the diff a little short shouldn't be a problem. It's basically a big pool of gear oil in the bottom of the diff that the gears spin into. so if it isn't really really under you should be okay I think
Ging is offline   Reply With Quote
Old 04-12-2004, 11:07 AM   #14
wrx112
Member#: 35048
^thanx i onli put .6 quart because i got lazy after doing oil n tranny. The tranny one smells like ish too
Old 04-12-2004, 11:57 AM   #15
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
The gray metallic color is normal. Just tiny metal shavings from normal breaking in. Once the gears are all broken in and "accustomed" to each other, you shouldn't get any more.
As for filling up the rear diff case, just plug the drain hole, and fill the case until gear oil starts to drip from the fill hole (when you can't get anymore in).
Old 04-12-2004, 01:59 PM   #16
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
ditto. When I changed the rear differential fluid the second time, the fluid came out looking new. I think it is definitely related to the initial break in and the factory fill.
Stanley is offline   Reply With Quote
Old 04-12-2004, 05:17 PM   #17
mycarsux
Member#: 32049
2010 sti
does anybody know what i should use for the 2002 2.5RS? and how do u change the rear diff? im like a total noob in the tranny fluids changing thing, so i anybody can tell me how im suppose to do all the tranny stuff, that'll be great. my car has 21,000 miles on it and i havnt touched the tranny fluids and the diff.
mycarsux is offline   Reply With Quote
Old 04-12-2004, 05:33 PM   #18
mycarsux
Member#: 32049
2010 sti
nm, im an idiot. i'll just search.
Old 04-12-2004, 05:38 PM   #19
Bimmer
Member#: 4116
2002 Impreza TS
I'm getting ready to change the oil in the rear differential, but I'm wondering how to get the plugs out...
I know that they're square holes, and that a half inch drive rachet will do it, but mine's a pretty loose fit... I don't want to risk rounding them out, because I've heard of how tight they're torqued in from the factory.
I thought I heard that there's a special tool that fits them... is this right?
TIA,
Ben
Bimmer is offline   Reply With Quote
Old 04-12-2004, 07:40 PM   #20
Rev1
Member#: 51240
08 Lexus IS350
I used a 1/2" breaker bar for teh bottom drain plug, and it worked great.
The Sti has the rear diff sensor on the top fill plug, so I just used a crescent wrench to remove it.
Old 04-12-2004, 09:20 PM   #21
Psydotek
Member#: 44168
2003 Yellow WRX
The ratchet will work. Just put it into the holes and then put the car spare tire jack under it and jack it up slowly. Don't worry, it'll open up. Just make sure to undo the top bolt first then the bottom.
[if the top one has seized up and you undo the bottom you'll have a hell of a time refilling the differential case...]
Rear diff oil change JayD707 Newbies & FAQs 5 09-30-2004 02:57 PM
rear diff oil change memphisjames Service & Maintenance 29 07-16-2004 02:46 AM
rear diff oil change shortfuseWRX Service & Maintenance 1 02-15-2004 03:54 PM
rear diff oil change? rexmobbin' Service & Maintenance 20 03-30-2003 01:05 AM
Tranny and Rear Diff oil changes help WRXThis Transmission (AT/MT) & Driveline 5 04-30-2002 06:25 PM
