Old 02-22-2004, 10:26 PM   #1
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
blue ridge pearl-sold
Default fuel pump relay question
In my 00 2.5RS it had a wire going from the fuel pump relay to the ECU, (b134,16) Now that I have swaped in a 2004 ej20 ECU,it no longer needs this wire. I'll be hooking up the fuel pump controller black/yellow wire to the black/red power wire,but what to do with the relay control wire?....EDIT,after looking over the two wiring diagrams it looks like I could just ground this wire and then the relay should work, yes/no?
imprezaclipse is offline   Reply With Quote
Old 02-23-2004, 11:42 AM   #2
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
that's correct. just splice that wire into the ground off of the main relay.
Z
Zephyr is offline   Reply With Quote
Old 06-09-2007, 11:24 PM   #3
tombro22
Member#: 151041
1998 outback
white
got a 98 outback... won't start when it has ran a while and you shut the engine off and try to restart it... it cranks but won't start up. I can't hear the fuel pump buzz when I turn the key on. I have changed the pump, but still does the same. Thinking it might be the fuel pump relay or the ecm. what is the most common problem? don't want to spend money on a ecm. seams to restat after it cools down. are relays a dealer part? how much?
tombro22 is offline   Reply With Quote
Old 06-13-2007, 04:57 PM   #4
tanyasauction
Member#: 151362
1993 subaru
black
thats really strange, i have a 1993 impreza saloon wrx and i have the exact same problem your having. When my car was cooling down it would start up again then stop i dont think shes getting fuel to the engine. Now she doesnt even start at all. I think my fuel relay has blown or my pump has gone. any suggestions.
thanks.
tanyasauction is offline   Reply With Quote
need fuel pump and fuel pump relay 4/18/10 raceckr MWSOC Private Classifieds 1 04-18-2010 03:05 AM
Fuel Pump Relay Control and Airconditioner Cut Relay Control modifiedauto Newbies & FAQs 0 09-19-2007 08:43 PM
Fuel Filter replacement - where is fuel pump relay? SeenDubAYouAreEx Newbies & FAQs 4 07-11-2007 09:29 PM
fuel pump relay question ILwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-15-2005 08:38 PM
Fuel Pump Relay Question NickSTi Normally Aspirated with bolt-on Forced Induction Powertrain 2 06-03-2002 03:31 PM
