Old 02-22-2004, 09:10 PM   #1
Hit Man X
Member#: 27787
'02 WRX Sedan
Default Tuning A/F off stock O2 sensor?
I'm considering upgrading from my TXS Unichip to the UTEC setup. I have AutoTap Enhanced currently and am wondering how close can I get in the mV on the regular O2 sensor? I've got my two trucks tuned via the stock O2 then put on a wideband and they were very close (off by about .1-.3) so I was wondering if anyone has had good luck w/o a wideband on the Subaru end?
Hit Man X is offline   Reply With Quote
Old 02-22-2004, 09:20 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I don't think so...
Old 02-22-2004, 10:26 PM   #3
codean
Member#: 10186
the stock front O2 sensor is only able to read down to around 11.73 to 1 and is NOT very accurate.
codean is offline   Reply With Quote
Old 02-22-2004, 10:34 PM   #4
Hit Man X
Member#: 27787
'02 WRX Sedan
Ah well, thanks guys.
Old 02-23-2004, 07:52 AM   #5
TheMadScientist
Member#: 23717
2005 Big red
I use the stock front O2 as a check that I am not lean. The OBD software that I use reads down to 11.3:1. I just make sure that I don't go over that. After tuning my car on the road with UR600's and a 16G the A/F on the dyno was 11.2-11.0 from 4800-6400 droping to 10:1 at redline.
TMS
TheMadScientist is offline   Reply With Quote
Old 02-23-2004, 09:06 AM   #6
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
how do you read off the front O2? a basic A/F gauge?
GMTarkin is offline   Reply With Quote
Old 02-23-2004, 09:43 AM   #7
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
DeltaDash
jblaine is offline   Reply With Quote
Old 02-23-2004, 01:15 PM   #8
TheMadScientist
Member#: 23717
2005 Big red
My harrisonR&D OBD scanner does it too.
TMS
Old 02-23-2004, 03:15 PM   #9
Hit Man X
Member#: 27787
'02 WRX Sedan
AutoTap reads in mV's and I have based A/F off those. All I'd need to do it sounds like is to get someone to give me a reading of their O2 who's been tuned already to give me a target mV.
Old 02-23-2004, 07:00 PM   #10
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
You could use the rear O2 (narrowband) just as you did on your previous cars. Its true that if you're careful, you can get a decent tune from a narrowband O2. It won't be exact, but pretty close.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 02-24-2004, 03:29 AM   #11
Delicious Tuning
Member#: 1990
Vaus is correct. You can get a decent tune from the rear O2. If you know what values to look for then you are all set. I even tuned my RS-T only on the rear O2, poeple said I was crazy. 2 years later of driving a 245 wheel horsepower and 285 ft/lbs of torque and people started to think otherwise.
I will admit a really good O2 helps a lot. But don't rely on it, because it will get dirty and in the end becomes less accurate much faster than one that is a little more vague. As it will get dirty but will still be in the same ball park for tuning.
Cheers,
Bill Knose
Tuner I-Speed USA
Delicious Tuning is online now   Reply With Quote
Old 02-24-2004, 10:27 PM   #12
Rickyh
Member#: 40453
does anyone know what the values would be? as in how many mV's equals roughly what af ratio?
Rickyh is online now   Reply With Quote
Old 02-25-2004, 04:20 AM   #13
Delicious Tuning
Member#: 1990
A lot depends on the O2 sensor and if it is dirty, wether there is a cat in the system or not? Etc...
The only way to really know from the start, is to turn the car on and let it idle. You know this is about 14.5:1 A/F ratio. Now get the narrow band reading from that.
Drive down the road in cruising condition and get the average reading for the narrow band, here, the car will be anywhere from 13:1 to 14.5:1. You can then deduce what is 13:1 as you know what 14.5:1 is.
Now you have an idea of that range. Next try flooring it, if it is a stock WRX, they like to run RICH!!! So your O2 sensor will be some number again, but you know the A/F ratio is at least 10:1. So you know have the range and what is important and not.
Add in a fudge factor for safety and you should be all set. Go to the dyno and see how accurate you were with the values, you might be very surprised.
