Welcome to the North American Subaru Impreza Owners Club Thursday September 9, 2010
Old 04-03-2001, 09:53 AM   #1
adamsrs
Member#: 3768
Have a Nice Day? Coasting ILLEGAL!?!
I was just reading through title 46 of the Revised code of Washington. In washington state it is illegal to coast in nuetral on a downgrade. Weird, also it is illegal to lower your car so that the lowest point of the car is lower than the lowest part of the rim. Weird!
adamsrs www.unnatural.org
adamsrs is offline
Old 04-03-2001, 09:57 AM   #2
steve_d
Member#: 315
Post
Just put bigger rims on. with little tiny rubber band tires...
nuff said
sjd
steve_d is offline
Old 04-03-2001, 10:01 AM   #3
8Complex
Member#: 922
00 2.5RS
04 FXT
Post
They don't want you coasting in neutral because it picks up more speed then if you left it in gear (in an auto). If you're in a stick car it automatically keeps the car at a decent speed rather then accelerating so much that you get out of control. Personally, I think you're a wuss if you don't power down the hills.
8Complex is offline
Old 04-03-2001, 10:05 AM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
2001 2.5 RS
02 WRX Wagon Rally Car
Wink
it's also illegal to drive w/your parking lights (only) on....
and illegal to drive w/plastic headlight covers... especially the smoked ones... you are not allowed to alter your lights in any way, shape or form...
my car is basically a driving vehicle code violation
j.
Subie Gal is offline
Old 04-03-2001, 10:08 AM   #5
98mpreziveRS
Member#: 972
Post
*applauds* way to break the law Jamie
actually some of the stuff is REALLY dumb they make laws about..go figure
98mpreziveRS is offline
Old 04-03-2001, 10:08 AM   #6
adamsrs
Member#: 3768
Post
The only reason I would ever coast down a hill is if I was running out of gas.
adamsrs is offline
Old 04-03-2001, 10:13 AM   #7
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Post
Coasting downhill is illegal in most states. The reason: brakes don't work effectively.
Believe it or not, you save a little more gas by putting the car in gear than putting in neutral when going downhill.
In Japan, if you lower the car too low, the police will take it away. I saw that happened on news when I used to live there.
tmat3 is offline
Old 04-03-2001, 10:14 AM   #8
brainrally
Member#: 3683
2007 Impreza WRX
Shagginwagon
Post
And why would you want your car even as low as the lower part of your rims? Not very convenient for driving, 'specially when you're dirt drivin'.
Brian
brainrally is offline
Old 04-03-2001, 10:18 AM   #9
Subie Gal
GC84Ever
Super Moderator
Member#: 301
2001 2.5 RS
Wink
all sho.. no go...
trust me.. hehehe
i used to be one of them...
wheels sucked up into the fender liner... LOL!
when the weather went sour... i had difficulty driving!! now is that smart?? eh?? is it?? hmmmm... definately not SAFE!
lol
i was silly...
j. www.subiegal.com
Old 04-03-2001, 10:23 AM   #10
adamsrs
Member#: 3768
Post
Oh well it looks dope.
adamsrs is offline
Old 04-03-2001, 10:33 AM   #11
donjuan
Member#: 2248
Post
[delete]
[This message has been edited by donjuan (edited April 03, 2001).]
donjuan is offline
Old 04-03-2001, 11:13 AM   #12
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Post
Talking abotu dumb laws. did you know that it is illegal to work on your car in the state of New Jersey if you're not a certified mechanic? You basiclly can't even check your oil or tire pressure.
I see this thread getting moved to off topic pretty quick
Jim
Impreza Rider is offline
Old 04-03-2001, 11:14 AM   #13
Buck-O
Guest
Member#:
Post
Are you sure its just the car?
Old 04-03-2001, 11:15 AM   #14
98mpreziveRS
Member#: 972
Post
yeah but what IF a scooby mechanic touches a non-subaru in his driveway..is that illegal?
(just keeping it related to subaru )
edit: argh..i can not type today see that uppercase I and F..well i put id and then is and then made it all caps the right way..b/c it was making me mad
anyhow jamie, wheels into the fenders..i am going to guess you either removed your fender liners..or just dealt with rubbing the struts, liners, etc.
[This message has been edited by 98mpreziveRS (edited April 03, 2001).]
Old 04-03-2001, 11:25 AM   #15
remarcable
Member#: 2362
1999 Legacy Outback
Blue w/ Paint Chips & Mud
Post
Isn't coasting in an auto tranny subaru BAD for the AWD system?
Because if you can't tow it in neutral with all 4 wheels on the ground then it would make sense that coasting it down a hill with all 4 wheels on the ground would do the same damage.
Well, short-term I doubt it would do much harm... but if it was a REALLY LONG HILL........
remarcable is offline
Old 04-03-2001, 01:08 PM   #16
Eby
Member#: 1305
Post
I think you can just pull the fuse in the auto and tow it in 2wd mode.
Eby is offline
Old 04-03-2001, 01:16 PM   #17
remarcable
Member#: 2362
1999 Legacy Outback
Post
In the 4EAT subarus......
