Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 02-22-2004, 08:38 PM   #1
jjtdiceman
Member#: 54926
Default new problem with 88 gl 10
I've got a 88 subaru gl 10 4wd 4cyl turbo. I had a problem with it not wanting to go over 56mph. I drove it the other day and turned it off for about 10 minutes. I tried to start it and it will barely idle now. It floods itself out. Gas will pour out the of the catalytic converter. It has a new fuel pump, filter, plugs, wires, cap, rotor, and everything is hooked up right. When i start it, gas comes out from between the turbo and the exhaust. If that gasket is bad, will it cause it to flood out? I tried removing the air filter to allow more fuel and it still flooded out. It's getting plenty of spark. I looked inside the turbo and the turbine turns fine, but there is a small amount of oil in there. Is the turbo bad? If so, can i just disconnect the turbo and run a pipe in place of it? I really need to get this car fixed.
jjtdiceman is offline   Reply With Quote
Need help with my GL 10 Tranny woes! Jeramiah 'Old School' Subaru Forum 2 02-17-2007 12:27 AM
88 gl-10 engine swap chevelle8389 'Old School' Subaru Forum 5 11-23-2006 11:37 PM
problems with 88 legacy jjtdiceman Legacy Forum 3 02-12-2004 06:20 PM
22B vents on 88 GL-10 XT6Wagon Interior & Exterior Modification 6 11-06-2000 05:56 PM