Cheers,
Bill Knose
I-Speed USA
Old 02-25-2004, 04:49 PM   #14
Rickyh
Member#: 40453
which wire do I tap into for the front 02 sensor(assuming that that is the one to use).
Old 02-25-2004, 05:02 PM   #15
Hit Man X
Member#: 27787
'02 WRX Sedan
Why would you tap into it? Use a program such as AutoTap to monitor the voltage to it to get the WOT A/F levels...
Old 02-25-2004, 05:23 PM   #16
Rickyh
Member#: 40453
because i do not have autotap. i have an safc and i can hook up one of the wires to the o2 sensor to read the voltage from it.
Old 02-25-2004, 11:30 PM   #17
Hit Man X
Member#: 27787
'02 WRX Sedan
I dunno what the SAFC is but I'd check the manual that came with it to see what wire is needed. I believe the WRX has a 4 wire O2 sensor, so if you can find the signal that should be the correct wire to tap into.
Good luck!
Old 02-26-2004, 04:27 AM   #18
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Again...
I'd use the rear O2 sensor if you're used to tuning with standard narrow bands.
-- Ed
Old 02-26-2004, 05:01 AM   #19
Delicious Tuning
Member#: 1990
Rickyh,
I would suggest NOT using the front O2 sensor, as this is wide band O2 sensor. The AFC from what I remeber does not work off a wide band it works off a narrow band. you could damage something if you try using the wideband.
So my suggestion is to use the rear O2. If you want to find out which one it is please goto. www.northursalia.com
Cheers,
Bill Knose
I-Speed USA
www.i-speed.us
Old 02-26-2004, 09:04 AM   #20
Rickyh
Member#: 40453
Well, i admit i was really trying to get out of spending 350 on a wideband. I guess I will just have to suck it up and spend the money.
Old 02-27-2004, 07:10 PM   #21
Conduit
Member#: 6162
MBP, 1st WRX Ever in FL.
Suck it up and get the DeltaDash. That is going to be the most useful tuning tool you have, frankly.
Conduit is offline   Reply With Quote
Old 02-27-2004, 10:09 PM   #22
copracer288
Member#: 50590
2007 Charger SRT8
black
What would be the ideal A/F ratio?
copracer288 is offline   Reply With Quote
Old 07-06-2004, 10:19 PM   #23
jugger
Member#: 64228
can anyone tell me what the stock a/f readings are at WOT???
thank you
jugger is offline   Reply With Quote
Old 07-07-2004, 09:03 AM   #24
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
thank you
~10:1
mbiker97 is offline   Reply With Quote
Old 12-20-2004, 07:15 PM   #25
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Sorry for dragging this from the dead again
Going RS-T soon with the AVO kit, but really no money to spend on a Wideband...
1) The Link ECU doesn't take wideband, and my thoughts are tapping the rear O2 signal for the Link as a reference.
2) Front stock wideband is about a foot from the turbo on the downpipe, around where the bend towards to tail. I'm thinking of finding some cheap way to read of that.
3) Equal length headers are coming when the funds are available as well as the VSD Concept, and thus not really wanting to spend for an EGT and getting the probe welded to the stock headers
4) Supposingly the Link has a map already for the AVO kit
Given the above, should I try to do a first cut road tune after the kit goes in? What should I be looking for in case the map doesn't work too well in the colder weather up North? And lastly, while I'm kind of blind in terms of tuning (no EGT, read off the stock O2 front and rear), how handi-capped I'm with this kind of equipment to tune?
Thanks
Chris
kgb is offline   Reply With Quote
How to take off front O2 sensor from manifold???? STINOMORMONEY Newbies & FAQs 9 10-08-2008 08:55 PM
PDE DP w/ stock o2 sensor. Need extended? hossak8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-26-2004 03:49 PM
About Stock O2 Sensor BoostdBoxer Engine Management & Tuning 1 02-24-2004 03:13 AM
FS: Borla Gen 4 Headers, stock O2 sensors munkis Tri-State Area Forum 0 02-09-2003 10:43 AM
Autometer A/R Gauge compatible with stock O2 Sensor??? ChrisV-FL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-25-2002 09:40 AM