The FWD fuse is there to allow use of the donut spare which should not be used over 50MPH and no longer than 50 miles. This is from memory, so I may have a couple number juxtaposed.
You cannot tow the car with 2 wheels on the ground even in 2WD mode - this is a BAD THING to do. In an EMERGENCY you can tow the car in neutral for a mile or two with all FOUR wheels on the ground without any major damage to the AWD system.
With the manual xmission you can tow the car in neutral with all 4 wheels on the ground.
In reality, if you have an auto xmission subaru you need to have it towed on a flatbed unless you want expensive repairs and an undrivable car. Although... if you're having it towed it probably wasn't driveable in the first place, huh?
Like I said I am pretty sure this is correct because in the past I have researched it to death, but my memory is a bit vague on the numbers.
(edit: I contradicted myself, whoops!)
[This message has been edited by remarcable (edited April 03, 2001).]
Old 04-03-2001, 01:16 PM   #18
bryanw
Member#: 807
2002 WRX Wagon
Post
You don't want to drive down a grade in neutral. It can heat your brakes to a dangerous level, possibly causing them not to work. Keep it in gear to keep as much pressure off your brakes as possible, and your car (and you) will last longer.
bryanw is offline
Old 04-03-2001, 01:20 PM   #19
NebScoob
Member#: 2646
Post
EDIT...Someone already said same thing..
[This message has been edited by NebScoob (edited April 03, 2001).]
NebScoob is offline
Old 04-03-2001, 02:35 PM   #20
MarbleTurtle
Member#: 2959
Post
In Dalton its illegal to heard sheep through the town on Sunday... and me without my Shelties!
MarbleTurtle is offline
Old 04-03-2001, 03:08 PM   #21
Skirvdawg
Member#: 3375
2002 VW Jetta Wagon
Post
Who said that leaving the car in gear while going down a hill gives better mileage than coasting in neutral? Are you nuts? Consider this; your car is in neutral, effectively it is idling. Now consider this, your car is parked and running, and you're getting 0mpg. So while you're coasting down the hill in neutral, covering ground, how is it that you're getting less than 0mpg? Basically, you're getting free miles.
Skirvdawg is offline
Old 04-03-2001, 03:17 PM   #22
JGard
Pooptastic
Member#: 1904
2009 WRX Premium 5dr
1991 Mazda Miata
Post
and who would think that because you can't tow a subaru, you can't coast? sorry, not quite
there's quite a difference... when you coast, 4 wheels are on the ground. That's fine, cause they all have to spin the same speed. And you know what, if they still used tow hooks, rather than putting a car up with 2 wheels on a block, then you COULD in effect tow an AWD car without doing damage, because all wheels could spin.
Now, you can't tow a Subaru (be it manual or automatic) at all! Unless, like I said, they just pull it up by tow hooks, which isn't good, because every bump you hit, the car will slam on those chains.
but seriously, even though it does no harm, why put car in neutral when going down a hill? that's just more wear on your clutch than needed...albeit not much.
JGard is offline
Old 04-03-2001, 03:33 PM   #23
Skylab
Member#: 4263
2010 5'6" Catch Surf
Y-Quad Deluxe Foamer
Thumbs up
I side with Skirvdog. Coasting downhill on the freeway (Interstate 15 From El Cajon to Escondido), improved my MPG and MPTF DRASTICALLY!
My dad's got an '88 Sterling 825sl, 2.5 litre 24valve V-6, 5 speed) with the onboard computer which shows your instant and average fuel economy. By coasting on the downslopes of the 15 freeway, the car averaged on a 60 mile roundtrip 38.4 mpg.
This is no economy car. I just drove economy minded. Total mileage using 15 gallons of gas was 435 miles!
Same goes for the Scooby. So far I've achieved 353.4 miles on 14.2 gallons of gas. Pretty sure on a roadtrip that 400 miles on a tankfull is possible.
Skylab
(driving slow)
Skylab is offline
Old 04-03-2001, 04:54 PM   #24
adamsrs
Member#: 3768
Post
WOW lotsa replies!
adamsrs is offline
Old 04-03-2001, 05:37 PM   #25
RidinLow
Member#: 329
1999 C5
Post
Leaving your car in gear going down a hill uses less gas than putting it into neutral. Why? The ECU senses that there's no load, so it cuts the gas. You can feel this when you coast to a stop in second... you'll feel a surge when the revs near idle while the gear is still engaged... that's the gas & spark kicking back in.
RidinLow is offline
Bookmarks
HTML code is On
They're illegal aliens because they're here illegally. RastaMon Political Playground 64 09-22-2009 09:52 PM
anyone coming over to victoria for the coast to coast tsd rally? Ghostrider#2 Vancouver Impreza Club Forum -- VIC 5 06-14-2002 10:31 AM
Attn TSD'ers: coast to coast rally postponed Subie Gal North West Impreza Club Forum -- NWIC 0 04-08-2002 09:59 AM
To coast or not to coast Scoober01 General Forum Archive 17 03-03-2001 12:35 AM
Coast to Coast Rally cancelled rsquire North West Impreza Club Forum -- NWIC 5 10-11-2000 07:16 AM
Message Board Statistics All times are GMT -4. The time now is 03:39 AM.
